CCCUK logo
 Adrian Flux
Website Control
Recent threads
New Forum Posts
» How Many Miles Does Your Corvette Get Driven? by Redlevel on Tue 11 Dec 18 18:01
» Insurance recommenations by FIVE RED on Tue 11 Dec 18 15:31
» What did you do with your Vette today? by roppa440 on Tue 11 Dec 18 08:33
» Bloodhound SSC by Atomic UK on Mon 10 Dec 18 13:04
» Spotted C2 by Jan25 on Mon 10 Dec 18 09:01
» Help with newly acquired 72 350 Auto by Jimbo64 on Sun 09 Dec 18 21:33
» Facebook page by fat_jogger on Sun 09 Dec 18 19:36
» O.m.g. by Redlevel on Sun 09 Dec 18 17:35
» Trimmer/upholsterer by roscobbc on Sun 09 Dec 18 17:15
» C5 Harmonic balancer wobbling! by therabster on Sat 08 Dec 18 22:02
» My C8 Grump by Vetteheadtony on Sat 08 Dec 18 13:05
» C7 Z06 by MShaky on Fri 07 Dec 18 15:17
» Replacement head unit for US spec C6 by Young Bill on Fri 07 Dec 18 10:10
» Kelsey Hayes Aluminum Wheels by Daytona Vette on Thu 06 Dec 18 01:05
» Thames Vally Region trip to Studio 434 by Nicetie on Wed 05 Dec 18 22:33
» C6 LED halos by autocolor on Wed 05 Dec 18 19:20
» Another day, another Mid-Engine Corvette thread by Norm on Wed 05 Dec 18 19:05
» 2007 C6 ZO6, Manual. by Fraser on Wed 05 Dec 18 15:50
» 2019 Nationals by curious bystander on Wed 05 Dec 18 11:15
» Replacing Fuel Filter by robbiew on Tue 04 Dec 18 18:28
» South Central Breakfast Club by Daytona Vette on Mon 03 Dec 18 12:52
» Differential Rebuild by Nick B on Sun 02 Dec 18 18:51
» Trans fluid by Nigelcurry on Sun 02 Dec 18 12:28
» wheels by robbiew on Sun 02 Dec 18 09:25
» The EVENTS CALENDAR by kentvette on Sat 01 Dec 18 15:25
» 1982 Collectors Edition by kentvette on Sat 01 Dec 18 15:23
» Magazine Purchase? by roscobbc on Sat 01 Dec 18 10:19
» 1976 ''Spirit of Le Mans'' Corvette by Atomic UK on Thu 29 Nov 18 18:00
» Speedo not working by kentvette on Thu 29 Nov 18 16:29
» International Corvette & Camaro Meeting 2019 - 20th Anniversary by Alexa-Italy on Wed 28 Nov 18 09:40
Stock thermostat opening temp
Go to page: 1, 2, 3, 4 / Next
Reply to topic
Author
Message
roppa440
Club Member
Wed 04 Oct 17 09:23
You would think it would be easy to find out what the stock opening temp of my 2002 C5 is wouldn't you but the internet is only full of arguments about 160 and 180 degree versions.
I am guessing mine opens around 195 degrees because it normally sits at around that temp?
Redlevel
Club Member
Wed 04 Oct 17 10:23
Re: Stock thermostat opening temp
My thermostat is a 160deg unit, but the car runs about 180-185 on a hot day on the motorway (the fan is set to come on at 170).
The opening temp is usually a bit lower than the running temp.
roppa440
Club Member
Wed 04 Oct 17 10:39
Thermostats set the MINIMUM engine temp and have no effect on max temps.
Something people fail to grasp most of the time.
I just want to know what the stock rating is.
If a cooling system is efficient enough the engine temp will never go much higher than the thermostat temp and settle back down quickly. However most systems deliberately only switch the radiator fans on at a higher temp. Sometimes in two stages.
I have a basic Diablo tune on my car. It is unclear to me if that tune program has altered the point the fans kick in or not as some do.
I just want to work out how the system is currently working. But to do that I need to be certain what temperature the current thermostat is opening. Then I can decide if I want to make some changes to that.
roppa440
Club Member
Wed 04 Oct 17 10:44
stevel98 wrote (View Post):My thermostat is a 160deg unit, but the car runs about 180-185 on a hot day on the motorway (the fan is set to come on at 170).
I would put a 180F thermostat in your engine. That way it will warm up quicker without effecting running temps. Thumbs up
Yellowshark
Club Member
Wed 04 Oct 17 11:06
I have had my 2001 C5 since new. It came with a 180F thermostat which it still has after 152,000 miles
Yellowshark
Club Member
Wed 04 Oct 17 11:12
I THINK I read somewhere, because I was looking for it, that the stock temp for the fan activation is 210f or 220f
roppa440
Club Member
Wed 04 Oct 17 12:09
Yellowshark wrote (View Post):I THINK I read somewhere, because I was looking for it, that the stock temp for the fan activation is 210f or 220f
Mine are definitely coming on at a lower temp than that.
Standard thermo can't be 180 because all the yanks talk about is swapping to a 180 and re-programming the fans to come on sooner.
Yellowshark
Club Member
Wed 04 Oct 17 12:52
That does not make a whole lot of sense to me, why would you increase the time it takes for the coolant to start circulating the block and bring in the fans earlier? Anyway my 2001 user manual says 186.8F; I always thought it was 180, a figure I have certainly seen elsewhere on the forums. It sure is not 160. Your 2002 user manual will have the figure at the back in the specifications section
Now maybe because they have deserts the domestic C5 is setup differently on cooling than export models?? never seen anything on that but then have never been looking.
Oh saw something just now that suggests fan activation is 220, which is what I though it was but was not certain.
roppa440
Club Member
Wed 04 Oct 17 13:01
I have seen some replacements for sale labelled at 187F. So that makes sense.
I have looked in a user manual for a 2002 but didn't find a thermostat spec. I will look again.
I don't want to start trying to explain how a cooling system works. Just humour me.
Yellowshark
Club Member
Wed 04 Oct 17 13:46
Lol I do not, so I will Smile
Reply to topic
Permissions
