CCCUK logo
 Lancaster Insurance
Website Control
Recent threads
New Forum Posts
» Outer Door Handles by fordpop52 on Thu 13 Dec 18 07:29
» 2002 C5 Coupe by Firepit on Wed 12 Dec 18 23:58
» wet carpets by stephano on Wed 12 Dec 18 22:51
» AMERICAN SPEEDFEST 7 on 1st - 2nd JUNE 2019 by 7YEL on Wed 12 Dec 18 15:11
» Once A Vette Head - Always A Vette Head! by Rich on Wed 12 Dec 18 13:57
» South Central Midlands Supper Club Meet by Daytona Vette on Wed 12 Dec 18 12:53
» What did you do with your Vette today? by roscobbc on Wed 12 Dec 18 12:09
» Insurance recommenations by Rich on Wed 12 Dec 18 07:54
» Website Copy and Paste by Rich on Wed 12 Dec 18 07:51
» Trimmer/upholsterer by Forrest Gump on Tue 11 Dec 18 20:06
» How Many Miles Does Your Corvette Get Driven? by Redlevel on Tue 11 Dec 18 18:01
» Bloodhound SSC by Atomic UK on Mon 10 Dec 18 13:04
» Spotted C2 by Jan25 on Mon 10 Dec 18 09:01
» Help with newly acquired 72 350 Auto by Jimbo64 on Sun 09 Dec 18 21:33
» Facebook page by fat_jogger on Sun 09 Dec 18 19:36
» O.m.g. by Redlevel on Sun 09 Dec 18 17:35
» C5 Harmonic balancer wobbling! by therabster on Sat 08 Dec 18 22:02
» My C8 Grump by Vetteheadtony on Sat 08 Dec 18 13:05
» C7 Z06 by MShaky on Fri 07 Dec 18 15:17
» Replacement head unit for US spec C6 by Young Bill on Fri 07 Dec 18 10:10
» Kelsey Hayes Aluminum Wheels by Daytona Vette on Thu 06 Dec 18 01:05
» Thames Vally Region trip to Studio 434 by Nicetie on Wed 05 Dec 18 22:33
» C6 LED halos by autocolor on Wed 05 Dec 18 19:20
» Another day, another Mid-Engine Corvette thread by Norm on Wed 05 Dec 18 19:05
» 2007 C6 ZO6, Manual. by Fraser on Wed 05 Dec 18 15:50
» 2019 Nationals by curious bystander on Wed 05 Dec 18 11:15
» Replacing Fuel Filter by robbiew on Tue 04 Dec 18 18:28
» South Central Breakfast Club by Daytona Vette on Mon 03 Dec 18 12:52
» Differential Rebuild by Nick B on Sun 02 Dec 18 18:51
» Trans fluid by Nigelcurry on Sun 02 Dec 18 12:28
Stock thermostat opening temp
Go to page: Previous / 1, 2, 3, 4
Reply to topic
Author
Message
roppa440
Club Member
Fri 06 Oct 17 12:32
Re: Stock thermostat opening temp
It helps keep the engine temp steady I believe. Scratchchin
roppa440
Club Member
Sat 07 Oct 17 14:25
Just found this in the 2002 service manual;
"When the coolant temperature is below 91C (195F), the thermostat valve remains closed. This prevents circulation of the coolant to the radiator and allows the engine to warm up quickly. After the coolant temperature reaches 91C (195F), the thermostat valve will open. The coolant is then allowed to circulate through the thermostat to the radiator where the engine heat is dissipated to the atmosphere. The thermostat also provides a restriction in the cooling system, even after it has opened. This restriction creates a pressure difference which prevents cavitation at the water pump and forces coolant to circulate through the engine block."
So my hand testing was spot on. Thumbs up
Sid.123
Club Member
Mon 09 Oct 17 18:50
Just to put my two pennys worth in here....
I'm not sure what thermostat is in my 86, Ive never realy give it much thought but when cruising its normaly stable about 185f. when in traffic it will creep up to 218f when the fan cuts in, quickly bringing the temp down.
When I first got the car I did wire in a switch to manualy earth the relay to switch the fan on if needed but as yet ive never needed to use it. But its nice to know its there incase the fan switch goes faulty.
As I understand it these engines are designed to run hot and by keeping them cooler I would imagine they would not be running at max efficiency..
59/69 silver beige/medium brown. 1 of 1,014 in 1986. C4 glasstop
roppa440
Club Member
Mon 09 Oct 17 18:56
They run them hot for emissions reasons. Not for max power or efficiency.
Sid.123
Club Member
Mon 09 Oct 17 19:00
ok..i wasn't aware of that...makes sense I suppose...
roppa440
Club Member
Mon 09 Oct 17 19:05
That's why my mates 2012 Challenger in Denver makes more power at 180f. They have to make cars these days with tight emissions and fuel economy ratings.
I would rather make a bit more power than slightly less emissions.
roppa440
Club Member
Mon 09 Oct 17 19:14
If your car runs as cool as 185f then it's thermostat HAS to be rated around that figure as it is impossible for the engine to run below the rating of the thermostat. Once at the rated temp it closes and does not allow any cool water from the radiator to enter he engine. So your radiator water can be as cold as ice and it still will not effect the minimum engine temp.
If your temp rises much higher than the thermostat rating them the fans are not coming on until reaching that high temp. Then once they are on they cool the engine back down again as you experience.
It is better if the fans come on before temps get high. That way the engine temp becomes more consistent.
Reply to topic
Permissions
