 ShipMyCar.co.uk
» C8 is Coming by KeithC7 on Wed 19 Sep 18 21:36
» C2 fibreglassing and stuff by L88 on Wed 19 Sep 18 20:50
» C7 Configurator by roscobbc on Wed 19 Sep 18 18:39
» Amazing by kentvette on Wed 19 Sep 18 17:10
» What did you do with your Vette today? by FelixP on Wed 19 Sep 18 13:44
» Potential new C5 owner - some basic questions by Le Vette on Tue 18 Sep 18 14:09
» Stunt Driving from 1966 Chevys by Daytona Vette on Tue 18 Sep 18 10:47
» 1966 C2 Corvette Wilwood Master Cylinder by L88 on Mon 17 Sep 18 11:44
» Euro to US tail lights help by julian marshall on Sun 16 Sep 18 11:41
» Mid engined Corvette by Norm on Sat 15 Sep 18 15:19
» C3 Side Exhaust Pipes by CaptainK on Fri 14 Sep 18 13:10
» Presume this is my battery on the way out? :-( by roppa440 on Fri 14 Sep 18 00:02
» [Pics] C6 Corvette's in the UK. by autocolor on Thu 13 Sep 18 19:45
» Resto Vette - or - Modifed Vette by Vetteheadtony on Thu 13 Sep 18 14:16
» T-tops - single / double latch by Vetteheadtony on Thu 13 Sep 18 14:06
» Breakfast meet by VetteWeekend on Wed 12 Sep 18 20:20
» Recommended Restorers by CaptainK on Wed 12 Sep 18 12:12
» 1990 L98 C4 not starting by lovejoy on Tue 11 Sep 18 19:28
» CCCUK West Sussex meeting in September by robbiew on Tue 11 Sep 18 18:34
» South Central Regional Meeting for September by Daytona Vette on Mon 10 Sep 18 12:22
» Spare wheel light by fordpop52 on Mon 10 Sep 18 07:14
» My 01 c5 yellow for sale by Celcius on Sun 09 Sep 18 20:58
» For Sale 09 C6 Corvette by John Lynn on Sun 09 Sep 18 01:25
» C2 Bonnets by L88 on Sat 08 Sep 18 22:56
» BBCN Regional meet by autocolor on Sat 08 Sep 18 09:48
» Interesting Article by philv8 on Fri 07 Sep 18 23:54
» Heads/cam by Fraser on Fri 07 Sep 18 16:26
» Carburettor leaking by Genghis on Fri 07 Sep 18 14:43
» z51 to z06 by The Dark Knight on Fri 07 Sep 18 08:21
» End of an Era by Firepit on Thu 06 Sep 18 23:39
Spare tyre
Dellb
Sun 24 Jun 18 12:48
Spare tyre
Hi All
Continuing with the thread on tyres, I have moved onto the spare. My spare is basically a piece of bald rubber attached to a pile of rust.
The rime has an OD of 16 inches, and is 6 inches wide, and I intend to have it blasted.
The only marks on the tyre are Remould, and 6 : 40 : 15 which does not mean a lot to me.
Can anybody advise on the size of space saver I need. I presume the normal tyres (deflated) will not fit.
Also has any body tried the sealer and pump kits?
Derek L G
curious bystander
Sun 24 Jun 18 18:01
Re: Spare tyre
I replaced the spare on mine last year. It had never been used but after nearly 40 years I assumed it wouldn't be safe.
My local tyre place found me a van tyre the same size - fits under the car perfectly fully inflated.
195R15 Autogrip Vanmax 106/104R 75 with valve and balanced
Are you sure your diameter is 16"? You say the old tyre was 6 : 40 : 15
Does the 15 refer to the diameter?
79 L82 Auto
Having a lot of bhp is all very well, but on these forums it's torque that counts
Club Secretary
roscobbc
Sun 24 Jun 18 18:47
Re: Spare tyre
Rim for 15" tyre will measure diameter of sealing surface - 16" will probably be across total wheel diameter?
CCCUK Chairman
Dellb
Sun 24 Jun 18 20:52
Re: Spare tyre
The 16 inch measurement is the outside diameter from rim to rim.
Thanks for the info for a space saver.
I am still toying with the idea of having a sealing kit and pump, because I can then also fit my jump pack into the same space.
Derek L G
curious bystander
Sun 24 Jun 18 21:18
Re: Spare tyre
Ross is correct. 16 inch across = 15 tyre size
I would have thought a deflated tyre takes up much the same room as an inflated one.
Your jump pack could fit in the hollow of the wheel perhaps?
79 L82 Auto
Club Secretary
Grahamred70
Sat 30 Jun 18 10:11
I have OKO tyre sealant in all my tyres but would advise carrying a compressor to top up as when I removed the large screw from a tyre on my golf I had to keep topping it up for a week or so until it finally sealed but it was a large screw!
Graham
Graham, red 1970 convertible 350
Sat 30 Jun 18 10:34
Re: Spare tyre
curious bystander wrote (View Post):I replaced the spare on mine last year. It had never been used but after nearly 40 years I assumed it wouldn't be safe.
Good idea to change the spare, mine all looks good even had the wheel yellow powder coated, never gave a thought to the 40 year old rubber - start of a new list.
Cheers.
Barry - Daytona Vette
Sat 30 Jun 18 10:39
Grahamred70 wrote (View Post):I have OKO tyre sealant in all my tyres but would advise carrying a compressor to top up as when I removed the large screw from a tyre on my golf I had to keep topping it up for a week or so until it finally sealed but it was a large screw!
Graham
Tyre sealant only works for small holes like a screw or a nail, which would be a slow puncture anyway.
If you have an instant blowout with max deflation the silicone will not seal it - ask me how I know.
