CCCUK logo
 ShipMyCar.co.uk
Website Control
Recent threads
New Forum Posts
» Birdcage repair by L88 on Wed 17 Oct 18 10:04
» C3 Hooker Side Pipe headers by L88 on Tue 16 Oct 18 22:17
» C3 Side Exhaust Pipes by icandycanvas on Tue 16 Oct 18 20:52
» Wiper actuator on a 69L by Ddave on Tue 16 Oct 18 18:36
» What did you do with your Vette today? by Ddave on Tue 16 Oct 18 18:08
» Le Mans 2019 by kentvette on Tue 16 Oct 18 17:55
» Tips by CaptainK on Tue 16 Oct 18 13:44
» Im interested in a C5 Z06 (this time next year) by Benbay001 on Tue 16 Oct 18 12:55
» Engine cutting out after firing up by Firepit on Tue 16 Oct 18 09:19
» A trio of C2 owners. by yenko 1969 on Mon 15 Oct 18 21:38
» Thinking About Hanging Them Up....... by Norm on Mon 15 Oct 18 15:44
» BBCN Regional meet by Nicetie on Mon 15 Oct 18 12:57
» C5 O2 sensor code?? by roppa440 on Mon 15 Oct 18 08:45
» C2 fibreglassing and prep. by L88 on Sun 14 Oct 18 17:16
» Spec lists by Jimbo64 on Sun 14 Oct 18 15:36
» Road Atlanta this weekend. by UkBeancounter on Sun 14 Oct 18 14:29
» New Series of Wheeler Dealers an 02 Z06?? by dex99 on Sun 14 Oct 18 12:02
» Door removal on 79 coupe by Nigelcurry on Sat 13 Oct 18 20:01
» American Day - Museum of Power Essex by Forrest Gump on Sat 13 Oct 18 17:44
» C5 Performance Projects - book by robbiew on Fri 12 Oct 18 21:19
» Help with newly acquired 72 350 Auto by Jimbo64 on Fri 12 Oct 18 18:15
» speed bleeders by Grahamred70 on Fri 12 Oct 18 16:17
» South Central Regional Meeting and Midlands-ish Breakfast Club - October by Daytona Vette on Fri 12 Oct 18 10:44
» Essex Regional meeting by roscobbc on Fri 12 Oct 18 08:36
» 1972 Washer bottle wanted by Vetteheadtony on Thu 11 Oct 18 22:48
» Vette Hire In The U.S. by 86vetteman on Thu 11 Oct 18 20:33
» South Central Mids Supper Club Meet by Daytona Vette on Wed 10 Oct 18 07:29
» CCCUK West Sussex meeting in October by robbiew on Tue 09 Oct 18 19:11
» You Like Shine? I Like Shine....... by Norm on Mon 08 Oct 18 19:21
» FOR SALE - C6 MODIFIED STANDARD EXHAUSTS – louder than stock by Rich on Mon 08 Oct 18 17:20
Spark Plugs - 1968 327
Reply to topic
Author
Message
Club Member
Tue 07 Nov 17 16:52
Hello all. I've been searching the internet and on the forums for the spark plugs I need for my 1968 327/300hp Corvette (original engine), and just found tons of different plug numbers and some saying that a 1968 327 doesn't exist.
So I thought I'd give in and ask here in case any of you know good plugs or part numbers for the 1968 327. The engine isn't particularly fancy or highly modified - just aftermarket carb and manifold. From reading the threads on here, some say Champion plugs, other say NGK.
Ideally from a UK seller please. Thanks Smile
Club Member
Tue 07 Nov 17 19:28
Re: Spark Plugs - 1968 327
My manual says AC44.
I looked at The Green Spark Plug Co. They seem to do 44.5. But, I found the NGK equivalent is B6S and they have that.
http://www.gsparkplug.com/1x-ngk-copper-core-spark-plug-b6s-...
Highly recommend GSPC, very reasonable price and speedy delivery. Plus, if you want to be sure, you can choose your plugs by size, length, contact size etc etc....
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
Chris Sale
Club Member
Wed 08 Nov 17 00:21
I agree with Stephen's recommendation. I have been using NGK B6S for many years in my '64 which also has the 300 HP 327. My annual mileage runs between 4000 - 5000 miles and I change plugs every two years.
If, after you have put a few thousand on your first set of B6S you think you could go to a hotter plug in some cylinders, you can install BP5S which are one 'range' hotter and have a projected tip. My No. 8 plug has always been prone to fouling before the others, presumably because of oil getting past the valve stem seals, and a BP5S stays clean for longer.
Chris Sale
CCCUK 436
NCRS 11971
'64 Coupe
roscobbc
Wed 08 Nov 17 01:25
Agree with Chris - I use NGK's on my big block, and yes generally replace every two seasons or when misfires start-up. I changed to BCPR6's to try and cure plugs going 'open circuit' with the 7's (it did improve - and these are resistor plugs which I believe are easier to source from local autofactors) - in my case plug fouling is caused by a combination of prolonged city use coupled with the rich idle mixture needed with a rumpity - rumpity camshaft and big double pumper carb. Even the super powerful spark from a MSD system has its limitations Yes
CCCUK Chairman
Club Member
Wed 08 Nov 17 08:43
Thanks everyone. When I did a search on the forum I found multiple references to the Green Spark Plug co, but I didn't know which plugs I needed. Tried to look at other sites to cross reference and just ended in a pickle.
I'll get some ordered soon, as the engine isn't particularly happy with life, and I'm changing the carb and inlet soon, along with the dist and leads and figured I may as well change the plugs too. Problem is, I believe to change the plugs you need to remove the exhaust manifolds, and I was thinking of replacing my exhaust manifolds with a better set, so I'll be on a big parts buying session soon.
Thanks.
jmvette
Addict
Wed 08 Nov 17 18:18
I
Club Member
Fri 10 Nov 17 12:55
Well, the Green Spark Plugs co seems very efficient - I ordered them shortly after my comment above and they arrived the next day. Well done GSPCo. Smile
Reply to topic
Permissions
