CCCUK logo
 ShipMyCar.co.uk
Website Control
Recent threads
New Forum Posts
» What did you do with your Vette today? by Vetteheadtony on Tue 22 Jan 19 11:39
» New Unexpected Owner of this C3!! by L88 on Tue 22 Jan 19 10:59
» Power Windows by roscobbc on Mon 21 Jan 19 20:50
» CCCUK Website and Forum by roscobbc on Mon 21 Jan 19 20:47
» C6 Z06 Flat battery by Tattooboy on Mon 21 Jan 19 20:03
» This seems very cheap for a C7 by roscobbc on Mon 21 Jan 19 17:28
C6 Active Handling System
Go to page: 1, 2 / Next
Reply to topic
Author
Message
Graham
Club Member
Sat 08 Jul 17 10:56
I have a message come up on my dashboard saying 'Service Active Handling System' and the Traction Control symbol comes on.
Does anyone know how you actually service this system please?
Graham
1982 Corvette
2006 Corvette
1991 Honda NSX
FranV8
Awww... join the CCCUK!
Sun 09 Jul 17 13:36
Unfortunately it doesn't mean routinely service an item, it's found a fault somewhere (likely a sensor or connection) and needs further diagnosis.
It should have set a trouble code. Is this C5 or 6?
1995 Corvette LT1 6-Speed Coupe
2007 Honda UFO
Previous
1986 Corvette Z51 Coupe
FranV8
Sun 09 Jul 17 15:26
I should have read this properly, on a C6 it's not as easy tobget codes out of. In fact, I think a normal code reader might struggle as OBD2 only required the manufacturers to make powertrain codes generically available, it may need scanning with a Tech 2 or equivalent...
2007 Honda UFO
Previous
roppa440
Club Member
Mon 10 Jul 17 11:19
Re: C6 Active Handling System
If you are lucky it is a wheel sensor or a bad connection.
If you are unlucky it is the EBCM (Electronic Brake Control Module) which is probably going to cost you 1k to replace.
Identify which bit is the EBCM in your engine bay. Drivers side between the engine and radiator. It has a lot of steel brake pipes going in and out of it. On the side of it there will be a wiring harness plugged in. Clean the pins on the connector and cross your fingers that sorts it.
Graham
Club Member
Mon 10 Jul 17 17:32
Well, the message has disappeared but I don't trust it. It'll be back.
I've looked under the hood and found the module and connector. Absolutely impossible to get at. Maybe I'll look from underneath and see if I can sneak a hand in.
Graham
Graham
1982 Corvette
2006 Corvette
1991 Honda NSX
C6NL
Club Member
Mon 10 Jul 17 18:20
Steering wheel position sensor was the culprit on mine
Callaway Honker
Ported throttle body
Ported intake
Crane Cams 1.8 ratio rockers
Kooks Jet Hot coated headers
Pfadt Johnny O'Connel shocks
Hotchkis sway bars
Diablosport Trinity with custom tune
Brian Tooley Racing valve spring kit
When launching and stopping this beast, passengers may experience temporary black-out due to "G" forces
caused by acceleration and deceleration speeds faster than what they are normally accustomed to.
roppa440
Club Member
Mon 10 Jul 17 22:07
C6NL wrote (View Post):Steering wheel position sensor was the culprit on mine
Oh yes. I have had that one before too. Forgot about that one. That confuses the active handling. It's a cheap part too. Both in price and quality.
C6NL
Club Member
Tue 11 Jul 17 05:15
roppa440 wrote (View Post):C6NL wrote (View Post):Steering wheel position sensor was the culprit on mine
At least with our cars the parts are cheap, and cheaply made, with a Ferrari the parts would be cheaply made and hugely expensive Rofl
Fred
Callaway Honker
Ported intake
Hotchkis sway bars
craigyboy
Club Member
Fri 14 Jul 17 11:31
you will need to codes read... I doubt it be the steering wheel position sensor.
The reason why a steering wheel position sensor could cure the problem is down to the plug that connects to it . The telescopic steering pulls on the wiring loom that connects to the SWPS and this causes fretting that can cause this issue.
Easiest is to buy a small comb that plugs into the plug that connects to the SWPS. and it's a GM part fix I can supply one if needed
The active handling service code is only stored if it stays on when you restart the car. It could also be the ABS pressure valve
It wont be the EBCM
I do have a tech 2 . not sure what area you live?
it could also just be dirty contacts on each speed sensor. Unplug each one and squirt some contact cleeaner and reconnect
BlackZeD
Club Member
Fri 14 Jul 17 12:08
You could get one of those OBDII readers that plugs into the port
under the steering wheel and use an App such as Torque Pro to read them.
Would be cheaper than a finding someone with a Tech 2 possibly.
Reply to topic
Permissions
