CCCUK logo
 Ian Allan Motors
Website Control
Recent threads
New Forum Posts
» What did you do with your Vette today? by Vetteheadtony on Tue 22 Jan 19 11:39
» New Unexpected Owner of this C3!! by L88 on Tue 22 Jan 19 10:59
» Power Windows by roscobbc on Mon 21 Jan 19 20:50
» CCCUK Website and Forum by roscobbc on Mon 21 Jan 19 20:47
» C6 Z06 Flat battery by Tattooboy on Mon 21 Jan 19 20:03
» This seems very cheap for a C7 by roscobbc on Mon 21 Jan 19 17:28
C6 torque tube
Reply to topic
Author
Message
mach2andy
Club Member
Sat 22 Apr 17 09:27
C6 torque tube
Does anyone know how common a problem the torque tube failure is on a C6? To be mechanically precise, I think it's a failure of the prop shaft bearings inside the torque tube which seems to start with a tinkling rattling noise? Does it affect both manual and auto cars? Low mileage/high mileage cars? Does it happen when the car is hot, when it's cold or does temperature have no affect? Has anyone out there had to have one fixed, or indeed fixed one themselves? Was there ever a GM recall on this issue? Any thoughts or experiences would be appreciated.
BlackZeD
Club Member
Sat 22 Apr 17 13:51
Re: C6 torque tube
I've heard reports of the slave cylinder failing causing a grinding noise.
Also the rubber joining parts from the engine to drive shaft fail as well.
You haven't said what your fault actually is.
Dave.
mach2andy
Club Member
Sat 22 Apr 17 14:55
Re: C6 torque tube
Hi Dave
I don't have a C6, but I'm thinking of buying one. But I am a little put off by what appears to be a not uncommon problem which I think was also an issue with the C5? So I suppose I'm just trying to get a feel for how common or not it is?
Nogbad
Club Member
Sat 22 Apr 17 15:42
Re: C6 torque tube
I've had 2 C6's over about 6 years and a C5 for 3 years or more and never had a problem with transmission,or anything else for that matter. In my opinion they are pretty much bullet proof !
Red C7 Stingray
AC Cobra (Dax) 5.7 Chevy with straight through sidepipes = LOUD! Soon to be stroked to 6.3
BlackZeD
Club Member
Sat 22 Apr 17 16:07
Re: C6 torque tube
As Nogbad says above, ive had 2 C5s and now have a C6 Z06, I haven't had any
problems with the drive train at all.
The ones I mentioned are the only ones that I know about.
You could try searching the corvetteforum.com for more info.
In my opinion some guys regularly have up to 600+ horsepower through
them and don't mention any drivetrain upgrades due to failing etc.
Dave.
5 USA
Club Member
Sat 22 Apr 17 16:27
Re: C6 torque tube
mach2andy wrote (View Post):I think it's a failure of the prop shaft bearings inside the torque tube which seems to start with a tinkling rattling noise?
I've never heard of that one.
My C5 auto certainly had a slight rattle from the torque tube throughout its life - I owned the car for 12 years from new. The rattle was typically audible in neutral or in other "no load" conditions and is just a feature of the car's mechanical layout. My belief, rightly or wrongly, was that the rattle came from joints rather than bearings.
For what it's worth my understanding is that in manual cars the clutch is attached to the front-mounted engine whereas in auto's the torque converter is attached to the rear-mounted transmission. This may clearly make a difference to if/when the torque tube rattles.
"The driveshaft is held in place by bearings inside the torque tube. In 2001, a stronger driveshaft was put into all C5s to cope with the higher performance of the Z06. The driveshaft was changed from a metal matrix composite to aluminum alloy 6061, and was increased in diameter from 55 mm to 63 mm."
http://www.chevydiy.com/c5-corvette-performance-driveline-gu...
The Stingray has landed!
CUSTOM EXOTICS
Addict
Sat 22 Apr 17 22:15
Re: C6 torque tube
Huuuum not unheard of we have just pulled the transfer out of our manual c5 due to vibrations and being told prob the rubber doughnuts, they looked perfect when remove, we replaced with the 6 shooter poly items but vibration still remained pulled transfer again after first road test due to loss of clutch turns out the performance clutch with 7000 miles on it had let go ordered new clutch through monkfish performance but due to larger size of this as really designed for the marrano we had to drop the bell housing, thank God as we discovered it was badly split. But bit of chicken and egg here did bell housing cause clutch or clutch cause bell housing anyway this is only time I have seen or heard of this and very very unlikely you will ever have prob with the proper or doughnuts !!!!! Ps ours is over 600hp with the supercharger hope this puts your mind at rest. Pps even the gearbox and different internals were mint as we did the gasgets on them both at same time !
nothing to prove
C6NL
Club Member
Wed 26 Apr 17 12:35
Re: C6 torque tube
I had a rattle on my car at 130.000 Km which turned out to be the Clutch Pilot Bearing. Because replacing the part means taking halve the car apart I decided to replace all the clutch components, although not worn, clutch slave cylinder, and the three bearings in the torque tube. From the three bearings in the torque tube one was making some noise when you turn it in your hands, it didn't while it was installed, the other two were in good shape. So I would say that a torque tube failure is not a common failure for the C6.
Callaway Honker
Ported throttle body
Ported intake
Crane Cams 1.8 ratio rockers
Kooks Jet Hot coated headers
Pfadt Johnny O'Connel shocks
Hotchkis sway bars
Diablosport Trinity with custom tune
Brian Tooley Racing valve spring kit
When launching and stopping this beast, passengers may experience temporary black-out due to "G" forces
caused by acceleration and deceleration speeds faster than what they are normally accustomed to.
craigyboy
Club Member
Thu 27 Apr 17 09:36
Re: C6 torque tube
Unless you are doing very hard launches at a drag strip all the time you won't have any issues with the torque tube at all
Reply to topic
Permissions
