 ShipMyCar.co.uk
» Le Mans 2019 by philv8 on Fri 19 Oct 18 17:26
» 2009 C6 LS3 wing mirrors by 86vetteman on Fri 19 Oct 18 16:13
» A trio of C2 owners. by L88 on Fri 19 Oct 18 14:46
» Help with newly acquired 72 350 Auto by Jimbo64 on Fri 19 Oct 18 10:03
» Silverstone Classic 2019 by curious bystander on Thu 18 Oct 18 20:01
» AC belt by corvetteville on Thu 18 Oct 18 17:55
» Spec lists by kentvette on Thu 18 Oct 18 16:41
» Birdcage repair by johng on Thu 18 Oct 18 12:49
» Strange tacho by kentvette on Thu 18 Oct 18 12:44
» What did you do with your Vette today? by FIVE RED on Thu 18 Oct 18 12:25
» C3 Hooker Side Pipe headers by icandycanvas on Wed 17 Oct 18 16:18
» C3 Side Exhaust Pipes by icandycanvas on Tue 16 Oct 18 20:52
» Wiper actuator on a 69L by Ddave on Tue 16 Oct 18 18:36
» Tips by CaptainK on Tue 16 Oct 18 13:44
» Im interested in a C5 Z06 (this time next year) by Benbay001 on Tue 16 Oct 18 12:55
» Engine cutting out after firing up by Firepit on Tue 16 Oct 18 09:19
» Thinking About Hanging Them Up....... by Norm on Mon 15 Oct 18 15:44
» BBCN Regional meet by Nicetie on Mon 15 Oct 18 12:57
» C5 O2 sensor code?? by roppa440 on Mon 15 Oct 18 08:45
» C2 fibreglassing and prep. by L88 on Sun 14 Oct 18 17:16
» Road Atlanta this weekend. by UkBeancounter on Sun 14 Oct 18 14:29
» New Series of Wheeler Dealers an 02 Z06?? by dex99 on Sun 14 Oct 18 12:02
» Door removal on 79 coupe by Nigelcurry on Sat 13 Oct 18 20:01
» American Day - Museum of Power Essex by Forrest Gump on Sat 13 Oct 18 17:44
» C5 Performance Projects - book by robbiew on Fri 12 Oct 18 21:19
» speed bleeders by Grahamred70 on Fri 12 Oct 18 16:17
» South Central Regional Meeting and Midlands-ish Breakfast Club - October by Daytona Vette on Fri 12 Oct 18 10:44
» Essex Regional meeting by roscobbc on Fri 12 Oct 18 08:36
» 1972 Washer bottle wanted by Vetteheadtony on Thu 11 Oct 18 22:48
» Vette Hire In The U.S. by 86vetteman on Thu 11 Oct 18 20:33
Injectors / Fuel Filter Changed
voguev8
Regular
Fri 10 Nov 17 18:49
Had a go at doing the job myself
My 1993 LT1 looked as though it still had the factory fuel filter and definitely the original injectors.The fuel filter was a bit of a job due to doing on axle stands but do able. The 8 injectors were easy to change took about 20 minutes.
What a difference - worth doing - faster,smoother and better mpg.
dm575
Regular
Sat 11 Nov 17 10:16
Did the same on my 91, massive improvement. I envy the injector position on the LT1, L98 is a bit more than 20 mins !!! Smile
1991 Black C4 Targa L98 Auto
1997 White Z28 Camaro Coupe LT1 Auto
Redlevel
Mon 13 Nov 17 14:43
Re: Injectors / Fuel Filter Changed
Injectors are simply solenoids controlling flow pintles activated by pulses of 12vdc. They can get a bit dirty affecting the spray pattern and reduced rate via dirty filters. If the solenoids are good (15ohm-ish), they just need a clean.
Mine were Rochester injectors as stock on an '87 L98. I had them refurbished by these guys for 100 and a week away. The difference was tangible, faster smoother etc..
When you install injectors, best to lubricate the O rings with silicon grease as its quite benign as regards rubber, whereas other petroleum based oils and greases can degrade the O rings especially with heat over time. My own original injector seals were very hard and inflexible, i.e. perished.
https://www.fuelinjectorclinic.co.uk/
