CCCUK logo
 Adrian Flux
Website Control
Recent threads
New Forum Posts
» Corvette Nationals 2018 - pre booking. by Rich on Thu 24 May 18 22:37
» Masters Historic Festival, Brands Hatch Sat 26 May-Sun 27 May by Forrest Gump on Thu 24 May 18 20:53
» 2019 Corvette ZR1 by Gort on Thu 24 May 18 19:22
» 1981 corvette 64,000 mile on it way over by JJVETTE on Thu 24 May 18 15:48
» Le Mans 2017 by Pigginvet on Wed 23 May 18 22:35
» Harmonic balancer by Vetteheadtony on Wed 23 May 18 13:44
» South Central Regional Meeting and Midlands-ish Breakfast Club - November by Bowler on Wed 23 May 18 08:25
» South Central Regional Meeting and Midlands-ish Breakfast Club - October by Bowler on Wed 23 May 18 08:22
» Midlands-ish Breakfast Club Meeting - September by Bowler on Wed 23 May 18 08:05
» Midlands-ish Breakfast Club Meeting - August by Bowler on Wed 23 May 18 08:03
» Midlands-ish Breakfast Club Meeting - July by Bowler on Wed 23 May 18 08:00
» South Central Regional Meeting for September by Bowler on Wed 23 May 18 07:53
» South Central Regional Meeting for August by Bowler on Wed 23 May 18 07:50
» South Central Regional Meeting for July by Bowler on Wed 23 May 18 07:49
» C5 aircon recharge by weslp00 on Tue 22 May 18 20:29
» dash bulbs by damc3 on Tue 22 May 18 19:41
» RockAuto.com Discount Code for Parts & More - Expires August 15, 2018 by Vetteheadtony on Tue 22 May 18 19:27
» What did you do with your Vette today? by petchy56 on Tue 22 May 18 17:10
» Jacking whole car onto axle stands by BlackZeD on Tue 22 May 18 12:40
» For Sale 1976 C3 L48 Auto by Vetteheadtony on Tue 22 May 18 09:07
» Silverstone Classic - 20/21/22 July 2018 by curious bystander on Tue 22 May 18 08:54
» Loose handbrake lever by stiej on Mon 21 May 18 23:23
» CCCUK East Sussex Monthly Meeting in May by Sea5 on Mon 21 May 18 22:07
» Leeds Castle Motors by the Moat Sunday 13th May 2018 by 7YEL on Mon 21 May 18 16:43
» Lincolnshire Corvette Open Day by JJVETTE on Mon 21 May 18 16:41
» FOR SALE - C6 MODIFIED STANDARD EXHAUSTS louder than stock by craigyboy on Mon 21 May 18 13:23
» Oil by stevel98 on Sun 20 May 18 08:12
» no posts by L88 on Sat 19 May 18 12:41
» c5 outdoor cover by curious bystander on Sat 19 May 18 10:28
» Ordering Spares From The States by voguev8 on Sat 19 May 18 06:13
L98 Misfire problem
Go to page: Previous / 1, 2
Reply to topic
Author
Message
Sid.123
Club Member
Mon 09 Oct 17 19:22
I was going to suggest a vacuem leak as did roppa as mine had an initial flat spot on acceleration which I found to be caused by perished 30yr old vacuem pipes....
But if you say number 7 plug was black/rich it could be that athough the injector may be clicking it may be stuck open.I would try cleaning the plug and running with the injector unplugged to see if the plug still gets wet etc or run it with the plug out while unplugged to see if fuel is ejected from the hole.
59/69 silver beige/medium brown. 1 of 1,014 in 1986. C4 glasstop
Manj82
New Comer
Sat 14 Oct 17 23:21
Re: L98 Misfire problem
I'm chasing a miss on a LB9 Trans Am so will watch this with interest Smile
Noticed you mentioned you replaced your injectors with Bosch D3's. Have you checked your fuelling after this and what's your crank times like
I query as I changed the injectors in my trans am to D3's (that according to a vendor were supposedly a like for like replacement) and the car was running pretty lean according to a scan of the fuel trims; BLM high 140's, low 150's on idle and max out at 160 in some cases when driving. Had I not had a scan tool, I would've been clueless about this other than an occasional lean surge
I had to burn a chip with adjustments to the injector constant and some other tables to get the fuelling close to the desired 128.
A google search whilst diagnosing found that quite a few people experienced similar lean conditions with their TPI cars (L98, LB9) and had to pull out the laptop...
just thought to mention
FelixP
Addict
Wed 08 Nov 17 10:55
I finally got to the bottom of this and it was a cheap and easy fix!
When I changed the leads a few had got a little too hot near the headers despite having those socks on the boots. When I put new leads on, I didn't take the boots off to slide on the heatshields. Anyway, I started it up and now we have darker evenings, I saw one of the leads shorting against the header!
I'll have to run them very neatly. I was using Summit racing leads but had put new AC Delco ones on, I guess the insulation isn't as good, as they were further away from everything previous but still the spark jumped across. Thank you daylight savings! And a good lesson in checking & double checking the simple things silly
1989 Corvette C4 L98 6 speed ZF with Z51 & FX3
chevrolet
Club Member
Wed 08 Nov 17 12:41
Well Done/Top Marks Thumbs up So can we call that a "Leaking Spark Plugs Wire" job/fault, as in the Haynes manual Trouble Shooting section above?
AKA "Silver C6" on Pistonheads
Reply to topic
Permissions
