CCCUK logo
 Lancaster Insurance
Website Control
Recent threads
New Forum Posts
» Wanted: C5 front wheels, set of 4... by gavinfdavies on Fri 18 Jan 19 00:58
» Best tyres for the C5? by Ph300zx on Thu 17 Jan 19 17:47
» battery charging by Invetterate on Thu 17 Jan 19 17:00
» What did you do with your Vette today? by kentvette on Wed 16 Jan 19 15:52
» Drifting your Corvette by Fishy Dave on Wed 16 Jan 19 11:34
» Earls Barton Classic car and bike Meet by Nicetie on Fri 11 Jan 19 15:43
» Sywell Pistons & Props by Nicetie on Fri 11 Jan 19 15:42
» Kop Hill Hillclimb by Nicetie on Fri 11 Jan 19 15:41
» AACI Open Nationals at Billing Aquadrome by Nicetie on Fri 11 Jan 19 15:40
» Raunds festival of Transport by Nicetie on Fri 11 Jan 19 15:38
» NSRA Supernationals by Nicetie on Fri 11 Jan 19 15:35
» Silverstone Classics by Nicetie on Fri 11 Jan 19 15:33
radiator bleeding
Reply to topic
Author
Message
mutley
New Comer
Tue 07 Nov 17 15:08
radiator bleeding
Hi peeps
Can any of you enlighten me on the proceedure for bleeding the coolant system on a l98 1988
since i changed my rad my temp has been running a little high . Ive done the head gasket check its good . It used to cut in at 178 and drop it to 164 now it stays up in the early 200's and goes up to 220 if i rev it hard but soon comes back down to 200 . the fan is staying on all the time after getting hot as it is in the range of when it should cut in
ill be grateful for any advice
Mutley
go on then small dick pass me
Redlevel
Club Member
Tue 07 Nov 17 17:02
Re: radiator bleeding
Hi..
Just did mine and this is what works for me..
You have air in the system somewhere, and what you could do is park the car facing an bit of an uphill to allow the air to gather at the top of the rad easier.
Then, from cold, start the motor and remove the radiator cap and top it up. Stuff an old towel around the neck of the rad and watch as the motor heats up. It'll bubble and spill out a bit, but hang in there, and after a minute or so, the level in the radiator will suddenly and dramatically drop significantly as the thermostat opens and this is the time to quickly top up the radiator again so have your coolant standing by and plenty of it.
Keep on it until your sure that you can't get anymore coolant in and then refit the cap and let it heat up proper. After this, it should run a bit cooler and you can periodically check the level as I doubt you'll get all the air out first go.
Good luck.. Smile
mutley
New Comer
Wed 08 Nov 17 04:22
thanks Steve
will do it tomorrow bless ya pal
Club Member
Wed 08 Nov 17 10:40
Good tip Steve, I never thought of that "park the car facing an bit of an uphill"
Barry - Daytona Vette
Reply to topic
Permissions
