 ShipMyCar.co.uk
» 2009 C6 LS3 wing mirrors by BlackZeD on Thu 18 Oct 18 22:15
» A trio of C2 owners. by L88 on Thu 18 Oct 18 21:56
» Silverstone Classic 2019 by curious bystander on Thu 18 Oct 18 20:01
» AC belt by corvetteville on Thu 18 Oct 18 17:55
» Spec lists by kentvette on Thu 18 Oct 18 16:41
» Birdcage repair by johng on Thu 18 Oct 18 12:49
» Strange tacho by kentvette on Thu 18 Oct 18 12:44
» What did you do with your Vette today? by FIVE RED on Thu 18 Oct 18 12:25
» C3 Hooker Side Pipe headers by icandycanvas on Wed 17 Oct 18 16:18
» C3 Side Exhaust Pipes by icandycanvas on Tue 16 Oct 18 20:52
» Wiper actuator on a 69L by Ddave on Tue 16 Oct 18 18:36
» Le Mans 2019 by kentvette on Tue 16 Oct 18 17:55
» Tips by CaptainK on Tue 16 Oct 18 13:44
» Im interested in a C5 Z06 (this time next year) by Benbay001 on Tue 16 Oct 18 12:55
» Engine cutting out after firing up by Firepit on Tue 16 Oct 18 09:19
» Thinking About Hanging Them Up....... by Norm on Mon 15 Oct 18 15:44
» BBCN Regional meet by Nicetie on Mon 15 Oct 18 12:57
» C5 O2 sensor code?? by roppa440 on Mon 15 Oct 18 08:45
» C2 fibreglassing and prep. by L88 on Sun 14 Oct 18 17:16
» Road Atlanta this weekend. by UkBeancounter on Sun 14 Oct 18 14:29
» New Series of Wheeler Dealers an 02 Z06?? by dex99 on Sun 14 Oct 18 12:02
» Door removal on 79 coupe by Nigelcurry on Sat 13 Oct 18 20:01
» American Day - Museum of Power Essex by Forrest Gump on Sat 13 Oct 18 17:44
» C5 Performance Projects - book by robbiew on Fri 12 Oct 18 21:19
» Help with newly acquired 72 350 Auto by Jimbo64 on Fri 12 Oct 18 18:15
» speed bleeders by Grahamred70 on Fri 12 Oct 18 16:17
» South Central Regional Meeting and Midlands-ish Breakfast Club - October by Daytona Vette on Fri 12 Oct 18 10:44
» Essex Regional meeting by roscobbc on Fri 12 Oct 18 08:36
» 1972 Washer bottle wanted by Vetteheadtony on Thu 11 Oct 18 22:48
» Vette Hire In The U.S. by 86vetteman on Thu 11 Oct 18 20:33
New member, new c3 on order!
Go to page: Previous / 1, 2, 3, 4, 5 / Next
MIT
Wed 11 Jul 18 12:48
Re: New member, new c3 on order!
Cheers guys.
Iíll take a few pics when I do the Borgeson install, doesnít look that bad a job, providing the column collapses ok. Hoping to be able to leave it in situe but will see. My concern at the mo is the stainless headers, Iíve heard they can interfere with the slightly larger box, and people effectively putting a dent in them to clear with a hammer! Doh
Tim.
74 coupe.
Thu 12 Jul 18 10:50
Tim
I suspect that you "enjoy" the headers, but we used to have them on our '78. After enduring the head produced inside inside the car, plus the noise, when the opportunity arose to obtain a set of the stock manifolds we jumped at the chance! The difference was amazing - much quieter inside the car, and a whole lot cooler!
I know you have a fancy cam etc, so maybe the headers are part of the package, but its nota route I'd go down again, certainly not on a "regular street car".
Yes, photos of the Borgenson install will be interesting - good luck!
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
Thu 12 Jul 18 16:15
MIT wrote (View Post):Cheers guys.
Get a Dolly the shape of the required dent and hit the Dolly, you may want to remove the Header first rather than cause stress damage in other areas (joints / threads etc).
Barry - Daytona Vette
Thu 12 Jul 18 16:23
[quote="kentvette";p="149812"]Tim
I have a 78 Big block with Headers and I do not have a heat problem, maybe it is just me and what I am used to, but then in the recent heatwave here, I am using the AC, but then that is the same for the daily driver.
If you ceramic coat the inside of Headers that will reduce the transmission of heat, especially good if you are running chrome Headers as it stops the blueing of the chrome.
roscobbc
Thu 12 Jul 18 17:43
Despite the detrimental remarks that people make about headers - specifically the heat generated - my experience differs.......when I installed a set of 'small' tube Hedman headers on my '68 427 the engine bay and coolant temperature actually reduced a little. Much later when I installed the modded 489, using the same 1 7/8" headers it was much the same. I'm not saying the car was cool inside - because it certainly wasn't (and isn't now) I 'cook' in the car during summer trips - removal of T tops and rear window is essential for every trip. A much later change to 2 1/4" ceramic coated Hooker Super Comps hasn't really changed anything (other than upper-end performance) - they are certainly have a cooler case temperature than uncoated headers (still hot in relative terms though) they don't make that 'pinging' sound that is characteristic of tube headers. I was pleasantly surprised how well the car coped with the 30 degree temperature of the Nats weekend.
I define 'hot' as sitting in the car in a traffic jam - looking forward through the windscreen at distant objects and it's like one of those mirage scenes in a desert - everything you look at is distorted and 'shimmering' - when you eventually move off the heat that then blows back from under the dashboard is sufficient to make you eyes 'water' Yes
CCCUK Chairman
MIT
Thu 12 Jul 18 21:37
My headers are ceramic coated, and my concern was damaging this finish if I had to shape them. But might not be necessary.
Heat wise, I went on a 20 mile trip when it was hot, and didnít notice any problems in the car, but Iíve not sat in traffic yet.
The noise is a bit too much for me, a real drone in the car at lower revs, Iím going to pop into my local custom exhaust shop and change the Flowmaster back boxes for something less dramatic at some point. Iím going to the show at north Weald in a week so will see how it goes, and what mpg I get!
Tim.
74 coupe.
roscobbc
Thu 12 Jul 18 23:40
MIT wrote (View Post):My headers are ceramic coated, and my concern was damaging this finish if I had to shape them. But might not be necessary.
A good number of us Essex boys should be there - I used Jetex mufflers on mine a number of years ago - were very quiet on a light throttle - and nice and strident without being too loud when pushing-on.
https://www.jetex.co.uk/custom-exhaust-parts/
Rule is to select longest/largest diameter casing to keep noise down. I selected one that was more or less the same size as stock.
CCCUK Chairman
MIT
Fri 13 Jul 18 16:50
Cheers, Iíll look into that.
Do I need to pay up front for the show, or on the door?
Tim.
74 coupe.
Regional Rep
Sat 14 Jul 18 12:06
MIT wrote (View Post):Do I need to pay up front for the show, or on the door?
Hi Tim, it's pay at the gate. I'll be in touch during the week re times.
Hopefully this weather will hold out.
Andy
Blue '75
MIT
Tue 24 Jul 18 21:06
Well, met a bunch of the guys at my first show on Sunday, the damn yankies at North Wealds. Had a great time, and what a decent bunch you all are! Looking forward to the next one.
Picture courtesy of Andrew.
Tim.
74 coupe.
