 Ian Allan Motors
» BBCN Region CHRISTMAS Dinner by Nicetie on Wed 21 Nov 18 12:39
» Northeast regional, Breakfast Meeting Sun 9th December by Wacjac on Mon 19 Nov 18 22:00
» Replacement head unit for US spec C6 by c6pete on Mon 19 Nov 18 18:05
» NEC Classic Car Show - Birmingham by Chuffer on Mon 19 Nov 18 14:28
» Best Advertising Place?? by roscobbc on Mon 19 Nov 18 12:01
» 1982 Collectors Edition by kentvette on Mon 19 Nov 18 11:00
» C3 wanted by Jimbo64 on Mon 19 Nov 18 07:01
» C6 LED halos by Fraser on Sun 18 Nov 18 16:34
» 2007 Indianapolis 500 Pace car For Sale by Atomic Corvette 22 on Sun 18 Nov 18 12:44
» Heads/cam by Fraser on Sun 18 Nov 18 11:42
» 1978 C3 Corvette Silver Anniversary L82 Automatic by J Broom on Sun 18 Nov 18 10:01
» rear dampers by Norm on Sat 17 Nov 18 22:35
» My Ideal Vette by Redlevel on Sat 17 Nov 18 22:17
» 2007 C6 ZO6, Manual. by jackconcord on Fri 16 Nov 18 15:44
» 1986 c4 coupe silver/brown for sale by chevrolet on Fri 16 Nov 18 12:48
» C3 roof panel by curious bystander on Thu 15 Nov 18 15:56
» 2017 Tapas and Rioja Tour by kentvette on Tue 13 Nov 18 11:13
» C5 Z06 for sale (2002) by roscobbc on Tue 13 Nov 18 00:50
» Anyone know anything about this C5??? by roppa440 on Mon 12 Nov 18 11:38
» 94 In A 45 by kentvette on Sun 11 Nov 18 18:32
» Wanted.. Convertible C6 by Monty`s vette on Sat 10 Nov 18 16:10
» C6 Grand Sport Convertible by Monty`s vette on Sat 10 Nov 18 16:00
» My new C3 pace car by Nosheruk on Sat 10 Nov 18 12:04
» C3 jack, brace, spare tub bolts by MIT on Fri 09 Nov 18 21:03
» WTB: C6 Auto Coupe For Sale? by Atomic UK on Fri 09 Nov 18 02:27
» Spring Compressor by L88 on Thu 08 Nov 18 22:01
» Refurbishing wheels, factory finish by RumblinRon on Thu 08 Nov 18 13:45
» Visual differences US and Export models? by BlackZeD on Thu 08 Nov 18 13:28
» Help with newly acquired 72 350 Auto by Jimbo64 on Wed 07 Nov 18 16:52
» Coilovers by Daytona Vette on Wed 07 Nov 18 11:10
Readily available battery..
Ddave
Sat 07 Jul 18 08:51
Hi all.. happy heat wave!
10 year old optima red top won't hold a charge... so I'd appreciate views on the best readily available battery options for a big block c3... e.g., something I could pop to eurocarparts tomorrow to pick up... or could order online and have delivered early next week?
Many thanks for thoughts
David
roscobbc
Sat 07 Jul 18 09:06
Re: Readily available battery..
Ddave wrote (View Post):Hi all.. happy heat wave!
David
Just don't see the point in buying another Optima battery - you've just proved the point 10 year life (against a probable 7/8 year life for conventional battery) - elevated cost for just a couple more years Doh I'd simply buy the best quality standard type battery at half to two thirds the cost and budget on replacing a little more frequently if keeping the car. I'm on my third battery in 18 years Thumbs up
CCCUK Chairman
Ddave
Sat 07 Jul 18 10:06
Is cca an issue? The highest i see in most commonly available over the counter battery is about 600... a long way off the optima (800) and below what most of the u.s folks call ''minimum'?
roscobbc
Sat 07 Jul 18 11:09
I'll check the CCA on mine later - I think it's 660. More than capable of turning over nearly 500 cu in's at 10.5 c/r for quite a long time. On cold starts I always turn over over for up to 10 seconds or so waiting until oil pressure shows before pumping carb to start.
CCCUK Chairman
MIT
Sat 07 Jul 18 19:14
I put a Halfords HCB096 battery in mine, converted to top post. 680 crank amps. With trade card was £80.
Tim.
74 coupe.
Ddave
Sat 07 Jul 18 19:48
And that fits ok?
I've only been looking at 075s,so fas, as wasn't convinced bigger was,a straight fit...
MIT
Sat 07 Jul 18 20:34
Yep, I put quick release fittings on as well.
Tim.
74 coupe.
MIT
Sat 07 Jul 18 20:37
Thatís assuming my 74 coupe has the same size battery storage.
Tim.
74 coupe.
Ddave
Sat 07 Jul 18 20:58
Should be.. nice, thanks..
roscobbc
Sat 07 Jul 18 22:27
Mine's a '68 - I believe a '086' is same overall size as 075 - but taller)
Here we go
And an 'essential' addition in any 'glass' car
CCCUK Chairman
