 ShipMyCar.co.uk
» 17th Annual Straight Run....... by Norm on Mon 22 Oct 18 16:25
» Spotted C2 by Daytona Vette on Mon 22 Oct 18 12:22
» C6 For Sale? by Atomic UK on Mon 22 Oct 18 05:35
» C5 standard wheels and one aftermarket multispoke. by L88 on Sun 21 Oct 18 16:13
» Help with newly acquired 72 350 Auto by Grahamred70 on Sun 21 Oct 18 12:17
» CCCUK East Sussex meeting in October by Sea5 on Sat 20 Oct 18 22:21
» C2/C3 rear trailing arms plus other parts by L88 on Sat 20 Oct 18 13:56
» Le Mans 2019 by kentvette on Sat 20 Oct 18 12:48
» 2009 C6 LS3 wing mirrors by 86vetteman on Fri 19 Oct 18 16:13
» A trio of C2 owners. by L88 on Fri 19 Oct 18 14:46
» Silverstone Classic 2019 by curious bystander on Thu 18 Oct 18 20:01
» AC belt by corvetteville on Thu 18 Oct 18 17:55
» Spec lists by kentvette on Thu 18 Oct 18 16:41
» Birdcage repair by johng on Thu 18 Oct 18 12:49
» Strange tacho by kentvette on Thu 18 Oct 18 12:44
» What did you do with your Vette today? by FIVE RED on Thu 18 Oct 18 12:25
» C3 Hooker Side Pipe headers by icandycanvas on Wed 17 Oct 18 16:18
» C3 Side Exhaust Pipes by icandycanvas on Tue 16 Oct 18 20:52
» Wiper actuator on a 69L by Ddave on Tue 16 Oct 18 18:36
» Tips by CaptainK on Tue 16 Oct 18 13:44
» Im interested in a C5 Z06 (this time next year) by Benbay001 on Tue 16 Oct 18 12:55
» Engine cutting out after firing up by Firepit on Tue 16 Oct 18 09:19
» Thinking About Hanging Them Up....... by Norm on Mon 15 Oct 18 15:44
» BBCN Regional meet by Nicetie on Mon 15 Oct 18 12:57
» C5 O2 sensor code?? by roppa440 on Mon 15 Oct 18 08:45
» C2 fibreglassing and prep. by L88 on Sun 14 Oct 18 17:16
» Road Atlanta this weekend. by UkBeancounter on Sun 14 Oct 18 14:29
» New Series of Wheeler Dealers an 02 Z06?? by dex99 on Sun 14 Oct 18 12:02
» Door removal on 79 coupe by Nigelcurry on Sat 13 Oct 18 20:01
» American Day - Museum of Power Essex by Forrest Gump on Sat 13 Oct 18 17:44
Alternators and Starters
Go to page: Previous / 1, 2, 3, 4 / Next
Tue 21 Nov 17 09:52
Bowler wrote (View Post):For what it's worth Adrian at ABM Vettes in Weymouth will probably be able to rebuild your starter for you
Yeah, that was one person I was considering after your recommendation thanks. I've also got some local starter motor (and alternator) rebuilders in my area which I thought would be better as I wouldn't have to spend on postage and stuff.
But I'm just considering getting a better OEM replacement (the Powermaster one) as the reviews look good and it'll be better than my original standard motor. Then when my original has been taken out, I'll probably get it rebuilt at some point and keep as a spare. Smile
I'm also going to be getting other parts from Summit Racing soon, so tagging a starter into the postage hopefully shouldn't add up to much more. Obviously import tax is still a bummer though.
Thu 30 Nov 17 11:26
Well, I've ordered my "bunch of parts", including the Powermaster starter motor.
Now, I've replaced a starter motor before in a 2003 MG, and I've read my Haynes manual on how to change the motor in a Corvette and it looks simple (undo negative battery cable, disconnect cables to starter motor & solenoid and mark them up, undo two bolts and remove starter, reinstallation is reverse of removal and put the same amount of shims back in that came out). But the Haynes manual is based on a later post chrome bumper model C3 Corvette. So I thought I'd check with you here - is there anything specific I need to know about changing the starter motor in a 1968 Corvette? And what's with the shims? I get that I have to space it correctly, but I've yet to find photos of the shims and where they go. I know it'll be rather obvious when I take it apart, but I'm just educating myself beforehand.
Thanks Smile
roscobbc
Thu 30 Nov 17 14:28
Re: Alternators and Starters
Shims are used under fixing bolts to set correct gap between ring-gear on flywheel or torque converter plate. Challenging job with a manual. Less so with auto.
CCCUK Chairman
z06_tim
Thu 30 Nov 17 14:53
Reasonably clear instructions for shimming a starter motor here: https://itstillruns.com/shim-starter-chevrolet-5904862.html
2001 Z06, 1994 LT1 (sold)
Alfa 147 GTA daily driver.
roscobbc
Thu 30 Nov 17 23:12
Simple enough if the bellhousing is removed (manual transmission) - don't think that there is an inspection window or access to do clearance by this method on manual C3 - I think the use of engineers blue and trial and error is the alternative.
CCCUK Chairman
roscobbc
Thu 30 Nov 17 23:13
CCCUK Chairman
roscobbc
Thu 30 Nov 17 23:13
CCCUK Chairman
z06_tim
Fri 01 Dec 17 07:37
I figured it would be likely they didn't provide an inspection window!
Mon 04 Dec 17 09:38
roscobbc wrote (View Post):Shims are used under fixing bolts to set correct gap between ring-gear on flywheel or torque converter plate. Challenging job with a manual. Less so with auto.
Ahhh... I understand now thanks. I'm guessing just putting back the same numbers of shims as it had before is just a bit too easy? (which is what the Haynes manual says to do :O )
And typically I have a manual gearbox..... I thought things were supposed to be easier with manuals...... Banghead
Mon 04 Dec 17 13:30
CaptainK wrote (View Post):Ahhh... I understand now thanks. I'm guessing just putting back the same numbers of shims as it had before is just a bit too easy? (which is what the Haynes manual says to do :O )
I had thought that the shim "issue" might be another reason to go for a rebuild? That way, presumably, you would just put the same shims back in when the rebuilt starter was replaced.
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
