 Adrian Flux
» Lights by kentvette on Mon 20 Aug 18 18:12
» U-joint replacement by langlj00 on Mon 20 Aug 18 13:03
» Carpets for 56 C1 by vet80y on Mon 20 Aug 18 08:42
» Another 'nail in the coffin' for UK based motorsport by chevrolet on Sat 18 Aug 18 22:00
» Heads/cam by roppa440 on Sat 18 Aug 18 16:15
» Spare wheel light by Nigelcurry on Sat 18 Aug 18 11:34
» 2003 Anniversary Red and Shale Convertible. by Number3 on Fri 17 Aug 18 19:30
» BBCN Regional meet by Nicetie on Thu 16 Aug 18 19:47
» Tyres by roscobbc on Thu 16 Aug 18 13:02
» Drag event... by roppa440 on Thu 16 Aug 18 09:20
» 1989 C4 For Sale by RobBrom on Wed 15 Aug 18 19:56
» C5 Headlamp Adjusters "Golden Rods" by roppa440 on Wed 15 Aug 18 16:31
» Shooting for 1000whp with my C7 @ Top Cats Racing by Sierra on Tue 14 Aug 18 14:19
» C6 European Rear Light Conversion by Daytona Vette on Mon 13 Aug 18 16:42
» Full geo setup needed. by Daytona Vette on Mon 13 Aug 18 10:33
» C3 Side Exhaust Pipes by CaptainK on Mon 13 Aug 18 10:00
» Kit Kat wrappers don't make good insulation by CaptainK on Mon 13 Aug 18 09:52
» Head Unit Replacement by L88 on Sun 12 Aug 18 13:57
»  by Chris123 on Sun 12 Aug 18 12:24
» 1968 Door Handles by riddyboy on Sat 11 Aug 18 08:54
» Aircon fixed at last! by Daytona Vette on Fri 10 Aug 18 13:29
» Headlight Buckets by kentvette on Fri 10 Aug 18 09:40
» C3 Auto Box Issue Just Developed by Daytona Vette on Thu 09 Aug 18 22:52
» CCCUK West Sussex meeting tonight 9th August by Sea5 on Thu 09 Aug 18 18:27
» History of my vehicle VJD 5G by Bill Riches on Thu 09 Aug 18 16:58
» Borgeson steering box upgrade. by Skeets on Thu 09 Aug 18 13:19
» Cumbria classic (Dalemain House) car show. Sunday 19th August by 666Vette on Thu 09 Aug 18 12:26
» Concours of Elegance by curious bystander on Wed 08 Aug 18 16:47
» What did you do with your Vette today? by MIT on Wed 08 Aug 18 15:31
» South Central Regional Meeting for August by Daytona Vette on Wed 08 Aug 18 10:35
Wheel Alignment
Go to page: Previous / 1, 2, 3
Redlevel
Wed 14 Feb 18 16:25
Re: Wheel Alignment
roppa440 wrote (View Post):Daytona Vette wrote (View Post):I only asked the question because I remember many posts ago when you mentioned that you could not get the power down as much as you wanted due to insufficient traction, because if your man has a corner weighting facility he could give you more traction at the rear.
Different game that. To get weight over the rear tyres the centre of gravity of the car needs to shift rearwards at launch on a drag car. To do that you need stiff suspension at the rear and very soft suspension at the front.
Can you still get 90/10 shocks then? Scratchchin
https://www.youtube.com/watch?v=TF9IJljDMfk
Redlevel
Wed 14 Feb 18 16:32
Re: Wheel Alignment
roppa440 wrote (View Post):Oh and I have no traction issues since I bought a pair of sticky Mickey Thompsons to use at the track. Thumbs up
MT's... Yes
I'd love to have a set of these on the back.. Probably lethal in our climate, but what the hell, they look great. And they do them in my size!
https://firstchoicewheelsandtires.com/product/tire/166
roppa440
Wed 14 Feb 18 16:34
Re: Wheel Alignment
stevel98 wrote (View Post):roppa440 wrote (View Post):Daytona Vette wrote (View Post):I only asked the question because I remember many posts ago when you mentioned that you could not get the power down as much as you wanted due to insufficient traction, because if your man has a corner weighting facility he could give you more traction at the rear.
Yes. And sometimes the guys remove the front anti roll bar and fit springs from a lighter engined car.
Normally weight at the wheels is used when adjusting suspension rates at each corner. Adjustable coil overs, spring/traction bar preload and shocks etc. I can't see how adjusting caster, camber, and toe could be effected by wheel weight. I must not know as much about it as I thought? Confused
roppa440
Wed 14 Feb 18 16:38
Re: Wheel Alignment
stevel98 wrote (View Post):roppa440 wrote (View Post):Oh and I have no traction issues since I bought a pair of sticky Mickey Thompsons to use at the track. Thumbs up
MT's... Yes
Apparently these newer Mk2 versions of the tyre are "better" in the wet than the completely lethal previous version. Laughing
roppa440
Wed 14 Feb 18 16:46
Re: Wheel Alignment
Would these bolt on your car at the track Steve? You could borrow them off me at the Mopar Nats. Very Happy
Redlevel
Wed 14 Feb 18 17:43
Re: Wheel Alignment
I wish..
The 84-89 C4 has a unique wheel with a 34-38mm backspace depending on the width (8.5 or 9.5 depending upon what Bubba and Dan had available on the line) so later C4's and C5's won't fit as I think they have a 56mm backspace. The only later GM wheel that will fit an early C4 oddly enough is a ZR1 wheel (11x17) as it has the same 38mm backspace. I could fit C5 wheels, but I'd need spacers and that would push the wheel out of the wheelarch.
My BBS's are in fact off a BMW and 10x16 and 295/50R16 is a perfect size for me.
The biggest issues seem to occur with the '84-'87 models. According to Mike Sweeney of Corvette Wheel Specialist, these wheels were special, with a 36-38mm offset, different from the more common 56mm offset found on '88 through '96 Corvette wheels. "Offset" is the distance between the front of the wheel and where the wheel mounts to the disc-brake rotor; backspacing is measured from this point to the back of the wheel.
To be honest, I doubt if traction would be an issue with my car as Santa Pod's surface, and the traction compound they spray on it seems to bog down a lot of the lesser powered cars especially if they are burning out too. I would guess that my best shot would be to not burn out and let the tyres spin a tad to keep it all going..
roscobbc
Wed 14 Feb 18 19:39
Re: Wheel Alignment
That may change with the new 'concrete' surface being laid for the 2018 season
CCCUK Chairman
Richard J
Fri 16 Feb 18 09:01
Had it's MOT yesterday passed with no Advisories...
I asked them to check, for anything worn, wobbly or look out for dodgy shocks etc. he said didn't find anything and all was well. He drives a Skyline and said he's does it as well, any car with this sort of set up and fat tyres is always going to follow ruts in the road, so maybe it's just me...
Also has new tyers all round now, so I'll see how that goes
