CCCUK logo
 ShipMyCar.co.uk
Website Control
Recent threads
New Forum Posts
» Heads/cam by Fraser on Tue 14 Aug 18 21:40
» Drag event... by Pinhead on Tue 14 Aug 18 21:15
» Shooting for 1000whp with my C7 @ Top Cats Racing by Sierra on Tue 14 Aug 18 14:19
» Spare wheel light by kentvette on Tue 14 Aug 18 08:46
» 2003 Anniversary Red and Shale Convertible. by Number3 on Tue 14 Aug 18 07:11
» U-joint replacement by MIT on Mon 13 Aug 18 22:37
» C6 European Rear Light Conversion by Daytona Vette on Mon 13 Aug 18 16:42
» Full geo setup needed. by Daytona Vette on Mon 13 Aug 18 10:33
» C3 Side Exhaust Pipes by CaptainK on Mon 13 Aug 18 10:00
» Kit Kat wrappers don't make good insulation by CaptainK on Mon 13 Aug 18 09:52
» Head Unit Replacement by L88 on Sun 12 Aug 18 13:57
»  by Chris123 on Sun 12 Aug 18 12:24
» 1968 Door Handles by riddyboy on Sat 11 Aug 18 08:54
» Aircon fixed at last! by Daytona Vette on Fri 10 Aug 18 13:29
» Headlight Buckets by kentvette on Fri 10 Aug 18 09:40
» C3 Auto Box Issue Just Developed by Daytona Vette on Thu 09 Aug 18 22:52
» CCCUK West Sussex meeting tonight 9th August by Sea5 on Thu 09 Aug 18 18:27
» History of my vehicle VJD 5G by Bill Riches on Thu 09 Aug 18 16:58
» Borgeson steering box upgrade. by Skeets on Thu 09 Aug 18 13:19
» Cumbria classic (Dalemain House) car show. Sunday 19th August by 666Vette on Thu 09 Aug 18 12:26
» Concours of Elegance by curious bystander on Wed 08 Aug 18 16:47
» What did you do with your Vette today? by MIT on Wed 08 Aug 18 15:31
» South Central Regional Meeting for August by Daytona Vette on Wed 08 Aug 18 10:35
» Some Subtle Mods to my C7 Stingray by C7KEN on Tue 07 Aug 18 22:01
» Boston Bowl - American Meet and Family Day - Saturday 11th August from 11:30am by cjc on Tue 07 Aug 18 15:02
» New alloys - size advice by CaptainK on Tue 07 Aug 18 14:57
» Modified C5 for Sale by Bowler on Tue 07 Aug 18 13:57
» Local c3 garage services. by MIT on Mon 06 Aug 18 23:14
» Raby castle classic vehicle show Sunday 12th August. by STELTHYFLATFISH on Mon 06 Aug 18 15:45
» C3 68-73 Chrome Rear Bumpers Wanted by JJVETTE on Mon 06 Aug 18 12:24
L98 Misfire problem
Go to page: 1, 2 / Next
Reply to topic
Author
Message
FelixP
Addict
Wed 27 Sep 17 16:46
L98 Misfire problem
Hi all looking for some advice.
My 89 6 speed has 104k and I took it on the dyno since it was running sweet with the new headers. Now it has a misfire at all RPM. Please see attached video.
https://sendvid.com/tbdya808
I have recently changed:
Coolant temp sensor & connector
Plugs
O2
Leads
Bosch III injectors
I have put on new:
Cap
Rotor arm
Ignition control module
I have checked:
Plug wire routing
TPS voltage
MAF unplugged/plugged in - No difference
Injector resistance & fuses
1989 Corvette C4 L98 6 speed ZF with Z51 & FX3
Redlevel
Club Member
Wed 27 Sep 17 17:03
Re: L98 Misfire problem
Hi..
Is the poundage of the new injectors same as the stock ones? If not, that could be a problem for the ECU.
I would have changed to coil too, could be that yours is breaking down as it heats up.
Scratchchin
chevrolet
Club Member
Wed 27 Sep 17 18:58
Well, I am definitely no L98/TPI expert. Presumably, the theory is that putting the car on the dyno may have caused/raised the problem? e.g running the engine at/or near max revs for an extended period?
Presuming you have looked at the Haynes manual? In mine for an 84-87, it lists 10 possible causes why "Engine misses throughout driving speed range"
AKA "Silver C6" on Pistonheads
peterguest
Club Member
Mon 02 Oct 17 12:57
Could be the knock sensor, mine packed up out of the blue and caused a misfire across a fair part of the rev range.
You can check it as it does throw up a code, which I can't remember, but I'm sure some knowledgeable person here will know what it is.
straight forward to replace but a bit of a pain to get at, on my 91 had to remove a heat shield as its just under the exhaust manifold on the passenger side of the block as I recall.
rgds
pete
FelixP
Addict
Tue 03 Oct 17 12:20
Thanks guys
I don't have a Haynes. Chevrolet - Yes that is my theory. I think I'm in the midst of a lesson learned here!
Steve - Injectors are factory spec and caused no issues in the last 12 months since fitting
Peter - I don't have any codes so don't think it's the knock sensor?
I've tried swapping injector harnesses around, no change. Likewise tried pulling leads off the dizzy cap, seems to have less of an impact on 7 & 8.
I took the valve covers off and the rocker arms seemed consistent, I turned it over a few times and watched them. The springs feel tight too.
I have Hedman headers so I can't take the plugs out without taking them off which is a pain. Would I be jumping the gun to just drain the oil and see what's in the pan/filter? I really don't like the sound it makes that you can hear in the end of the video.
roppa440
Club Member
Tue 03 Oct 17 14:36
Could a vacuum hose have come off or split?
chevrolet
Club Member
Tue 03 Oct 17 14:47
Must admit, don't totally understand the sounds in the video compared to my "stock" '85 . Presume yours will sound different anyway due to the headers (?) Are the background "banging" noises the misfire? Haynes manual (not expensive):
https://haynes.com/en-gb/chevrolet-corvette-84-96-haynes-rep...
Don't know if you can see this attachment (extract from Haynes manual)?
FelixP
Addict
Thu 05 Oct 17 22:59
Got myself a Haynes manual.
Offset spanner did the trick on the plugs, cylinder 7 was black. Did a compression test and all cylinders were 175-180psi. Put it back together, ran ok for a few minutes then started missing again. With an IR temp gun I found the exhaust on cylinders 8&6 half that of the rest. Using a stethoscope I could hear all injectors pulsing. Happily no more banging sounds.
I'll order and ignition coil now and see how I get on.
Redlevel
Club Member
Fri 06 Oct 17 12:53
What kind of leads are you using?
I had problems with another car using silicon/carbon leads from Halfords (orange and yellow) which kept failing and eventually the replacements failed too. I ended up visiting a lawnmower shop and bought a (cheap) roll of black/copper HT lead and caps which solved all the misfiring.
These days, I'm using Taylor products specifically their copper leads and distributor cap with brass fittings.
https://www.summitracing.com/int/parts/tay-76240/overview/ye...
If I'm doing ignition these days, I prefer to source all the components from the same manufacturer if I can.
FelixP
Addict
Fri 06 Oct 17 13:31
All of my parts are genuine AC Delco
Reply to topic
Permissions
