CCCUK logo
 Lancaster Insurance
Website Control
Recent threads
New Forum Posts
» Spotted C2 by Jimbo64 on Mon 10 Dec 18 08:25
» Help with newly acquired 72 350 Auto by Jimbo64 on Sun 09 Dec 18 21:33
» How Many Miles Does Your Corvette Get Driven? by JonnyC4 on Sun 09 Dec 18 20:25
» Facebook page by fat_jogger on Sun 09 Dec 18 19:36
» O.m.g. by Redlevel on Sun 09 Dec 18 17:35
» Trimmer/upholsterer by roscobbc on Sun 09 Dec 18 17:15
» C5 Harmonic balancer wobbling! by therabster on Sat 08 Dec 18 22:02
» Bloodhound SSC by rayquayle on Sat 08 Dec 18 13:10
» My C8 Grump by Vetteheadtony on Sat 08 Dec 18 13:05
» C7 Z06 by MShaky on Fri 07 Dec 18 15:17
» Replacement head unit for US spec C6 by Young Bill on Fri 07 Dec 18 10:10
» Kelsey Hayes Aluminum Wheels by Daytona Vette on Thu 06 Dec 18 01:05
» Thames Vally Region trip to Studio 434 by Nicetie on Wed 05 Dec 18 22:33
» C6 LED halos by autocolor on Wed 05 Dec 18 19:20
» Another day, another Mid-Engine Corvette thread by Norm on Wed 05 Dec 18 19:05
» 2007 C6 ZO6, Manual. by Fraser on Wed 05 Dec 18 15:50
» 2019 Nationals by curious bystander on Wed 05 Dec 18 11:15
» What did you do with your Vette today? by FelixP on Wed 05 Dec 18 10:36
» Replacing Fuel Filter by robbiew on Tue 04 Dec 18 18:28
» South Central Breakfast Club by Daytona Vette on Mon 03 Dec 18 12:52
» Differential Rebuild by Nick B on Sun 02 Dec 18 18:51
» Trans fluid by Nigelcurry on Sun 02 Dec 18 12:28
» wheels by robbiew on Sun 02 Dec 18 09:25
» The EVENTS CALENDAR by kentvette on Sat 01 Dec 18 15:25
» 1982 Collectors Edition by kentvette on Sat 01 Dec 18 15:23
» Magazine Purchase? by roscobbc on Sat 01 Dec 18 10:19
» 1976 ''Spirit of Le Mans'' Corvette by Atomic UK on Thu 29 Nov 18 18:00
» Speedo not working by kentvette on Thu 29 Nov 18 16:29
» International Corvette & Camaro Meeting 2019 - 20th Anniversary by Alexa-Italy on Wed 28 Nov 18 09:40
» Why did you buy your corvette by Wacjac on Tue 27 Nov 18 20:46
Zo6 lost all power
Go to page: 1, 2, 3, 4, 5 / Next
Reply to topic
Author
Message
Fraser
Club Member
Fri 03 Nov 17 10:08
Zo6 lost all power
Hi, my 2006 zo6. Came to start it the other day and no power at all. Had it on trickle charge. Full charge and still nothing. Put some jump leads on it and nothing. All it does when you push start it make some weird crackle noise. Not a clicking, more of a faint Crackle.
Anyone had this happen before? What should I try?
Thank you.
z06_tim
Club Member
Fri 03 Nov 17 10:25
Oh dear. Sorry to hear this.
Have you tried doing an OBD diagnostic to see what fault codes are reported? This is easy to do on the instrument cluster of a C5, but I believe not so easy on a C6.
Other than that, I'm struggling to give a good suggestion for the "weird crackle noise" you experience. Is this lack of fuel or lack of spark, I'm not so sure.
First suggestion with these cars is usually to make sure your electrical system is tip/top. Sounds like you may have had a low battery, so although you recently charged, is it giving a strong enough voltage? Is it above 12.6V after a short rest period from charging, and with everything off. Also check condition of earthing.
2001 Z06, 1994 LT1 (sold)
Alfa 147 GTA daily driver.
Redlevel
Club Member
Fri 03 Nov 17 11:12
Re: Zo6 lost all power
Fraser wrote (View Post):Hi, my 2006 zo6. Came to start it the other day and no power at all. Had it on trickle charge. Full charge and still nothing. Put some jump leads on it and nothing. All it does when you push start it make some weird crackle noise. Not a clicking, more of a faint Crackle.
Thank you.
Could still be battery.. How do you know the battery's taking a full charge?
A flat battery can still show a decent voltage yet be totally gutless and collapse when you try to use it and be so empty that it sucks all the energy from the jump start battery.
If you try jumping it again, disconnect your own battery first and make sure the jumper battery is well connected. Keep an eye on the cables and if it still doesn't crank and they get hot, stop as you have a problem elsewhere.
Good luck..
chevrolet
Club Member
Fri 03 Nov 17 11:55
How old is the battery?/Is the car used regularly, and put on trickle charger/conditioner when not?
What car/battery (CCA rating?) did you attempt to jump start it with (without success)? If it was from the missuses Peugeot 206, that may not have enough juice/CCA to turn it over/start it.
When my Optima red top gave up the ghost a few months back, my portable battery back, which will jump start most things, didn't have enough juice to turn over/start the C6.
Presuming also that when you tried to jump start it, you connected up as per the handbook instructions (one of the leads attaches to the fuse box connection)?
AKA "Silver C6" on Pistonheads
Fraser
Club Member
Fri 03 Nov 17 13:16
Hi cheers for the help!
Iíve left the battery on trickle for 24hrs.
Someone pinched my multi meter so canít chec the voltage.
Connected the jump lead like in the manual to my Audi Q7.
Left running for a while but still nothing. Fob wonít even unlock the car.
Car only used at weekends really.
Maybe a new battery?
Gixer
Club Member
Fri 03 Nov 17 14:53
New battery. If the fobs aren't working either then get s new battery.
Try Tanya.co.uk
Black 2008 C6 Z06
Haibeck 368ci 530hp ZR1
Movit brakes
4:10 Rear Gears
Doug Rippie suspension
#1281
www.corvetteclips.co.uk
UK Country Dir. ZR1netRegistry.
chevrolet
Club Member
Fri 03 Nov 17 16:29
The doors won't unlock/lock using the fob(s)?. So presume also, the door(s) won't open manually either, and if they do, the interior lights are faint or non-existant? If they don't open, you have used the emergency key in the rear hatch and emergency pull to open the door?
Sounds like the battery has given up, as mine did a few months back (and your trickle charger is giving false readings?). It will make the "crackle noise," if there is a bit of activity from the battery, but not enough to turn the engine over.
As Gixer says, new battery from Tayna sounds in order. If you buy an Optima Red Top, don't discard the red plastic tray on the bottom. It's not packing/goes in the battery tray in the car.
Fraser
Club Member
Fri 03 Nov 17 16:30
Ordered a new battery. Same as whatís in ther - optima red top.
Tried to start it holding multimeter accross the battery. 12.4V. And didnít drop much at all when tried to start.
Opened up the bonnet while my mate pressed start and heard a clicking noise. From around the fuse box area...
Anyway ordered new battery so will try that first! Thanks
BlackZeD
Club Member
Fri 03 Nov 17 17:11
It could be the connection to the starter as well.
If thats bad it usually stops it starting and gives loads of gremlins as well.
Does sound like a dead battery though.
I have steered away from Optima now. Have had a re and a yellow top in mine.
1 year warranty sucks, have a Yuasa from Halfords, cheaper than Optima and
5 year warranty.
Dave.
z06_tim
Club Member
Fri 03 Nov 17 17:24
Almost certainly just needs a new battery. Red top Optimas may not like regular discharge cycles tho. i.e not using for long periods. Better to keep on a trickle charger probably.
Yellow top may be more tolerant of long periods of no use, and may recover better when re-charging from flat. This is a deep cycle battery.
Reply to topic
Permissions
