 ShipMyCar.co.uk
» Failed oil pump drive by Daytona Vette on Sun 23 Sep 18 17:11
» 2008 z06 jacking pucks. by Jack Oreilly on Sun 23 Sep 18 09:31
» C3 that are in UK 1968-73 with chrome bumpers pics please! by L88 on Sat 22 Sep 18 19:11
» C8 is Coming by Alan305 on Sat 22 Sep 18 14:01
» Resto Vette - or - Modifed Vette by MIT on Sat 22 Sep 18 11:18
» Amazing by MIT on Sat 22 Sep 18 11:07
» Spare wheel light by PAZ9556 on Fri 21 Sep 18 19:35
» '95 C4 with LT1 missfire by corvetteville on Fri 21 Sep 18 18:42
» 1989 C4 For Sale by RickyG512 on Fri 21 Sep 18 14:28
» C7 Configurator by c6pete on Thu 20 Sep 18 12:46
» C2 fibreglassing and prep. by L88 on Wed 19 Sep 18 20:50
» What did you do with your Vette today? by FelixP on Wed 19 Sep 18 13:44
» Potential new C5 owner - some basic questions by Le Vette on Tue 18 Sep 18 14:09
» Stunt Driving from 1966 Chevys by Daytona Vette on Tue 18 Sep 18 10:47
» 1966 C2 Corvette Wilwood Master Cylinder by L88 on Mon 17 Sep 18 11:44
» Euro to US tail lights help by julian marshall on Sun 16 Sep 18 11:41
» Mid engined Corvette by Norm on Sat 15 Sep 18 15:19
» C3 Side Exhaust Pipes by CaptainK on Fri 14 Sep 18 13:10
» Presume this is my battery on the way out? :-( by roppa440 on Fri 14 Sep 18 00:02
» [Pics] C6 Corvette's in the UK. by autocolor on Thu 13 Sep 18 19:45
» T-tops - single / double latch by Vetteheadtony on Thu 13 Sep 18 14:06
» Breakfast meet by VetteWeekend on Wed 12 Sep 18 20:20
» Recommended Restorers by CaptainK on Wed 12 Sep 18 12:12
» 1990 L98 C4 not starting by lovejoy on Tue 11 Sep 18 19:28
» CCCUK West Sussex meeting in September by robbiew on Tue 11 Sep 18 18:34
» South Central Regional Meeting for September by Daytona Vette on Mon 10 Sep 18 12:22
» My 01 c5 yellow for sale by Celcius on Sun 09 Sep 18 20:58
» For Sale 09 C6 Corvette by John Lynn on Sun 09 Sep 18 01:25
» C2 Bonnets by L88 on Sat 08 Sep 18 22:56
» BBCN Regional meet by autocolor on Sat 08 Sep 18 09:48
L98 Misfire problem
Go to page: Previous / 1, 2
Sid.123
Mon 09 Oct 17 19:22
I was going to suggest a vacuem leak as did roppa as mine had an initial flat spot on acceleration which I found to be caused by perished 30yr old vacuem pipes....
But if you say number 7 plug was black/rich it could be that athough the injector may be clicking it may be stuck open.I would try cleaning the plug and running with the injector unplugged to see if the plug still gets wet etc or run it with the plug out while unplugged to see if fuel is ejected from the hole.
59/69 silver beige/medium brown. 1 of 1,014 in 1986. C4 glasstop
Manj82
New Comer
Sat 14 Oct 17 23:21
Re: L98 Misfire problem
I'm chasing a miss on a LB9 Trans Am so will watch this with interest Smile
Noticed you mentioned you replaced your injectors with Bosch D3's. Have you checked your fuelling after this and what's your crank times like
I query as I changed the injectors in my trans am to D3's (that according to a vendor were supposedly a like for like replacement) and the car was running pretty lean according to a scan of the fuel trims; BLM high 140's, low 150's on idle and max out at 160 in some cases when driving. Had I not had a scan tool, I would've been clueless about this other than an occasional lean surge
I had to burn a chip with adjustments to the injector constant and some other tables to get the fuelling close to the desired 128.
A google search whilst diagnosing found that quite a few people experienced similar lean conditions with their TPI cars (L98, LB9) and had to pull out the laptop...
just thought to mention
FelixP
Addict
Wed 08 Nov 17 10:55
I finally got to the bottom of this and it was a cheap and easy fix!
When I changed the leads a few had got a little too hot near the headers despite having those socks on the boots. When I put new leads on, I didn't take the boots off to slide on the heatshields. Anyway, I started it up and now we have darker evenings, I saw one of the leads shorting against the header!
I'll have to run them very neatly. I was using Summit racing leads but had put new AC Delco ones on, I guess the insulation isn't as good, as they were further away from everything previous but still the spark jumped across. Thank you daylight savings! And a good lesson in checking & double checking the simple things silly
1989 Corvette C4 L98 6 speed ZF with Z51 & FX3
chevrolet
Wed 08 Nov 17 12:41
Well Done/Top Marks Thumbs up So can we call that a "Leaking Spark Plugs Wire" job/fault, as in the Haynes manual Trouble Shooting section above?
AKA "Silver C6" on Pistonheads
