CCCUK logo
 Adrian Flux
Website Control
Recent threads
New Forum Posts
» C5 standard wheels and one aftermarket multispoke. by L88 on Sun 21 Oct 18 16:13
» Help with newly acquired 72 350 Auto by Grahamred70 on Sun 21 Oct 18 12:17
» CCCUK East Sussex meeting in October by Sea5 on Sat 20 Oct 18 22:21
» C2/C3 rear trailing arms plus other parts by L88 on Sat 20 Oct 18 13:56
» Le Mans 2019 by kentvette on Sat 20 Oct 18 12:48
» 2009 C6 LS3 wing mirrors by 86vetteman on Fri 19 Oct 18 16:13
» A trio of C2 owners. by L88 on Fri 19 Oct 18 14:46
» Silverstone Classic 2019 by curious bystander on Thu 18 Oct 18 20:01
» AC belt by corvetteville on Thu 18 Oct 18 17:55
» Spec lists by kentvette on Thu 18 Oct 18 16:41
» Birdcage repair by johng on Thu 18 Oct 18 12:49
» Strange tacho by kentvette on Thu 18 Oct 18 12:44
» What did you do with your Vette today? by FIVE RED on Thu 18 Oct 18 12:25
» C3 Hooker Side Pipe headers by icandycanvas on Wed 17 Oct 18 16:18
» C3 Side Exhaust Pipes by icandycanvas on Tue 16 Oct 18 20:52
» Wiper actuator on a 69L by Ddave on Tue 16 Oct 18 18:36
» Tips by CaptainK on Tue 16 Oct 18 13:44
» Im interested in a C5 Z06 (this time next year) by Benbay001 on Tue 16 Oct 18 12:55
» Engine cutting out after firing up by Firepit on Tue 16 Oct 18 09:19
» Thinking About Hanging Them Up....... by Norm on Mon 15 Oct 18 15:44
» BBCN Regional meet by Nicetie on Mon 15 Oct 18 12:57
» C5 O2 sensor code?? by roppa440 on Mon 15 Oct 18 08:45
» C2 fibreglassing and prep. by L88 on Sun 14 Oct 18 17:16
» Road Atlanta this weekend. by UkBeancounter on Sun 14 Oct 18 14:29
» New Series of Wheeler Dealers an 02 Z06?? by dex99 on Sun 14 Oct 18 12:02
» Door removal on 79 coupe by Nigelcurry on Sat 13 Oct 18 20:01
» American Day - Museum of Power Essex by Forrest Gump on Sat 13 Oct 18 17:44
» C5 Performance Projects - book by robbiew on Fri 12 Oct 18 21:19
» speed bleeders by Grahamred70 on Fri 12 Oct 18 16:17
» South Central Regional Meeting and Midlands-ish Breakfast Club - October by Daytona Vette on Fri 12 Oct 18 10:44
C3 Steering wheel boss
Go to page: 1, 2 / Next
Reply to topic
Author
Message
geoff917
Club Member
Sun 29 Oct 17 18:10
A request for help,please......at a recent show we took the C3 on its first outing.It was a warm day, the car was on the Club stand and there was security patrolling.This didn't stop someone from trying to remove the steering wheel boss, which they subsequently dropped onto the car floor.
I am having a real issue trying to refit it .Sounds a minor problem you might think, but the horn goes off with barely any contact with the boss in place.I must be doing something wrong....,,fortunately the battery has an isolator so at least it's not going off whilst I have been trying.....
Help!😕
curious bystander
Sun 29 Oct 17 19:46
Re: C3 Steering wheel boss
If you mean by the "boss" the horn button with the crossed flags I have exactly the same problem. Go over a bump and the horn goes off slightly.
New parts needed - the black spring thing that you are trying to get the "boss" back on to is probably tired of life like mine. Shorts out as soon as you look at it making the horn sound?
Look on Ecklers parts list for reference. All the different bits are available separately I think.
And when you find what you need, get me one please Smile
79 L82 Auto
Having a lot of bhp is all very well, but on these forums it's torque that counts
Club Secretary
geoff917
Club Member
Sun 29 Oct 17 20:09
Yes, it is thank you!
Will check it out and let you know lol☺
L88
Club Member
Sun 29 Oct 17 20:48
https://www.rockauto.com/en/catalog/chevrolet,1969,corvette,...
It's more than likely the Dorman spring contact kit at the bottom of page you need.
geoff917
Club Member
Sun 29 Oct 17 21:40
L88 wrote (View Post):https://www.rockauto.com/en/catalog/chevrolet,1969,corvette,5.7l+350cid+v8,1040892,electrical,horn,1060
Thank you for your kind response.....mine is a 78 C3, do you think the part would still fit?
L88
Club Member
Sun 29 Oct 17 21:56
https://www.rockauto.com/en/catalog/chevrolet,1978,corvette,...
Yes it lists as the same. To keep your neighbours happy try and temporary sleeve it to stop the alloy pin from touching the sides until the the kit arrives. Also the part that you're horn push clamps on to , pull each side away from the steering wheel a millimetre all the way around.
curious bystander
Sun 29 Oct 17 23:02
I was thinking this was the problem on mine Scratchchin
https://www.ecklerscorvette.com/corvette-horn-button-contact...
79 L82 Auto
Club Secretary
L88
Club Member
Sun 29 Oct 17 23:15
Yes that's the part I was on about trying to bend away from wheel so there is more travel until contact is made.
Grahamred70
Club Member
Mon 08 Jan 18 23:22
I found a used one with a good button, as mine was cracked, on E bay, the replacement was for a non tilt tele so I dismantled both, selected the best parts from them to make a good cap.
The outer ring was stripped and sprayed satin black, the plastic button was faded so I cleaned off the painted back then repainted to colours and silver lines followed by black and it ended up like new, have to say I was well impressed with the result.
As the button was like new it put the rest of the collumn etc. to shame so I stripped that and gave that a coat of satin black, during the strip down I discovered a few Bubba mods which were put right for example the spring contact was assembled in the wrong order, the spring ring that the horn button clips into was all distorted, when it all went back together the refurbed button clipped nicely into place and I had a working horn again.
By the way as I had to drill the heads off the rivetted staks that held it together originally I used small blobs of Araldite to fasten it all back together.
All in I think it only cost about 30 to do, the horn button was cheap as the plastic centre was so faded but not cracked.
Graham
Graham, red 1970 convertible 350
eurovettes
CCCUK Supporting Vendor
Wed 10 Jan 18 01:24
Let me know if I can help- i ma in Californai till jan 23rd and can get small parts form ecklers/rock or others - of course I havea US-UK shipment as well end jan beginning of feb
cheers
keith
keef @ eurovettes.com
Reply to topic
Permissions
