CCCUK logo
 Ian Allan Motors
Website Control
Recent threads
New Forum Posts
» AMERICAN SPEEDFEST 7 on 1st - 2nd JUNE 2019 by Blackadder on Sat 15 Dec 18 22:33
» Tesla Pick Up by Jack Cooper on Sat 15 Dec 18 21:46
» Fuse replacements by Daytona Vette on Sat 15 Dec 18 13:29
» wet carpets by kentvette on Sat 15 Dec 18 09:24
» Another day, another Mid-Engine Corvette thread by Norm on Fri 14 Dec 18 23:31
» Once A Vette Head - Always A Vette Head! by Jimbo64 on Fri 14 Dec 18 20:40
» Insurance recommenations by BlackZeD on Fri 14 Dec 18 20:31
» Help with newly acquired 72 350 Auto by Jimbo64 on Fri 14 Dec 18 18:54
» 2007 C6 Z51 BX08 ECV - Any Former Owners Here? by Atomic UK on Fri 14 Dec 18 16:44
» South Central Midlands Supper Club Meet by Daytona Vette on Fri 14 Dec 18 11:58
» 2002 C5 Coupe by roppa440 on Fri 14 Dec 18 10:29
» CCCUK West Sussex Xmas meeting tonight 13th December by Sea5 on Thu 13 Dec 18 17:14
» Outer Door Handles by kentvette on Thu 13 Dec 18 11:13
» How Many Miles Does Your Corvette Get Driven? by Skoosh1970 on Thu 13 Dec 18 11:08
» What did you do with your Vette today? by roscobbc on Wed 12 Dec 18 12:09
» Website Copy and Paste by Rich on Wed 12 Dec 18 07:51
» Trimmer/upholsterer by Forrest Gump on Tue 11 Dec 18 20:06
» Bloodhound SSC by Atomic UK on Mon 10 Dec 18 13:04
» Spotted C2 by Jan25 on Mon 10 Dec 18 09:01
» Facebook page by fat_jogger on Sun 09 Dec 18 19:36
» O.m.g. by Redlevel on Sun 09 Dec 18 17:35
» C5 Harmonic balancer wobbling! by therabster on Sat 08 Dec 18 22:02
» My C8 Grump by Vetteheadtony on Sat 08 Dec 18 13:05
» C7 Z06 by MShaky on Fri 07 Dec 18 15:17
» Replacement head unit for US spec C6 by Young Bill on Fri 07 Dec 18 10:10
» Kelsey Hayes Aluminum Wheels by Daytona Vette on Thu 06 Dec 18 01:05
» Thames Vally Region trip to Studio 434 by Nicetie on Wed 05 Dec 18 22:33
» C6 LED halos by autocolor on Wed 05 Dec 18 19:20
» 2007 C6 ZO6, Manual. by Fraser on Wed 05 Dec 18 15:50
» 2019 Nationals by curious bystander on Wed 05 Dec 18 11:15
Stock thermostat opening temp
Go to page: Previous / 1, 2, 3, 4 / Next
Reply to topic
Author
Message
roppa440
Club Member
Wed 04 Oct 17 14:31
Re: Stock thermostat opening temp
Nothing in the 2001 owners manual. Maybe it's in the "workshop" manual? I have a copy at home so I will check later.
I will run the car up to temp tonight. Maybe I can feel it in the hose when the thermostat opens and I will note the temp the fans first come on.
If it is a 187 thermostat its certainly not worth swapping it for a 180 and I just need to change the temp that the fans come on.
Redlevel
Club Member
Wed 04 Oct 17 15:29
roppa440 wrote (View Post):stevel98 wrote (View Post):My thermostat is a 160deg unit, but the car runs about 180-185 on a hot day on the motorway (the fan is set to come on at 170).
The opening temp is usually a bit lower than the running temp.
I would put a 180F thermostat in your engine. That way it will warm up quicker without effecting running temps. Thumbs up
I had an issue with a fan failure a while back and my temp shot up into the 260 mark, like really quickly, which lit a red lamp on the dash and dumped all my coolant out of the expansion tank as it defeated the rad cap spring valve.
Luckily the motor was ok, so I fitted the 160, new fan motor and a temperature adjustable fan controller to keep things cool which it does and the motor now warms up to about 180 in about 3 miles which is fine.
Yes, I know that these motors are designed to run hot well into the 200's+, and I realise that the book says its ok, but I really don't have the bottle to let it get that close again as its only the fan(s) that prevent the motor overheating which it can do very quickly and without warning of impending doom!
Unlike an older motor where you can watch the overheating process creeping up gradually, these motors react very quickly. None of my other cars run anywhere near the 200 mark including Michelle's Chevy S10, so I prefer to have the Corvette run a little cooler than it should be.
roppa440
Club Member
Wed 04 Oct 17 22:39
Yes but you just said it runs at 180. Not 160.
So why are you using. 160?
It amazes me how most people, even intelligent people, just don't get it.
Th thermostat only dictates the minimum engine temp and has nothing to do with max temp.
If it runs at 180 then opening at 160 just means the engine gets cooler water before it's needed. Which means it takes longer to reach 180. Whatever happens after 180 is nothing to do with the thermostat. It's been wide open since 160. It's not doing anything.
Jesus. It's like talking to second amendment nutters. Lol
lolmans34
Club Member
Wed 04 Oct 17 23:01
Well,...the stock thermostat for an '84-'88 is a 195F deg. ( from the factory parts manual), from my own driving experience of an '87 .....normal driving 176-178F on display, rising to 210F when stuck in traffic, at this point the fan kicks in until 176F is achieved. This is a stock, unmodified Z52 vehicle.
roppa440
Club Member
Thu 05 Oct 17 08:42
Right ho then.
Had a good test last night.
I have come to the conclusion my 2002 has a 195F thermostat fitted.
Was not sure at first exactly when the thermostat STARTED to open as the only bit of hose I could get my hand on was close to the hot block but it was definitely fully open by 196F.
Fans didn't come on until 198F. Once they came on the temp dropped to 192F quite quickly which shows the cooling system is capable of cooling the water below the thermostat rate.
Then after about 30 seconds stepped up to 194F and stayed there.
To me that shows that the thermostat is hovering slightly open at that point. Balancing the engine block water temp and cooler radiator water.
Fans stayed on and temp stayed at 194F solid. So not sure how far the temp has to drop before the fans switch back off but I bet it is not much lower than that temp.
So if I am right about the efficiency of the cooling system then in my case fitting a 180 F thermostat can bring the max temp down (with the fans running) but I need to get the fans coming on and off at lower temperatures otherwise the engine is still going to reach 198F at times and the fans will be switching off again much higher than the thermostat rating and so limiting the temperature drop.
If I can get the engine stable at around 180F-185F then that will make a performance difference big enough to feel.
Redlevel
Club Member
Thu 05 Oct 17 08:44
roppa440 wrote (View Post):Yes but you just said it runs at 180. Not 160.
The running temp of the motor when warmed up is usually around 15-20deg higher that the stated opening temp of the thermostat. If I used a 180 unit, my running temp would be back in the 200 range and I don't want that so I use a 160, which keeps it cooler. Its been that way for years now.
Your probably right, but its been that way for years now and I currently have a cool running L98, which I find comforting after years of "normal" running around the 210mark and experiencing it hitting 265 in the blink of an eye when the fan stopped.. I've never had a car get so hot so very quickly and make such a mess when most of my coolant burst out of the expansion tank and trailed glycol behind me like a WW2 aircraft with a radiator hit..
I'm not saying your wrong, and you do make more sense than most, but this works out for me very well. Thumbs up
roppa440
Club Member
Thu 05 Oct 17 08:50
The reason for all this is my mate in Denver, that I go on road trips with, just fitted a 180F thermostat to his 2012 Challenger R/T 5.7 Hemi and had his fans adjusted to come on at a lower temp too.
He wishes he had done that years ago. Made a big difference to him. Much like the performance increase we felt when we dropped down to sea level from "Mile High" Denver on our last trip.
You don't get something for nothing. He has seen a slight drop in MPG and might have a slight increase in emissions too. But, then again, he can't keep his foot off the pedal with this new found power so that could be the cause of that. Smile
Redlevel
Club Member
Thu 05 Oct 17 08:54
lolmans34 wrote (View Post):Well,...the stock thermostat for an '84-'88 is a 195F deg. ( from the factory parts manual), from my own driving experience of an '87 .....normal driving 176-178F on display, rising to 210F when stuck in traffic, at this point the fan kicks in until 176F is achieved. This is a stock, unmodified Z52 vehicle.
That sounds about right, but since I fitted my 160, I never see the wrong side of 190, even after a thrash or stuck in traffic. 180 is normal for me.
One thing I did used to do when I first got my '87 and was travelling on the motorway a lot with the temp around the 215 mark Surprised was to open the windows and run the demister. This would quickly drop the temp about 20deg.. Never had a car that doing this had such a marked effect.
roppa440
Club Member
Thu 05 Oct 17 08:54
[quote="stevel98";p="144843"]roppa440 wrote (View Post):
Yeah sorry I was getting rather drunk when I replied last night. Doh
But it was "Hump Day". Very Happy
Redlevel
Club Member
Thu 05 Oct 17 08:58
roppa440 wrote (View Post):The reason for all this is my mate in Denver, that I go on road trips with, just fitted a 180F thermostat to his 2012 Challenger R/T 5.7 Hemi and had his fans adjusted to come on at a lower temp too.
..hey, hey, Kowalski, ..can you hear me, man? Cool
Reply to topic
Permissions
