CCCUK logo
 Lancaster Insurance
Website Control
Recent threads
New Forum Posts
» Birdcage repair by L88 on Wed 17 Oct 18 10:04
» C3 Hooker Side Pipe headers by L88 on Tue 16 Oct 18 22:17
» C3 Side Exhaust Pipes by icandycanvas on Tue 16 Oct 18 20:52
» Wiper actuator on a 69L by Ddave on Tue 16 Oct 18 18:36
» What did you do with your Vette today? by Ddave on Tue 16 Oct 18 18:08
» Le Mans 2019 by kentvette on Tue 16 Oct 18 17:55
» Tips by CaptainK on Tue 16 Oct 18 13:44
» Im interested in a C5 Z06 (this time next year) by Benbay001 on Tue 16 Oct 18 12:55
» Engine cutting out after firing up by Firepit on Tue 16 Oct 18 09:19
» A trio of C2 owners. by yenko 1969 on Mon 15 Oct 18 21:38
» Thinking About Hanging Them Up....... by Norm on Mon 15 Oct 18 15:44
» BBCN Regional meet by Nicetie on Mon 15 Oct 18 12:57
» C5 O2 sensor code?? by roppa440 on Mon 15 Oct 18 08:45
» C2 fibreglassing and prep. by L88 on Sun 14 Oct 18 17:16
» Spec lists by Jimbo64 on Sun 14 Oct 18 15:36
» Road Atlanta this weekend. by UkBeancounter on Sun 14 Oct 18 14:29
» New Series of Wheeler Dealers an 02 Z06?? by dex99 on Sun 14 Oct 18 12:02
» Door removal on 79 coupe by Nigelcurry on Sat 13 Oct 18 20:01
» American Day - Museum of Power Essex by Forrest Gump on Sat 13 Oct 18 17:44
» C5 Performance Projects - book by robbiew on Fri 12 Oct 18 21:19
» Help with newly acquired 72 350 Auto by Jimbo64 on Fri 12 Oct 18 18:15
» speed bleeders by Grahamred70 on Fri 12 Oct 18 16:17
» South Central Regional Meeting and Midlands-ish Breakfast Club - October by Daytona Vette on Fri 12 Oct 18 10:44
» Essex Regional meeting by roscobbc on Fri 12 Oct 18 08:36
» 1972 Washer bottle wanted by Vetteheadtony on Thu 11 Oct 18 22:48
» Vette Hire In The U.S. by 86vetteman on Thu 11 Oct 18 20:33
» South Central Mids Supper Club Meet by Daytona Vette on Wed 10 Oct 18 07:29
» CCCUK West Sussex meeting in October by robbiew on Tue 09 Oct 18 19:11
» You Like Shine? I Like Shine....... by Norm on Mon 08 Oct 18 19:21
» FOR SALE - C6 MODIFIED STANDARD EXHAUSTS – louder than stock by Rich on Mon 08 Oct 18 17:20
1962 327 340 bhp 4 speed manual stalling
Reply to topic
Author
Message
Leif
Club Member
Sat 07 Oct 17 15:36
Hello, I am new to this forum and I am hoping that someone in the Club may be familiar with my problem. I have only owned my Vette for nearly four weeks. It runs and drives beautifully in city traffic without any stalling issues. However, if I have been on the motorway driving steady at 50 to 55 mph for 10 miles or so the engine stalls as soon as I stop. It actually stalls just before I come to a stop so sometimes if I gear down and release the clutch before coming to a stop the engine will turn over and restart before stopping. There is no sputtering or hesitation, it just cuts out. Needless to say this has caused a few near miss moments so I am desperate to have the issue resolved. Previous suggestions have included faulty distributor condensor, heat transferring from exhaust manifold to fuel line, vapour lock and flooding but no solution yet. Any suggestion will be appreciated. Thank you.
Leif
roscobbc
Sat 07 Oct 17 17:37
Re: 1962 327 340 bhp 4 speed manual stalling
Have you monitored engine temperature in both situations. Are you getting fuel flowing from the pump. Are float levels correct.
CCCUK Chairman
Leif
Club Member
Sat 07 Oct 17 17:47
Temperature is steady at about 185 degrees in both driving conditions. Idle, timing and I assume float level was adjusted professionally last week but I will confirm that later. I have not checked fuel level when the stall actually occurs because of traffic conditions. I will try driving on the motorway and stopping in a lay-by where I can pop the hood when it stalls.
Leif
Leif
Club Member
Sat 07 Oct 17 17:57
I forgot to mention that the previous owner has fitted a Holley double pumper.carburetttor to keep up with a high performance camshaft - not sure if that is relevant but thanks for the prompt reply.
Leif
roscobbc
Sat 07 Oct 17 20:50
Double pumpers can be prone to flooding engine when stopping suddenly if they don't have a 'snorkel' fitted in the float bowl - if its a new higher spec carb it should have that fitted. Is it the stock inlet manifold? if not put a spirit level on the carb to see if its level - if not you'll need to compensate the float levels.
CCCUK Chairman
Leif
Club Member
Thu 02 Nov 17 18:10
Thanks for the reply and please accept my apology for not having posted sooner (circumstances beyond my control). The carb model number is GR3760B and it is stamped 6497 list 4777. I don’t know if that is a new higher spec carb. There is a tube inside the carb throat but I don’t know if that is the “snorkel”. The manifold is stock numbered 3795397. It has been suggested that a new intake manifold gasket with blocking plates for the two center ports may solve the problem if the stalling is due to “percolation” or vapour lock. Also, installing an electric fuel pump has been suggested. Again, any advice will be greatly appreciated.
Leif
Reply to topic
Permissions
