 ShipMyCar.co.uk
» A rather fast C2 vette by Forrest Gump on Fri 20 Jul 18 22:20
» Damn Yankees Summer Slam - North Weald by roscobbc on Fri 20 Jul 18 21:04
» 1978 C3 Corvette Silver Anniversary L82 Automatic by geoff917 on Fri 20 Jul 18 17:08
» International Corvette & Camaro Meeting 2019 - 20th Anniversary by Alexa-Italy on Fri 20 Jul 18 16:31
» New member in Retford, Notts.......! by IbanezDan51 on Fri 20 Jul 18 11:21
» Valkenberg - A Beschi family tribute by JonnyC4 on Thu 19 Jul 18 20:48
» Vulcan Tour 2018 by Bowler on Thu 19 Jul 18 12:58
» C5 Z06 centre caps? by yenko 1969 on Thu 19 Jul 18 11:11
» 15x8 OEM Rally wheels by Ddave on Thu 19 Jul 18 08:44
» Silverstone Classic - 20/21/22 July 2018 by curious bystander on Thu 19 Jul 18 08:23
» Looking for a C6 Z06 by IbanezDan51 on Wed 18 Jul 18 23:56
» BBCN Regional Meet by Nicetie on Wed 18 Jul 18 22:58
» Buying a C6 Convertible.... Or more likely a Targa Top by chevrolet on Tue 17 Jul 18 22:18
» For Sale - C4 '84-'86 E (Early) Solid Roof by chevrolet on Tue 17 Jul 18 20:30
» Corvette-Fame 13-14-15 July 2018 by JonnyC4 on Tue 17 Jul 18 18:06
» Spare wheel kit 74 by BertieGas on Mon 16 Jul 18 23:40
» Developing Starter Issue by kentvette on Mon 16 Jul 18 18:41
» Shooting for 1000whp with my C7 @ Top Cats Racing by roppa440 on Mon 16 Jul 18 15:07
» Black '68 by Jan25 on Mon 16 Jul 18 10:23
» What did you do with your Vette today? by roppa440 on Mon 16 Jul 18 09:39
» Garage services required for a C3 in the NW by Daytona Vette on Sun 15 Jul 18 20:06
» NEC Classic Car Show - Birmingham by 86vetteman on Sat 14 Jul 18 22:39
» C4 coupe wanted by Redridge Corvette on Sat 14 Jul 18 21:54
»  by Nosheruk on Sat 14 Jul 18 17:44
» How to post a photo in the forums by Nosheruk on Sat 14 Jul 18 17:38
» New member, new c3 on order! by Forrest Gump on Sat 14 Jul 18 12:06
» C5 seat refurbishment by roscobbc on Sat 14 Jul 18 09:29
» Classic + Vintage Vehicle Festival - Peterborough by curious bystander on Fri 13 Jul 18 17:35
» R/H door lock mech and clip by MIT on Fri 13 Jul 18 16:53
» What modern spark plugs for 1973 454? by roscobbc on Fri 13 Jul 18 00:43
Spark Plugs - 1968 327
Tue 07 Nov 17 16:52
Hello all. I've been searching the internet and on the forums for the spark plugs I need for my 1968 327/300hp Corvette (original engine), and just found tons of different plug numbers and some saying that a 1968 327 doesn't exist.
So I thought I'd give in and ask here in case any of you know good plugs or part numbers for the 1968 327. The engine isn't particularly fancy or highly modified - just aftermarket carb and manifold. From reading the threads on here, some say Champion plugs, other say NGK.
Ideally from a UK seller please. Thanks Smile
Tue 07 Nov 17 19:28
Re: Spark Plugs - 1968 327
My manual says AC44.
I looked at The Green Spark Plug Co. They seem to do 44.5. But, I found the NGK equivalent is B6S and they have that.
http://www.gsparkplug.com/1x-ngk-copper-core-spark-plug-b6s-...
Highly recommend GSPC, very reasonable price and speedy delivery. Plus, if you want to be sure, you can choose your plugs by size, length, contact size etc etc....
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
Chris Sale
Wed 08 Nov 17 00:21
I agree with Stephen's recommendation. I have been using NGK B6S for many years in my '64 which also has the 300 HP 327. My annual mileage runs between 4000 - 5000 miles and I change plugs every two years.
If, after you have put a few thousand on your first set of B6S you think you could go to a hotter plug in some cylinders, you can install BP5S which are one 'range' hotter and have a projected tip. My No. 8 plug has always been prone to fouling before the others, presumably because of oil getting past the valve stem seals, and a BP5S stays clean for longer.
Chris Sale
CCCUK 436
NCRS 11971
'64 Coupe
roscobbc
Wed 08 Nov 17 01:25
Agree with Chris - I use NGK's on my big block, and yes generally replace every two seasons or when misfires start-up. I changed to BCPR6's to try and cure plugs going 'open circuit' with the 7's (it did improve - and these are resistor plugs which I believe are easier to source from local autofactors) - in my case plug fouling is caused by a combination of prolonged city use coupled with the rich idle mixture needed with a rumpity - rumpity camshaft and big double pumper carb. Even the super powerful spark from a MSD system has its limitations Yes
CCCUK Chairman
Wed 08 Nov 17 08:43
Thanks everyone. When I did a search on the forum I found multiple references to the Green Spark Plug co, but I didn't know which plugs I needed. Tried to look at other sites to cross reference and just ended in a pickle.
I'll get some ordered soon, as the engine isn't particularly happy with life, and I'm changing the carb and inlet soon, along with the dist and leads and figured I may as well change the plugs too. Problem is, I believe to change the plugs you need to remove the exhaust manifolds, and I was thinking of replacing my exhaust manifolds with a better set, so I'll be on a big parts buying session soon.
Thanks.
jmvette
Addict
Wed 08 Nov 17 18:18
I
Fri 10 Nov 17 12:55
Well, the Green Spark Plugs co seems very efficient - I ordered them shortly after my comment above and they arrived the next day. Well done GSPCo. Smile
