 Adrian Flux
» Black '68 by Ddave on Sun 22 Jul 18 22:04
» Shooting for 1000whp with my C7 @ Top Cats Racing by 5 USA on Sun 22 Jul 18 20:38
» BBCN Regional Meet by autocolor on Sun 22 Jul 18 08:50
» A rather fast C2 vette by Vetteheadtony on Sat 21 Jul 18 21:37
» Damn Yankees Summer Slam - North Weald by Vetteheadtony on Sat 21 Jul 18 21:32
» Vulcan Tour 2018 by 666Vette on Sat 21 Jul 18 18:54
» Is this 'The begining of the end' OR 'The end of the begining' ? by Daytona Vette on Sat 21 Jul 18 17:07
» Spare wheel kit 74 by MIT on Sat 21 Jul 18 13:44
» Silverstone Classic - 20/21/22 July 2018 by jukebox on Sat 21 Jul 18 12:56
» New member in Retford, Notts.......! by elv19.pn@outlook.com on Sat 21 Jul 18 09:11
» 1978 C3 Corvette Silver Anniversary L82 Automatic by geoff917 on Fri 20 Jul 18 17:08
» International Corvette & Camaro Meeting 2019 - 20th Anniversary by Alexa-Italy on Fri 20 Jul 18 16:31
» Valkenberg - A Beschi family tribute by JonnyC4 on Thu 19 Jul 18 20:48
» C5 Z06 centre caps? by yenko 1969 on Thu 19 Jul 18 11:11
» 15x8 OEM Rally wheels by Ddave on Thu 19 Jul 18 08:44
» Looking for a C6 Z06 by IbanezDan51 on Wed 18 Jul 18 23:56
» Buying a C6 Convertible.... Or more likely a Targa Top by chevrolet on Tue 17 Jul 18 22:18
» For Sale - C4 '84-'86 E (Early) Solid Roof by chevrolet on Tue 17 Jul 18 20:30
» Corvette-Fame 13-14-15 July 2018 by JonnyC4 on Tue 17 Jul 18 18:06
» Developing Starter Issue by kentvette on Mon 16 Jul 18 18:41
» What did you do with your Vette today? by roppa440 on Mon 16 Jul 18 09:39
» Garage services required for a C3 in the NW by Daytona Vette on Sun 15 Jul 18 20:06
» NEC Classic Car Show - Birmingham by 86vetteman on Sat 14 Jul 18 22:39
» C4 coupe wanted by Redridge Corvette on Sat 14 Jul 18 21:54
»  by Nosheruk on Sat 14 Jul 18 17:44
» How to post a photo in the forums by Nosheruk on Sat 14 Jul 18 17:38
» New member, new c3 on order! by Forrest Gump on Sat 14 Jul 18 12:06
» C5 seat refurbishment by roscobbc on Sat 14 Jul 18 09:29
» Classic + Vintage Vehicle Festival - Peterborough by curious bystander on Fri 13 Jul 18 17:35
» R/H door lock mech and clip by MIT on Fri 13 Jul 18 16:53
Problem solved
Grahamred70
Sun 22 Oct 17 18:41
Problem solved
At last I hope to have got to the bottom of the running issues I've had since I first got my vette on the road, carburation has always been less than perfect and after trying various tacks including a complete rebuild I finally bit the bullet and went for a new carb all the way from the good old US of A in the form of a Holley Brawler 670 cfm vacuum secondary electric choke like this https://www.holley.com/products/fuel_systems/carburetors/bra...
Fitted it today and started up and joy of joys at last she idles, think I need to tinker with the fast idle as it shot up to 4000 revs when it first fired up but a quick blip of the throttle brought it down to a more acceptable level!
The problem with the original carb, a 600cfm Holley, was that the Performer manifold although drilled for both square bore and spread bore carbs the base of the carb didn't match the mounting flange of the manifold which resulted in an air leak where the PCV connection is.
It was only when I removed the carb the gap in the marking of the gasket gave away the problem, an adaptor plate would have been an option but under bonnet clearance is tight anyway so probably wouldn't have fitted in.
If we get a dry day I'm looking forward to see how the new carb performs.
Graham
Graham, red 1970 convertible 350
roscobbc
Sun 22 Oct 17 19:04
Re: Problem solved
That's a particularly good spec' for a vac secondary carb - the 4 corner idle screws will help set things up.
CCCUK Chairman
