 ShipMyCar.co.uk
» CCCUK West Sussex Xmas meeting tonight 13th December by Sea5 on Thu 13 Dec 18 17:14
» South Central Midlands Supper Club Meet by Daytona Vette on Thu 13 Dec 18 16:46
» 2002 C5 Coupe by roppa440 on Thu 13 Dec 18 15:49
» 2007 C6 Z51 BX08 ECV - Any Former Owners Here? by Atomic UK on Thu 13 Dec 18 14:25
» Outer Door Handles by kentvette on Thu 13 Dec 18 11:13
» How Many Miles Does Your Corvette Get Driven? by Skoosh1970 on Thu 13 Dec 18 11:08
» AMERICAN SPEEDFEST 7 on 1st - 2nd JUNE 2019 by Fishy Dave on Thu 13 Dec 18 08:52
» wet carpets by stephano on Wed 12 Dec 18 22:51
» Once A Vette Head - Always A Vette Head! by Rich on Wed 12 Dec 18 13:57
» What did you do with your Vette today? by roscobbc on Wed 12 Dec 18 12:09
» Insurance recommenations by Rich on Wed 12 Dec 18 07:54
» Website Copy and Paste by Rich on Wed 12 Dec 18 07:51
» Trimmer/upholsterer by Forrest Gump on Tue 11 Dec 18 20:06
» Bloodhound SSC by Atomic UK on Mon 10 Dec 18 13:04
» Spotted C2 by Jan25 on Mon 10 Dec 18 09:01
» Help with newly acquired 72 350 Auto by Jimbo64 on Sun 09 Dec 18 21:33
» Facebook page by fat_jogger on Sun 09 Dec 18 19:36
» O.m.g. by Redlevel on Sun 09 Dec 18 17:35
» C5 Harmonic balancer wobbling! by therabster on Sat 08 Dec 18 22:02
» My C8 Grump by Vetteheadtony on Sat 08 Dec 18 13:05
» C7 Z06 by MShaky on Fri 07 Dec 18 15:17
» Replacement head unit for US spec C6 by Young Bill on Fri 07 Dec 18 10:10
» Kelsey Hayes Aluminum Wheels by Daytona Vette on Thu 06 Dec 18 01:05
» Thames Vally Region trip to Studio 434 by Nicetie on Wed 05 Dec 18 22:33
» C6 LED halos by autocolor on Wed 05 Dec 18 19:20
» Another day, another Mid-Engine Corvette thread by Norm on Wed 05 Dec 18 19:05
» 2007 C6 ZO6, Manual. by Fraser on Wed 05 Dec 18 15:50
» 2019 Nationals by curious bystander on Wed 05 Dec 18 11:15
» Replacing Fuel Filter by robbiew on Tue 04 Dec 18 18:28
» South Central Breakfast Club by Daytona Vette on Mon 03 Dec 18 12:52
rear dampers
Fri 16 Nov 18 20:45
rear dampers
Tried taking my rear dampers off today. No problem with the top fixing or removing the nut at the bottom, but can't get either damper off the stud at the bottom. Tried levering with a big bar but I guess the inner sleeve of the bush is rusted to the stud. Is there a method to do this, or is it just a case of more brute force needed?
Norm
Fri 16 Nov 18 23:20
Re: rear dampers
Check this out, may help.
https://www.youtube.com/watch?v=3jGzlh9qbp8
From Delmarva, USA
NCM Member
2016 Z06 Coupe A8 Black, Red & Ebony Int.
1975 L82 A3 T-Top, Bright Blue, Custom Blue & Black Interior (NCRS for me, Not Correctly Restored Stingray)
Previously Owned Vettes: '65, '97, '01, '10, '14
Sat 17 Nov 18 08:26
Re: rear dampers
Norm, did you mean to paste in this link? It will be useful when I come to remove the rear spring, but I can't see any mention of the shock absorbers in it.
John
Sat 17 Nov 18 13:07
Re: rear dampers
John
Not sure how you are doing this, but It helps to have the trailing arm jacked up a little to put the shock into something like the position it is in on the road. you should them be able to pull the top mounting bolt out towards you. Then you can turn the shock out of top mounting "slot", allowing you to get more "wiggle" on it. At the very least, the inner rubber bush should come free and that would allow the shock to come off. You can then decide what to do about the seized sleeve, if that is the case. It's almost impossible to get the shock to come off the lower mount if it is still attached at the top in any event.
Alternatively, if it is indeed seized, you may as well change the shock mount. That way you don't even need to get the old shock off the mount.
Regardless of what anyone says, you WILL need a Shock Mount Removing Tool for this job, (Corvette Kingdom will have one) but once you have one it's not as hard as it is sometimes told - you do just need a lot of WD40 first and a very big hammer! It all sounds a bit "bubba", but it does work.
In reality, if you doing the shocks, a new mount is probably a good idea.
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
Norm
Sat 17 Nov 18 14:58
Re: rear dampers
John, not sure what you were going for with the word damper, but kentvette's response ref. shocks is pretty much on the mark. Once that rust settles in, it's one big PITA to replace. Good luck with endeavor.
From Delmarva, USA
NCM Member
Sat 17 Nov 18 16:36
Re: rear dampers
Thanks to both of you. I've got the top of the dampers (or shock absorbers in the US http://www.corvetteclub.org.uk/images/smiles/icon_smile.gif) free, so sounds like I either need to just apply more force or else cut through the ring at the bottom of the shock absorber. I'll be doing a complete suspension overhaul and I think the shocks will need replacing anyway. They certainly will if I can't get them off without destroying the rubber.
Sat 17 Nov 18 16:37
Re: rear dampers
So how do you insert a smiley face anyway?
Sat 17 Nov 18 17:40
Re: rear dampers
John
If you're doing a complete overhaul then definitely put new Shock Mounts on it! There really is no point faffing around with the old ones, which have to come off anyway if you're removing the tie rods..... That way you'll get nice new mounts, plus the new nuts that go on them.
You should also receive new rubbers when you buy new shocks as part of the "package" so just get the shock mounts off and be done with it! Very Happy
Don't forget, when you bolt everything back on, the split pins for the large nut that holds the shock mount on, go in from the bottom - a sure sign of a "proper job"!
PS - smiley faces? Just click on the one you want on the left of the "reply box". It will probably go to the end of your text.. Thumbs up
Stephen J Irons
NCM Family Member
Apple IS Genisys!
Redlevel
Sat 17 Nov 18 22:28
Re: rear dampers
Norm wrote (View Post):John, not sure what you were going for with the word damper, but kentvette's response ref. shocks is pretty much on the mark. Once that rust settles in, it's one big PITA to replace. Good luck with endeavor.
Shocks are absorbed by the spring, and the spring's resultant oscillations are controlled (dampened) by the dampers. Thats why we refer to them as such.
Try driving a car with the dampers removed and you'll understand this only too well.
Norm
Sat 17 Nov 18 22:35
Re: rear dampers
Redlevel wrote (View Post):Norm wrote (View Post):John, not sure what you were going for with the word damper, but kentvette's response ref. shocks is pretty much on the mark. Once that rust settles in, it's one big PITA to replace. Good luck with endeavor.
Oh you mean driving without shocks? I've done that for sh!ts & grins, quite a bouncy ride.......... Very Happy
From Delmarva, USA
NCM Member
