 Ian Allan Motors
» 1978 C3 Corvette Silver Anniversary L82 Automatic by geoff917 on Fri 20 Jul 18 17:08
» International Corvette & Camaro Meeting 2019 - 20th Anniversary by Alexa-Italy on Fri 20 Jul 18 16:31
» New member in Retford, Notts.......! by IbanezDan51 on Fri 20 Jul 18 11:21
» A rather fast C2 vette by Invetterate on Fri 20 Jul 18 08:10
» Valkenberg - A Beschi family tribute by JonnyC4 on Thu 19 Jul 18 20:48
» Vulcan Tour 2018 by Bowler on Thu 19 Jul 18 12:58
» C5 Z06 centre caps? by yenko 1969 on Thu 19 Jul 18 11:11
» 15x8 OEM Rally wheels by Ddave on Thu 19 Jul 18 08:44
» Silverstone Classic - 20/21/22 July 2018 by curious bystander on Thu 19 Jul 18 08:23
» Looking for a C6 Z06 by IbanezDan51 on Wed 18 Jul 18 23:56
» BBCN Regional Meet by Nicetie on Wed 18 Jul 18 22:58
» Buying a C6 Convertible.... Or more likely a Targa Top by chevrolet on Tue 17 Jul 18 22:18
» For Sale - C4 '84-'86 E (Early) Solid Roof by chevrolet on Tue 17 Jul 18 20:30
» Corvette-Fame 13-14-15 July 2018 by JonnyC4 on Tue 17 Jul 18 18:06
» Spare wheel kit 74 by BertieGas on Mon 16 Jul 18 23:40
» Developing Starter Issue by kentvette on Mon 16 Jul 18 18:41
» Shooting for 1000whp with my C7 @ Top Cats Racing by roppa440 on Mon 16 Jul 18 15:07
» Black '68 by Jan25 on Mon 16 Jul 18 10:23
» What did you do with your Vette today? by roppa440 on Mon 16 Jul 18 09:39
» Garage services required for a C3 in the NW by Daytona Vette on Sun 15 Jul 18 20:06
» NEC Classic Car Show - Birmingham by 86vetteman on Sat 14 Jul 18 22:39
» C4 coupe wanted by Redridge Corvette on Sat 14 Jul 18 21:54
»  by Nosheruk on Sat 14 Jul 18 17:44
» How to post a photo in the forums by Nosheruk on Sat 14 Jul 18 17:38
» New member, new c3 on order! by Forrest Gump on Sat 14 Jul 18 12:06
» C5 seat refurbishment by roscobbc on Sat 14 Jul 18 09:29
» Classic + Vintage Vehicle Festival - Peterborough by curious bystander on Fri 13 Jul 18 17:35
» R/H door lock mech and clip by MIT on Fri 13 Jul 18 16:53
» What modern spark plugs for 1973 454? by roscobbc on Fri 13 Jul 18 00:43
» Insurance by MIT on Thu 12 Jul 18 21:44
What does this wire do / connect to?
Go to page: 1, 2 / Next
Fri 10 Nov 17 13:03
Hello all. 1968 with a 327 engine. All standard engine etc.
Was looking in my engine bay yesterday and noticed something I hadn't seen before - a wire coming out from the main red / positive alternator cable.
The wire has a small spade connector on the end of it and the end of it was tucked up underneath my driver's side exhaust manifold. I'm guessing it was connected to nothing, as there seems to be nothing in that area for it to connect to - but I'm surprised that with it being a "positive" cable that it hasn't tapped up against the engine and shorted itself out..... :O
See attached pic. I've put yellow arrows pointing to the wire in question, but if not, its the thin wire coming from the bottom left of the pic where it connects to the main positive cable to the alternator. For the benefit of the picture I ran it out over the steering box so you could see it, but it was tucked up underneath the manifold above the two spark plugs in the middle of the photo.
Fri 10 Nov 17 15:03
Re: What does this wire do / connect to?
Is your water Temp gauge working, looks like the wire that connects to the sensor
Barry - Daytona Vette
Fri 10 Nov 17 15:09
I'd go with Barry's suggestion. The sender is tucked up under the manifold, slightly forward of the exhaust down-pipe and tricky to see. If it's like mine, the original spade is pretty loose on the connector - I fitted a new spade with an insulating shroud.
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
Fri 10 Nov 17 15:38
By any chance do you mean this funny looking thing that is tucked up under the manifold? I couldn't see it un-aided, so I shoved the camera up there. Just for the benefit of location, that is between the first and second plugs from the left when looking at the driver's side of the engine.
Aka alternator just off screen, then first plug from left, then funny looking thing with no spade connector, then second plug from left, then the exhaust manifold downshaft just to the right hand side of the photo.
Problem is, I can't see how a spade connector attaches to it Confused
Mick Howes
Fri 10 Nov 17 16:50
Hi, that looks like the modded type, when I had my 79 C3, the original sensor failed and I got one that looked like this. The only way I could attach the connector was by using one of those open ended connectors (the horse shoe type), then crimp it is as tight as possible, and yes I kinow, it's in a real bugger of a place to get at, really a job done from underneath, have fun!
C4- ok now officially a convert!
www.mickhowes.freewebspace.com
Fri 10 Nov 17 18:05
It simply slides on, try it first and then if it is a tad loose compress the spade connector a very slight amount and try again until you have a more secure fit
Fri 10 Nov 17 18:22
Oooer! That doesn't look like mine. Very Happy Interesting how different the 327 is from the 350. Looks as though the spade would just slide on, but at 90 degrees to the normal way?
Stephen J Irons
NCM Family Member
Apple IS Genisys!
roscobbc
Fri 10 Nov 17 18:30
The 'spade' connector shown in the first image simply slides over the raised head of the temperature sender - it is at 90 degrees to the vertical - i.e it slides on sideways. If loose squeeze the connector slightly with a pair of pliers. Question is - does the sender work? - does the temperature gauge in the dash work?
CCCUK Chairman
gtr1999
Addict
Sun 12 Nov 17 15:50
The wiring has been spliced, it was originally a green wire I believe. I would peel it back to see if it's the green wire and then make a good splice with good connections. The switch is the temp sender and is in the correct place- LH side of the head, some guys put them in the intake but you will get a false reading there many times.
I would also look at the wires with the car running, I see them crossed and that can lead to misfire, in the dark at night you might see them arcing.
Gary R
69 'Vert 350 4 spd 373's
72 Coupe 350 TH400 336
75 Coupe 350(400hp)4 spd 373 12bolt,3.5" shafts, 31 spline outer axles.
Building vettes the past 40 years!!!!!
Mon 13 Nov 17 09:22
Well done team - yup, it is the coolant sensor and yes the spade connector does fit. Its just a bit loose, but I managed to get it back on. The coolant gauge had previously worked (and still does) but when I was checking the oil and so forth I must have just knocked that wire a bit to make it come off.
I see above concern about the plug leads and so forth. Don't panic, I've already ordered a new distributor and leads and plugs. I'm intending on having an overhaul over winter as to be honest I have no idea when these were last changed (I imported it from America, but the service history seems to have disappeared!). The wiring around the car does seem to be a bit odd here and there, so I'm intending on doing a bit of wiring changes too.
Talking of wiring - does anyone know why my battery has two wires connected to the positive terminal? Obviously I know what the the big thick cable is, but there is a very thin small wire (which is the same "thickness" as the coolant temp sensor wire pictured above) coming off the positive terminal too. It goes immediately towards the front of the car to the car structure border than resides between the driver's seat and battery box and then disappears into it. I have no idea where it goes or what it does :-S
