CCCUK logo
 ShipMyCar.co.uk
Website Control
Recent threads
New Forum Posts
» London Classic Car Show - 15th-18th February 2018 by Rich on Sat 17 Feb 18 18:58
» Faulty time clock by Nigelcurry on Sat 17 Feb 18 18:20
» BBCN Region February meet at Meguires by alan on Sat 17 Feb 18 18:13
» Action shots! by UkBeancounter on Sat 17 Feb 18 16:36
» RockAuto.com Discount Code for Parts & More - Expires April 4, 2018 by FIVE RED on Sat 17 Feb 18 14:02
» Le Mans 24 Hour by curious bystander on Sat 17 Feb 18 11:58
» c5 or c3??? by roppa440 on Sat 17 Feb 18 07:42
» Rear spring by kentvette on Fri 16 Feb 18 16:18
» Wheel Alignment by Richard J on Fri 16 Feb 18 08:01
» What do you carry? by roscobbc on Fri 16 Feb 18 00:56
» What did you do with your Vette today? by FIVE RED on Thu 15 Feb 18 16:24
» New road tax regs.. by roppa440 on Thu 15 Feb 18 13:03
» Classic Americans at Helicopter Museum- Weston-super-Mare by CaptainK on Thu 15 Feb 18 10:07
» Removing center clocks console on 1979 by kentvette on Tue 13 Feb 18 15:21
» Classic Car Show- Helicopter Museum Weston-super-Mare by CaptainK on Tue 13 Feb 18 11:59
» steel wheels by steve on Mon 12 Feb 18 21:24
» Now we're digital - Membership Renewals by Wacjac on Mon 12 Feb 18 21:23
» C3 Free Stuff by phild on Mon 12 Feb 18 17:35
» Classic Car Weekly Photo-shoot Request by Vette T-Shirt on Mon 12 Feb 18 11:46
» 2000 millennium yellow C5 coupe for sale by jukebox on Mon 12 Feb 18 10:19
» Proper rolling road / dyno tune by CaptainK on Mon 12 Feb 18 09:51
» Films with Corvettes in? by CaptainK on Mon 12 Feb 18 09:49
» Suhl 2018 by C6NL on Sun 11 Feb 18 13:49
» Vintage Motorsport Festival - Cadwell Park by curious bystander on Sat 10 Feb 18 17:15
» Red c5 cab red leather interior ebay by Celcius on Sat 10 Feb 18 10:06
» Head gasket problems by Coltstingray on Fri 09 Feb 18 16:06
» Vintage Motorsport Festival - Oulton Park by curious bystander on Fri 09 Feb 18 15:57
» C3 headlights . by kentvette on Fri 09 Feb 18 10:36
» Insurance recommenations by gary 53 on Fri 09 Feb 18 08:00
» Service parts ID sticker by gary 53 on Thu 08 Feb 18 21:49
What does this wire do / connect to?
Go to page: 1, 2 / Next
Reply to topic
Author
Message
Club Member
Fri 10 Nov 17 12:03
Hello all. 1968 with a 327 engine. All standard engine etc.
Was looking in my engine bay yesterday and noticed something I hadn't seen before - a wire coming out from the main red / positive alternator cable.
The wire has a small spade connector on the end of it and the end of it was tucked up underneath my driver's side exhaust manifold. I'm guessing it was connected to nothing, as there seems to be nothing in that area for it to connect to - but I'm surprised that with it being a "positive" cable that it hasn't tapped up against the engine and shorted itself out..... :O
See attached pic. I've put yellow arrows pointing to the wire in question, but if not, its the thin wire coming from the bottom left of the pic where it connects to the main positive cable to the alternator. For the benefit of the picture I ran it out over the steering box so you could see it, but it was tucked up underneath the manifold above the two spark plugs in the middle of the photo.
Club Member
Fri 10 Nov 17 14:03
Re: What does this wire do / connect to?
Is your water Temp gauge working, looks like the wire that connects to the sensor
Barry - Daytona Vette
Club Member
Fri 10 Nov 17 14:09
I'd go with Barry's suggestion. The sender is tucked up under the manifold, slightly forward of the exhaust down-pipe and tricky to see. If it's like mine, the original spade is pretty loose on the connector - I fitted a new spade with an insulating shroud.
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
Club Member
Fri 10 Nov 17 14:38
By any chance do you mean this funny looking thing that is tucked up under the manifold? I couldn't see it un-aided, so I shoved the camera up there. Just for the benefit of location, that is between the first and second plugs from the left when looking at the driver's side of the engine.
Aka alternator just off screen, then first plug from left, then funny looking thing with no spade connector, then second plug from left, then the exhaust manifold downshaft just to the right hand side of the photo.
Problem is, I can't see how a spade connector attaches to it Confused
Mick Howes
Club Member
Fri 10 Nov 17 15:50
Hi, that looks like the modded type, when I had my 79 C3, the original sensor failed and I got one that looked like this. The only way I could attach the connector was by using one of those open ended connectors (the horse shoe type), then crimp it is as tight as possible, and yes I kinow, it's in a real bugger of a place to get at, really a job done from underneath, have fun!
C4- ok now officially a convert!
www.mickhowes.freewebspace.com
Club Member
Fri 10 Nov 17 17:05
It simply slides on, try it first and then if it is a tad loose compress the spade connector a very slight amount and try again until you have a more secure fit
Club Member
Fri 10 Nov 17 17:22
Oooer! That doesn't look like mine. Very Happy Interesting how different the 327 is from the 350. Looks as though the spade would just slide on, but at 90 degrees to the normal way?
Stephen J Irons
NCM Family Member
Apple IS Genisys!
roscobbc
Fri 10 Nov 17 17:30
The 'spade' connector shown in the first image simply slides over the raised head of the temperature sender - it is at 90 degrees to the vertical - i.e it slides on sideways. If loose squeeze the connector slightly with a pair of pliers. Question is - does the sender work? - does the temperature gauge in the dash work?
CCCUK Chairman & Editor, Vette News
gtr1999
Addict
Sun 12 Nov 17 14:50
The wiring has been spliced, it was originally a green wire I believe. I would peel it back to see if it's the green wire and then make a good splice with good connections. The switch is the temp sender and is in the correct place- LH side of the head, some guys put them in the intake but you will get a false reading there many times.
I would also look at the wires with the car running, I see them crossed and that can lead to misfire, in the dark at night you might see them arcing.
Gary R
69 'Vert 350 4 spd 373's
72 Coupe 350 TH400 336
75 Coupe 350(400hp)4 spd 373 12bolt,3.5" shafts, 31 spline outer axles.
Building vettes the past 40 years!!!!!
Club Member
Mon 13 Nov 17 08:22
Well done team - yup, it is the coolant sensor and yes the spade connector does fit. Its just a bit loose, but I managed to get it back on. The coolant gauge had previously worked (and still does) but when I was checking the oil and so forth I must have just knocked that wire a bit to make it come off.
I see above concern about the plug leads and so forth. Don't panic, I've already ordered a new distributor and leads and plugs. I'm intending on having an overhaul over winter as to be honest I have no idea when these were last changed (I imported it from America, but the service history seems to have disappeared!). The wiring around the car does seem to be a bit odd here and there, so I'm intending on doing a bit of wiring changes too.
Talking of wiring - does anyone know why my battery has two wires connected to the positive terminal? Obviously I know what the the big thick cable is, but there is a very thin small wire (which is the same "thickness" as the coolant temp sensor wire pictured above) coming off the positive terminal too. It goes immediately towards the front of the car to the car structure border than resides between the driver's seat and battery box and then disappears into it. I have no idea where it goes or what it does :-S
Reply to topic
Permissions
