 Ian Allan Motors
» This! by roppa440 on Tue 19 Jun 18 09:30
» Headlamp bulbs by berg944 on Tue 19 Jun 18 09:08
» clicking sound non starting.. only when jump started by L88 on Tue 19 Jun 18 08:24
» STOP PRESS ADDITIONAL BREAKY MEET AAC UK Summer NATS by Dave R on Tue 19 Jun 18 07:36
» c5 alarm fob by Firepit on Mon 18 Jun 18 23:38
» Nationals Questions by JJVETTE on Mon 18 Jun 18 19:50
» 2018 LeMans by kentvette on Mon 18 Jun 18 17:33
» Developing Starter Issue by kentvette on Mon 18 Jun 18 17:31
» 1978 C3 Corvette Silver Anniversary L82 Automatic by geoff917 on Mon 18 Jun 18 15:15
» 8 For 12 by Norm on Mon 18 Jun 18 14:18
» Le Mans 2018 - The Aftermath - (Spoiler Alert!) by kentvette on Mon 18 Jun 18 12:26
» What did you do with your Vette today? by chevrolet on Mon 18 Jun 18 11:24
» New owner by roscobbc on Sun 17 Jun 18 23:20
» FOR SALE - 1966 Corvette Stingray C2 327/300hp 4 Speed Manual Gearbox by veeeight on Sun 17 Jun 18 17:59
» A Beautiful Day For A Car Show by C7KEN on Sun 17 Jun 18 00:13
» Rockcliffe Hall Supercar Show Sat 16th June by C7KEN on Sun 17 Jun 18 00:02
» Kimbolton Country Fayre 8th July by autocolor on Sat 16 Jun 18 20:25
» c5 finally by Invetterate on Sat 16 Jun 18 18:42
» Water pump leak. by MIT on Sat 16 Jun 18 12:03
» c5 repairs and servicing by cloudedmind on Sat 16 Jun 18 09:37
» C5 Z06 for sale by yenko 1969 on Sat 16 Jun 18 08:51
» C5 wanted pref cab or coupe yellow by Celcius on Fri 15 Jun 18 17:56
» Front indicator/side light mod without switchbacks by MIT on Fri 15 Jun 18 17:55
» Breakfast / Evening and end of an era Club Meet Midlands Area by Daytona Vette on Fri 15 Jun 18 13:34
» How many corvettes by L88 on Fri 15 Jun 18 10:58
»  by H3JLV on Thu 14 Jun 18 17:23
» 68-82 Brake Calipers by roscobbc on Thu 14 Jun 18 16:44
» Vulcan Tour 2018 by Bowler on Thu 14 Jun 18 15:02
» Oliver Gavin's old "Company car" (?) still for sale by chevrolet on Thu 14 Jun 18 13:04
» Beautiful E-Car by CaptainK on Thu 14 Jun 18 11:39
MIT
Tue 12 Jun 18 01:48
Hi, Iíd like to sort the front indicators/side lights, as my switchbacks are doing odd things.
Iím going to use the side wing mounted running light as a side indicator, but want to separate the current side/indicator light. But, as it currently flashes the side light, how do I overcome this? Iím happy to drill the current light assy and fit an additional orange lamp for an indicator, using the old lamp as a side light only.
Any ideas?
Cheers, Tim.
Tue 12 Jun 18 09:35
Re: Front indicator/side light mod without switchbacks
It is not the method I used, but quite a few people have added a bulb into teh existing side/indicator lamp unit. I understand that if you drill into it and fit one of those rubber mounted bulb holders for the indicator lamp, the orange will "overpower" the white side light when it flashes, so showing a yellow flasher, but white side light. You just need to separate the wiring from the original bulb holder..
I have included the side marker lamps in the indicator circuit on ours. I was unhappy with showing an amber lamp, in case it was cinfused with an indicator and someone pulled out in front of me!
You need to remove the side marker from the original wiring loop and add a wire from the indicator circuit directly to it, so that it flashes in time (not alternately) with the front indicator. I have only fitted a pretty low powered bulb, as anything too high will speed up the flasher unit too much. By adding, I think, about a 4 or 5 watt bulb, the flasher speed has risen slightly, to within the legal tolerance (in case anyone ever measures that!)
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
MIT
Tue 12 Jun 18 16:38
Thanks for the info, thatís exactly what I was thinking of doing. My switchback flash at different speeds, depending if side or main beam is on.
So I just separate the indicator wire, run it plus an earth to a new 5w lamp, drill the existing sidelight, then also route the indicator wire to the marker, thatís it?
Also, do you know if the front orange marker is a direct replacement for the rear red marker, so I have side rear indicators?
Cheers, tim Thumbs up
MIT
Tue 12 Jun 18 19:45
Iíve just swopped out the front and rear markers, and they are a direct fit. Thumbs up
sublimemike
Tue 12 Jun 18 21:48
My 70 had the orange bulb. I effectively split the the lens by removing the bulb holder, cutting and radiusing a piece of ally then siliconing it in place to allow for a bulb either side. I then wired different coloured LED bulbs each side from the existing bulb holder. I also needed to change the flasher unit for a solid state type. It works well with little bleed.
A phaff to radius the ally but the good thing is I didn't have to chop the wiring up. It would be straight forward to return this to stock if anyone wanted to.
MIT
Wed 13 Jun 18 00:57
Was the flasher unit change due to the use of ledís?
Wed 13 Jun 18 09:38
MIT wrote (View Post):Thanks for the info, thatís exactly what I was thinking of doing. My switchback flash at different speeds, depending if side or main beam is on.
Tim, That sounds about it! The old style flasher unit is a bi-metal unit, so affected by the drain on it. American flashers are always a little slow compared to the UK, so the addition of the 5 W bulb in the side marker speeded it up to the UK spec!
I didn't know that the front and rear side markers were the same, I know they looked it, but I've never tried to swap. (I still run the rears as red side markers) You may need to think about the replacement flasher unit mentioned if you have all those indicators.
Stephen J Irons
NCM Family Member
Apple IS Genisys!
MIT
Wed 13 Jun 18 15:37
Hi, yes, Iíll see how they do when all wired up, and if theyíre not flashing right Iíll swop the flasher. Is there a generic one available in the U.K.?
The side makers fit on opposite sides, so front left fits rear right etc.
Thanks for the help. Thumbs up
sublimemike
Thu 14 Jun 18 22:19
Hi MIT
Yes the flasher was changed for the led's to work . Needed a solid state. I left my rears as is US style. I had a lenient mot tester. Now I don't need an MOT. Im maybe taking a chance but its got to be a real jobs worth I think to ticket me and I didn't want to cut up my loom up.
MIT
Fri 15 Jun 18 17:55
The no mot thing is great, loving the fact itís just the insurance to pay for to have it sitting in the garage! Still surprised thereís no need for an initial mot for imports.
