 Adrian Flux
» CCCUK East Sussex monthly meeting in August by Sea5 on Mon 20 Aug 18 22:41
» Lights by kentvette on Mon 20 Aug 18 18:12
» U-joint replacement by langlj00 on Mon 20 Aug 18 13:03
» Carpets for 56 C1 by vet80y on Mon 20 Aug 18 08:42
» Another 'nail in the coffin' for UK based motorsport by chevrolet on Sat 18 Aug 18 22:00
» Heads/cam by roppa440 on Sat 18 Aug 18 16:15
» Spare wheel light by Nigelcurry on Sat 18 Aug 18 11:34
» 2003 Anniversary Red and Shale Convertible. by Number3 on Fri 17 Aug 18 19:30
» BBCN Regional meet by Nicetie on Thu 16 Aug 18 19:47
» Tyres by roscobbc on Thu 16 Aug 18 13:02
» Drag event... by roppa440 on Thu 16 Aug 18 09:20
» 1989 C4 For Sale by RobBrom on Wed 15 Aug 18 19:56
» C5 Headlamp Adjusters "Golden Rods" by roppa440 on Wed 15 Aug 18 16:31
» Shooting for 1000whp with my C7 @ Top Cats Racing by Sierra on Tue 14 Aug 18 14:19
» C6 European Rear Light Conversion by Daytona Vette on Mon 13 Aug 18 16:42
» Full geo setup needed. by Daytona Vette on Mon 13 Aug 18 10:33
» C3 Side Exhaust Pipes by CaptainK on Mon 13 Aug 18 10:00
» Kit Kat wrappers don't make good insulation by CaptainK on Mon 13 Aug 18 09:52
» Head Unit Replacement by L88 on Sun 12 Aug 18 13:57
»  by Chris123 on Sun 12 Aug 18 12:24
» 1968 Door Handles by riddyboy on Sat 11 Aug 18 08:54
» Aircon fixed at last! by Daytona Vette on Fri 10 Aug 18 13:29
» Headlight Buckets by kentvette on Fri 10 Aug 18 09:40
» C3 Auto Box Issue Just Developed by Daytona Vette on Thu 09 Aug 18 22:52
» CCCUK West Sussex meeting tonight 9th August by Sea5 on Thu 09 Aug 18 18:27
» History of my vehicle VJD 5G by Bill Riches on Thu 09 Aug 18 16:58
» Borgeson steering box upgrade. by Skeets on Thu 09 Aug 18 13:19
» Cumbria classic (Dalemain House) car show. Sunday 19th August by 666Vette on Thu 09 Aug 18 12:26
» Concours of Elegance by curious bystander on Wed 08 Aug 18 16:47
» What did you do with your Vette today? by MIT on Wed 08 Aug 18 15:31
Removing center clocks console on 1979
Nigelcurry
Wed 07 Feb 18 15:52
Hi all
I am new to this forum and I have recently bought my C3 Coupe,and I was wondering if anyone out there has any info /advice on removing the said console as I want to try and replace the modern radio for the original item that came with the car.It may not sound as good but to my eye it will look better.The car is a 1979 coupe
Many thanks nige
Thu 08 Feb 18 18:06
Re: Removing center clocks console on 1979
Nigel, Unless the console has been "butchered" to fit the new radio, you can perform the swap without removing the console. You can access the rear by removing the two carpet panel pieces on either side of the central tunnel. They are held in by screws, one at the front and one concealed by the seats. Once out, you can see around behind the console quite easily. The radio was originally held in by the knobs and a "brace" at the rear. I was able to release the knobs and carefully push teh radio out backwards, bringing it out from the passenger side, which is more open.
This what a '78 (almost identical to a '79) looks like from the left hand side, with the location of the screws circled.
This is during "work in progress", so ignore some of the connectors and duct tape!
You may find that the wiring has been butchered too. If you need details of the original wiring PM me.
Should you need to remove the console, you'll have to remove the section that includes the gears shift, starting with the arm rest. You can see the fixing at the sides in the photo. Then you'll need to release the gauge cluster. I've never gone that far, so can't tell you how tricky that is - or otherwise!
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
corvetteville
Thu 08 Feb 18 18:27
Hi Nigel, quite a fiddly job. I managed to do it so not impossible! I guess you've looked online/ youtube etc.Its to long to fully describe here but a couple of things that I found out:
Make sure the battery is disconected as the instruments and the ciggy lighter are live all the time.
Remove the side carpeted panels, one of the screws is at the side of the seat so use a thick cloth & a piece of board to press down on the seat to get to it.
On the flat part where the gear shift is, take out the screw going into the trans tunnel, put the shift in the centre and move the console back a little. watch out for the selector indicator(auto) as there is a pin on the stick which operates it.
On the upper part there are screws going vertically and horizontaly into the dash pad.
Be VERY careful with the HVAC control as it is small vacuum pipes and a cable, not an electrical plug on. I was able to unscrew panel from underneath and separate it from the console and leave in situ.
I did this same swop to fit an original radio, which packed up after a few months.I have now purchased a USA1 looks retro but got all mods USB etc. Just got to fit it now!!
hope that helps but please look online/ manual etc. Steve
Nigelcurry
Thu 08 Feb 18 18:55
Great info and quick reply,very helpful
Thanks lads
robashard
Fri 09 Feb 18 20:32
Do you know for a fact that the old radio works?
Might be worth lashing up to test it.
Nigelcurry
Sat 10 Feb 18 10:17
Yep
You’re dead right on that one,think i will get it checked out first,especially when I read corvtteville,cheers guys
Nige
Tue 13 Feb 18 16:21
Probably too late now, but today I came across the instructions on centre console removal that I had received a few years ago from a friend - couldn't locate them before now!
So, he said:-
To remove the centre gauge panel it is best to first remove the console top plate.
The sequence is as follows:
Remove seats (optional, but makes it a lot easier to work on)
Remove 3 screws on each side of carpeted console side panels
Remove 2 screws that attach console plate to e-brake cover (screws go from bottom up)
Remove 2 screw that attach centre console plate to centre gauge panel (screws go from bottom up near radio)
You should now be able to raise the rear of the console plate and slide it back a couple of inches
Remove 2 phillips screws from side of centre gauge panel
Remove 2 phillips screws from top of centre gauge panel
Remove radio knobs and remove nuts from radio
You should now be able to remove the centre gauge panel. Be very careful as there is a light at the top of the centre gauge panel and can catch the dash board and crack it if you are not careful.
After you have pulled the centre gauge panel out a couple of inches you can reach behind it and unplug the wiring before completely removing the panel.
It sounds a lot more complicated than it is. Doing it for the first time you should be able to handle it in about a 1/2 hour.
You may well have "been there, done it" by now, but if not, this may be handy!
Stephen J Irons
NCM Family Member
Apple IS Genisys!
