 Adrian Flux
» C7 Configurator by chevrolet on Thu 20 Sep 18 10:10
» C8 is Coming by chevrolet on Thu 20 Sep 18 09:42
» 1989 C4 For Sale by RickyG512 on Thu 20 Sep 18 03:16
» C2 fibreglassing and stuff by L88 on Wed 19 Sep 18 20:50
» Amazing by kentvette on Wed 19 Sep 18 17:10
» What did you do with your Vette today? by FelixP on Wed 19 Sep 18 13:44
» Potential new C5 owner - some basic questions by Le Vette on Tue 18 Sep 18 14:09
» Stunt Driving from 1966 Chevys by Daytona Vette on Tue 18 Sep 18 10:47
» 1966 C2 Corvette Wilwood Master Cylinder by L88 on Mon 17 Sep 18 11:44
» Euro to US tail lights help by julian marshall on Sun 16 Sep 18 11:41
» Mid engined Corvette by Norm on Sat 15 Sep 18 15:19
» C3 Side Exhaust Pipes by CaptainK on Fri 14 Sep 18 13:10
» Presume this is my battery on the way out? :-( by roppa440 on Fri 14 Sep 18 00:02
» [Pics] C6 Corvette's in the UK. by autocolor on Thu 13 Sep 18 19:45
» Resto Vette - or - Modifed Vette by Vetteheadtony on Thu 13 Sep 18 14:16
» T-tops - single / double latch by Vetteheadtony on Thu 13 Sep 18 14:06
» Breakfast meet by VetteWeekend on Wed 12 Sep 18 20:20
» Recommended Restorers by CaptainK on Wed 12 Sep 18 12:12
» 1990 L98 C4 not starting by lovejoy on Tue 11 Sep 18 19:28
» CCCUK West Sussex meeting in September by robbiew on Tue 11 Sep 18 18:34
» South Central Regional Meeting for September by Daytona Vette on Mon 10 Sep 18 12:22
» Spare wheel light by fordpop52 on Mon 10 Sep 18 07:14
» My 01 c5 yellow for sale by Celcius on Sun 09 Sep 18 20:58
» For Sale 09 C6 Corvette by John Lynn on Sun 09 Sep 18 01:25
» C2 Bonnets by L88 on Sat 08 Sep 18 22:56
» BBCN Regional meet by autocolor on Sat 08 Sep 18 09:48
» Interesting Article by philv8 on Fri 07 Sep 18 23:54
» Heads/cam by Fraser on Fri 07 Sep 18 16:26
» Carburettor leaking by Genghis on Fri 07 Sep 18 14:43
» z51 to z06 by The Dark Knight on Fri 07 Sep 18 08:21
front indicator problem can you help?
photoman1963
Mon 19 Mar 18 15:35
on my C1 1962 I my left hand indicators work front and back fine, but right side back flashes and both front indicators flash dimly?? tried cleaning fitting/new bulb.. please assist guys.. its driving me mad!
Mon 19 Mar 18 17:43
Re: front indicator problem can you help?
I can't pretend to be an expert on electrics, especially on a '62. But, it sounds like a dodgy "earth"? Probably worth going over all the connections in the indicator wiring circuit and cleaning them all up?
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
62vette
Addict
Mon 19 Mar 18 20:51
check the indicator mechanism on the coloum aswell
5 USA
Tue 20 Mar 18 19:03
Yes, as Kentvette says this is likely to be an earthing fault.
The first places I'd look are close to lamps which are flashing dimly, especially anything with a "twin filament" bulb.
If you think about it, a twin filament bulb has 3 contacts. For instance a twin filament tail lamp has,
* live for 21 watt filament
* live for 5 watt filament
* ground
So if the bulb's ground contact gets disconnected from the chassis (particularly likely on a fibreglass car!) the current will try to escape through the other filament and off around your wiring until it finds an earth elsewhere. It's because the filaments act as resistors in series with each other that the lamps only illuminate dimly. The same can happen with multiple single filament bulbs depending on the particular car's wiring.
A voltmeter can help you find the fault because if you test at the "live" side of a bulb that's flashing dimly and see a full 12v you know the problem's in the other direction. Similarly if you see low voltage on both sides of a bulb you know you're "somewhere in the middle" and not at the site of the fault.
Good luck!
The Stingray has landed!
roscobbc
Tue 20 Mar 18 23:31
A nice simple and logical explanation - thanks (of behalf of the potentially confused)
CCCUK Chairman
Wed 21 Mar 18 10:10
Agree Ross, a great explanation! I'm sure there are many like me who know what happens, but not why! Rolling Eyes Very Happy
Thanks!
Stephen J Irons
NCM Family Member
Apple IS Genisys!
photoman1963
Sat 24 Mar 18 23:54
many thanks
Yellowshark
Sun 25 Mar 18 15:31
Another thing to look out for is that the earth circuits often join together in places via a connector. These connectors corrode internally and so whilst your particular earth circuit may be physically connected at the light fitting and likewise at the earthing point, the corrosion will break the circuit en route. A good jewellers file will help to clean the internal connections within the connector "box".
