I think yours is an 81? In that case, teh screws are located at the sides, under the carpeted sides of the centre tunnel. You'll need to remove those side first. They are held by screws that are located a) beside the seats, partially hidden, and b) towards teh front, in the footwell. I usually have to remove one seat as I can't access the screws without! Then you will see screws for the centre console at the sides and, I think, at the back. I believe you can lift it from teh back and it is not necessary to remove the gauge cluster.
