 Lancaster Insurance
» Indicator/hazards switch by vet80y on Sun 20 Jan 19 18:56
» New Unexpected Owner of this C3!! by Lomaximus on Sun 20 Jan 19 18:48
» Help with newly acquired 72 350 Auto by Grahamred70 on Sun 20 Jan 19 16:53
» CCCUK Website and Forum by Jack Cooper on Sun 20 Jan 19 11:39
» Drifting your Corvette by Fishy Dave on Sun 20 Jan 19 11:11
» This seems very cheap for a C7 by GCVETTE on Sat 19 Jan 19 15:10
» What did you do with your Vette today? by Nick B on Sat 19 Jan 19 09:35
» Any interest in used Z06 suspension? by Ph300zx on Wed 16 Jan 19 22:44
Carburettor leaking
antonyba
New Comer
Sun 02 Sep 18 21:10
Carburettor leaking Message Icon
My 1959 Corvette has recently started to leak petrol from the carburettor linkage rods its a twin 4 bore carb
I live in Hampshire and desperately need a good mechanic who nows his way round one of these
Please help
Antony
antony barton
Chris Sale
Mon 03 Sep 18 16:13
Re: Carburettor leaking
Hi Antony,
Assuming that you still have the original carburettors, they should be Carter WCFBs. There is a good Service Manual for WCFBs here:
https://carbkitsource.com/carbs/tech/Carter/wcfb-service.pdf
Best,
Chris Sale
CCCUK 436
NCRS 11971
'64 Coupe
antonyba
New Comer
Mon 03 Sep 18 22:55
Thanks so much
I will let you know how I get on
antony barton
roppa440
Tue 04 Sep 18 17:19
It might just be muck in the fuel bowl stopping the needles seating.
Genghis
Fri 07 Sep 18 13:43
This happens quite regularly on my 1969 C3.
Fuel keeps leaking from the carb rods, and the engine runs too rich, and it just dies at low revs due to flooding.
If it is the same issue as mine, it is a really easy fix.
Crap/rust from the fuel tank gets sucked through the system and blocks the manual 'float' at the back of the carb. the needles can't reset and get jammed open, overfeeding petrol
Expensive total fix = strip and reseal your fuel tank, or buy a new one.
Medium fix = invest in an aftermarket very good fuel filter which will catch the particles before they reach the carb
Cheap fix = take of side of carb carefully (as there are small parts in there. Clean it all and put it back. takes about twenty minutes. All you need is a ratchet, a screwdriver and some tissue/cloth. DO NOT do this over the engine in case one of the small parts drops in. Just do this every time it happens.
Good luck!
If God intended us to be vegetarians, why are animals made of meat ?
