 Adrian Flux
» What did you do with your Vette today? by sssammm on Mon 23 Apr 18 22:58
» 1990 zr1 power key by Leadfootnlazy on Mon 23 Apr 18 22:06
» Touch up kits for my 1979 coupe by JJVETTE on Mon 23 Apr 18 21:32
» Stroud Classic Car Show by curious bystander on Mon 23 Apr 18 16:04
» Importing C4, but need to temporarily register in the UK by peterguest on Mon 23 Apr 18 12:58
» Now we're digital - Membership Renewals by vetteheadracer on Sun 22 Apr 18 21:12
» Harmonic balancer by Vetteheadtony on Sun 22 Apr 18 20:39
» Hand break adjustment by roscobbc on Sun 22 Apr 18 20:36
» Speedfest 2018 by Celcius on Sun 22 Apr 18 17:44
» Croyden Classic Car + Fun day by curious bystander on Sun 22 Apr 18 16:35
» Air con pump by weslp00 on Sun 22 Apr 18 12:26
» Corvette Nationals 2018 - pre booking. by Vetteheadtony on Sat 21 Apr 18 19:31
» 2019 Zr1 by roscobbc on Sat 21 Apr 18 18:59
» Wanted: C5 Z06 by yenko 1969 on Sat 21 Apr 18 17:42
» 1993 Cutting Out by Vetteheadtony on Sat 21 Apr 18 16:30
» Concours of Elegance by curious bystander on Sat 21 Apr 18 09:05
» Sunday Scramble - Bicester Heritage Centre by Daytona Vette on Fri 20 Apr 18 12:53
» camaro 1988 5.0L V8 for sale by yellowvette on Fri 20 Apr 18 12:14
» C2 Vert Yellow by Daytona Vette on Fri 20 Apr 18 11:55
» '64 "Survivor" C2 Corvette 327ci 365hp Roadster Just Arrived by stevel98 on Fri 20 Apr 18 09:00
» How do you get a l48 to 300 ish hp or engine swap by stevel98 on Thu 19 Apr 18 12:58
» 1981 corvette 64,000 mile on it way over by Vetteheadtony on Thu 19 Apr 18 10:40
» C4R-FEST tickets by curious bystander on Wed 18 Apr 18 15:35
» Corvette C6 oil filter and correct Oil / Owners manual by Eddie101 on Wed 18 Apr 18 13:08
» Parking brake adjustment by Nigelcurry on Wed 18 Apr 18 08:59
» C2 - Headlamp Not rotating by Bowler on Wed 18 Apr 18 07:01
» AACI Open Nationals by Bowler on Wed 18 Apr 18 06:51
» Youngest Member of the CCCUK? by Howard on Tue 17 Apr 18 22:25
» Corvette Club badge by kentvette on Tue 17 Apr 18 19:19
» Weather predicting by stevel98 on Tue 17 Apr 18 16:53
C4 ZR1 1990 - Serpentine Belt Fitting Issues
CDC
Sat 13 Jan 18 18:42
All
Having severe difficulty seeing how my new belt will fit even with the incredibly awkward tensioner fully retracted (is there a way to release the spring element so i don't have to hold it against its own tension constantly?). Is this a standard problem that everyone recognises? It made me reconsider whether the belt is the right length. I would like to think it is, however now i have it routed on and just waiting to get it over the alternator, i'm not keen to take it all off again to measure it against the old one. Markings on the belts are as follows if it sheds any light on the issue.
Old one: 5060810
New one: 5PK2030 800K6
Any insights appreciated.
Thanks
Charlie
gary 53
Sat 13 Jan 18 19:37
If you fully retrack the tensionor with I 1/2" bar the belt should fit on
Mine did ok
LOOKING FORWARD TO SUMMER
chevrolet
Sat 13 Jan 18 20:46
Re: C4 ZR1 1990 - Serpentine Belt Fitting Issues
Where did you get the new belt from/supplier? Is it a "Dayco" manufactured one? You say the old one is part # 5060810. If you look/search on the Rockauto website, 5060810 (Dayco manufactured) is not for a Corvette. Their Dayco part number for a ZR1 is 5060805.
Presume the new one (# 5PK2030) is this Dayco one?
https://automotivesuperstore.com.au/dayco-5pk2030
AKA "Silver C6" on Pistonheads
Sat 13 Jan 18 21:32
Not sure on the C4, but with my after market setup it can be a question of adjusting the Alternator to facilitate the Belt placement and even removal of the Alternator Pulley and then, replacing the Pulley with the Belt already on it.
These Belts can shred easily, worth keeping a spare to hand for the future.
Barry - Daytona Vette
CDC
Sun 14 Jan 18 11:55
chevrolet wrote (View Post):Where did you get the new belt from/supplier? Is it a "Dayco" manufactured one? You say the old one is part # 5060810. If you look/search on the Rockauto website, 5060810 (Dayco manufactured) is not for a Corvette. Their Dayco part number for a ZR1 is 5060805.
I bought the new one from Customville American http://customville-american.co.uk/
You say #5060810 is not for a covette, but it's been fairly happy on mine up until now.
After taking a step back and starting again i actually measured both belts this time. In hindsight this is how i should have started. I didn't do this in the first instance as Customville American took my VIN number and confirmed the belt they were sending was for a C4 ZR1. Anyway, measured them both a dozen times and we can see the problem.
Old: 2050mm
New: 2020mm
Time for a longer belt.
Appreciate all the quick feedback. Hopefully this car will be useable one day.
chevrolet
Sun 14 Jan 18 13:33
The ZR1 has a different serp belt part number to the "regular" C4. You are concluding that Customville have sent you the wrong (too short) belt. However, looking at this, you should expect a new "correct" belt to be shorter, because the old one will/may have stretched. Whether it will have stretched by 30mm, I do not know?
http://www.ebay.co.uk/gds/Guide-to-replace-your-C4-Serpentin...
Customville may be OK, but I would be going to Ian Goss or Keith at Eurovettes first, and would go for the OE AC Delco item.
VetteWeekend
Webmaster
Sun 14 Jan 18 19:12
CDC wrote (View Post):chevrolet wrote (View Post):Where did you get the new belt from/supplier? Is it a "Dayco" manufactured one? You say the old one is part # 5060810. If you look/search on the Rockauto website, 5060810 (Dayco manufactured) is not for a Corvette. Their Dayco part number for a ZR1 is 5060805.
Old: 2050mm
New: 2020mm
Hi Charlie,
Definitely think your 2030 (2020) is too small (as you've found out), I have a spare Dayco which is 2045 bought from Ecklers I believe. On Jerrys Gaskets site they stock Gatorbacks that are 2045 (80.5"). They also recommend checking the alternator pulley just in case its not the original ZR-1 part. The 2030 might fit if you had the smaller pulley?
Belt, Serpentine for 90~95 ZR-1 LT5. One Serpentine Belt is required per engine. Belt length is 80.5" and is the correct size with the LT5 pulley 2.5" alternator pulley diameter.
We recommend that you confirm the alternator pulley size on your engine, before ordering. Replacement alternators will frequently come with a smaller diameter pulley, more commonly used on other engine applications such as the L98 (2.2" dia). If you have a small pulley, 2.2", we recommend an 80" belt to work properly with the belt tensioner
http://www.jerrysgaskets.com/belt-serpentine-goodyear-90-95-...
Last edited by VetteWeekend on Sun 14 Jan 18 20:21; edited 2 times in total. [7 %]
CCCUK on Facebook
VetteWeekend
'75 Shark (on a shoestring) - Sold!
'58 Apache - The shop truck - Sold!
'91 ZR-1...For Fun! - The Return of Purple Haze!
'72 GMC G15 'Shorty' - Rolling Heavy.
www.kickson66.uk - For Official Gas Monkey Garage Merch & More.
