 Ian Allan Motors
» Lights by Daytona Vette on Sun 19 Aug 18 11:45
» Another 'nail in the coffin' for UK based motorsport by chevrolet on Sat 18 Aug 18 22:00
» Carpets for 56 C1 by vet80y on Sat 18 Aug 18 19:22
» Heads/cam by roppa440 on Sat 18 Aug 18 16:15
» Spare wheel light by Nigelcurry on Sat 18 Aug 18 11:34
» 2003 Anniversary Red and Shale Convertible. by Number3 on Fri 17 Aug 18 19:30
» BBCN Regional meet by Nicetie on Thu 16 Aug 18 19:47
» Tyres by roscobbc on Thu 16 Aug 18 13:02
» Drag event... by roppa440 on Thu 16 Aug 18 09:20
» 1989 C4 For Sale by RobBrom on Wed 15 Aug 18 19:56
» C5 Headlamp Adjusters "Golden Rods" by roppa440 on Wed 15 Aug 18 16:31
» Shooting for 1000whp with my C7 @ Top Cats Racing by Sierra on Tue 14 Aug 18 14:19
» U-joint replacement by MIT on Mon 13 Aug 18 22:37
» C6 European Rear Light Conversion by Daytona Vette on Mon 13 Aug 18 16:42
» Full geo setup needed. by Daytona Vette on Mon 13 Aug 18 10:33
» C3 Side Exhaust Pipes by CaptainK on Mon 13 Aug 18 10:00
» Kit Kat wrappers don't make good insulation by CaptainK on Mon 13 Aug 18 09:52
» Head Unit Replacement by L88 on Sun 12 Aug 18 13:57
»  by Chris123 on Sun 12 Aug 18 12:24
» 1968 Door Handles by riddyboy on Sat 11 Aug 18 08:54
» Aircon fixed at last! by Daytona Vette on Fri 10 Aug 18 13:29
» Headlight Buckets by kentvette on Fri 10 Aug 18 09:40
» C3 Auto Box Issue Just Developed by Daytona Vette on Thu 09 Aug 18 22:52
» CCCUK West Sussex meeting tonight 9th August by Sea5 on Thu 09 Aug 18 18:27
» History of my vehicle VJD 5G by Bill Riches on Thu 09 Aug 18 16:58
» Borgeson steering box upgrade. by Skeets on Thu 09 Aug 18 13:19
» Cumbria classic (Dalemain House) car show. Sunday 19th August by 666Vette on Thu 09 Aug 18 12:26
» Concours of Elegance by curious bystander on Wed 08 Aug 18 16:47
» What did you do with your Vette today? by MIT on Wed 08 Aug 18 15:31
» South Central Regional Meeting for August by Daytona Vette on Wed 08 Aug 18 10:35
Power and Torque figures from rolling road test
quarterflash
Mon 27 Nov 17 12:23
Hi
I recently had my car tested on a rolling road. The figures are as follows:
Engine power - 285 bhp or 212Kw, Wheel power 222bhp or 166Kw and Torque - 214lb.ft
Max power at 132mph.
Bearing in mind that the engine is from a '95 vette do the figures seem about right?
I think the power might be in the right region but the torque seems low.
Thankx
Q
Chevy and Porsche coming together
roscobbc
Mon 27 Nov 17 19:06
Re: Power and Torque figures from rolling road test
Torque is rarely higher than BHP - seems about the correct balance IMHO
CCCUK Chairman
Invetterate
Mon 27 Nov 17 22:29
Apologies Ross but I don't think it can be right....
The '95 LT1 was "advertised" with 300hp @ 5000rpm and 340 lbs-ft @3600rpm. So 285 seems about right. More to the point and assuming the 285hp is produced @ 5000, then the amount of torque needed to produce it is calculated as follows:
Torque =
HP x 5252 [The 5252 is derived from 33000 ft-lbs/min divided by 2pi]
RPM
= 285 x 5252 = 299.36 lbs-ft
5000
This, of course, is at RPM above torque peak so peak torque will be higher. As long as the RPM figure from the dyno is about 5000, the engine must be producing at least 299 lbs-ft.
Sure it is not 315 on the print out?
roscobbc
Mon 27 Nov 17 23:53
I bow to superior (and better investigated/calculated) knowledge - and in hindsight I had it all 'ass about face' anyhow Willy (its age related........ Banghead)
CCCUK Chairman
Invetterate
Tue 28 Nov 17 09:05
Know that feeling! silly
roppa440
Wed 29 Nov 17 12:34
At 5252rpm, horsepower will always exactly match torque because 5252 divided by 5252 cancel each other out.
So at that exact rpm HP=Torque.
Before 5252rpm Torque is always higher than HP and by 5000rpm will already be dropping past it's peak.
After 5252rpm HP is always higher than torque but in number terms can be close but not as high as torque was.
