 Ian Allan Motors
» Rear spring by Dellb on Fri 23 Feb 18 21:16
» Faulty time clock by Dellb on Fri 23 Feb 18 21:13
» C7 remote start by Number3 on Fri 23 Feb 18 17:45
» Headlamps by kentvette on Fri 23 Feb 18 17:05
» Earls Barton Classic Vehicle show by Nicetie on Fri 23 Feb 18 13:34
» Earls Barton Classic Vehicle show by Nicetie on Fri 23 Feb 18 13:33
» Earls Barton Classic Vehicle show by Nicetie on Fri 23 Feb 18 13:32
» Earls Barton Classic Vehicle show by Nicetie on Fri 23 Feb 18 13:31
» Earls Barton Classic Vehicle show by Nicetie on Fri 23 Feb 18 13:30
» BBCN Region February meet at Meguires by Nicetie on Fri 23 Feb 18 13:14
» Steering Wheel Position Sensor - Reset? by Rich on Fri 23 Feb 18 13:00
» C5 thrown a 'serpentine' belt by Le Vette on Fri 23 Feb 18 12:50
» Numbers matching by paj66 on Fri 23 Feb 18 11:39
» How it's made - Corvette Stingray by FIVE RED on Fri 23 Feb 18 11:29
» Does anyone recognise this Vert by MIKERED on Fri 23 Feb 18 10:09
» The Scottish Car Show 15th July 2018 by roppa440 on Fri 23 Feb 18 09:55
» Engine bay by Nigelcurry on Fri 23 Feb 18 09:16
» OBD connector ? 1 or 2 by stevel98 on Fri 23 Feb 18 09:08
» 1960 C1 steering box by paj66 on Thu 22 Feb 18 17:50
» London 'T' charge by roscobbc on Thu 22 Feb 18 17:35
» Tewkesbury Classic Vehicle Festival by curious bystander on Thu 22 Feb 18 17:30
» RockAuto.com Discount Code for Parts & More - Expires April 4, 2018 by Rich on Thu 22 Feb 18 16:00
» "Breakfast Club" Meeting - March by Bowler on Thu 22 Feb 18 14:18
» What did you do with your Vette today? by stevel98 on Thu 22 Feb 18 13:35
» London Classic Car Show - 15th-18th February 2018 by Fishy Dave on Wed 21 Feb 18 15:00
» Letter of conformity by Barrelmaker on Tue 20 Feb 18 21:04
» The Mods continue on my C7 by C7KEN on Tue 20 Feb 18 18:42
» New road tax regs.. by CaptainK on Tue 20 Feb 18 08:55
» What do you carry? by CaptainK on Tue 20 Feb 18 08:47
SBC engine
Go to page: Previous / 1, 2, 3 / Next
roppa440
Tue 05 Dec 17 13:13
Re: SBC engine
stevel98 wrote (View Post):Not good.. Sad
Hope your going to be ok and not have to swap your C5 for an SUV. Rolling Eyes
I'm just happy it's not a wooden box. Laughing
Tue 05 Dec 17 13:24
Re: SBC engine
roppa440 wrote (View Post):stevel98 wrote (View Post):Not good.. Sad
You would not like that Dave! - Every time I have seen one of those on the road, they are never doing more than 5mph.
Barry - Daytona Vette
stevel98
Awww... join the CCCUK!
Tue 05 Dec 17 16:07
Re: SBC engine
Sometimes at the mortuary here, its a Saab hearse that turns up to collect the deceased.
As if dying isn't bad enough! Sad
roppa440
Wed 06 Dec 17 09:35
Re: SBC engine
stevel98 wrote (View Post):Sometimes at the mortuary here, its a Saab hearse that turns up to collect the deceased.
It's been like a mortuary on this forum lately I have noticed.
Back to the original post subject, I just want to add that the high initial advance will probably sort most of the problem by giving you enough rpm to get the throttle blades closed enough to pull the idle mixture circuit online. But sometimes with a very big can you will also need to drill a small hole in each throttle blade to get the RPM up enough. Starting at 0.5mm and going up in 0.5 steps until correct idle speed is achieved.
I have head Ross say "you have to run rich with a big cam to get it to idle". This is not actually true. It is down understanding how to best modify the distributor and carb to match the engine modifications.
Here are the readings from my 550hp 440 Chrysler when I had it. Idle mixture 14.2 rpm 880rpm, 9.1 inches of manifold vacuum.
roppa440
Wed 06 Dec 17 09:37
Re: SBC engine
I have noticed there has been no response from the other experts on here.
roscobbc
Wed 06 Dec 17 10:05
Re: SBC engine
What I actually said was "low vacumn means stock power valves will flood engine with too rich a mixture at low rpm" i.e. HiPo cam usually means low intake vacumn. If using a carb (in this case 4160) the low vacumn will 'trick' the carb into thinking that it needs an enriched mixture and opening up the power valve (as it would under conditions of acceleration). Simply put - the OP needs to establish which power valve (valves) are installed in his carb before doing to much more.
CCCUK Chairman & Editor, Vette News
roppa440
Wed 06 Dec 17 10:30
Re: SBC engine
roscobbc wrote (View Post):What I actually said was "low vacumn means stock power valves will flood engine with too rich a mixture at low rpm" i.e. HiPo cam usually means low intake vacumn. If using a carb (in this case 4160) the low vacumn will 'trick' the carb into thinking that it needs an enriched mixture and opening up the power valve (as it would under conditions of acceleration). Simply put - the OP needs to establish which power valve (valves) are installed in his carb before doing to much more.
Gotcha. Thumbs up
roppa440
Wed 06 Dec 17 10:44
Re: SBC engine
Just to add a couple of things for interest.
Main primary jets I adjust to around 13:1 mixture or just a touch leaner. I find this gives the best power and plug colour with modern fuel. In the old days we used to aim for 12.5:1 which seems too rich now.
If you have a Holley carb with metering plates instead of jets on the secondaries your only option used to be to drill the holes in the plates if they needed to me richer - making it a J-B Weld job if you want to go back the other way.
But Promax carbs came out with this neat metering plate that takes normal Holley jets. I used them on my 440 and they really take the guesswork (well some of it) out of secondary tuning.
roppa440
Wed 06 Dec 17 10:48
Re: SBC engine
Also bear in mind that on an auto transmission car the mixture will be leaner and the rpm higher when idling in neutral. You need to tune the idle mixture in gear on an auto.
Dellb
Fri 29 Dec 17 11:54
Re: SBC engine
Hi All
Many thanks for your advice, it worked. I have increased the secondaries, and decreased the primaries and she is fine, with the volume control screws now doing their job.
However another issue has raised its head that roppa440 touched on. The engine is fitted with a comp cam magnum 270. It is smoothest (vac disconnected) at an enormous amount of initial advance. 23 degrees. At this it is quite smooth and pulls 15 inches vacuum.
If I drop to the 15 degree norm, it becomes quite rough and the vacuum drops to 13 inches which is right on the limit of the 6.5 power valve. The current vacuum is taken off the carb. With the Mallory unilite distributor mechanical advance, the total advance is going to be unacceptable.
On another issue, I got a Gunson gastester as a Christmas present. My thoughts are, with a dual plane inlet manifold, how do you determine which control screw to adjust?
Any ideas?
Delb
Derek L G
