CCCUK logo
 ShipMyCar.co.uk
Website Control
Recent threads
New Forum Posts
» A road trip to Ireland - from the Sharnbrook Hotel (CCCUK Nats. HQ) by curious bystander on Tue 23 Jan 18 22:39
» Vinyl hardtop by Grahamred70 on Tue 23 Jan 18 21:17
» Breakfast Club Meet FEBRUARY by Barry scard on Tue 23 Jan 18 18:05
» Sunday Scramble - Bicester Heritage Centre by Bowler on Tue 23 Jan 18 14:14
» Le Mans 24 Hour by 7YEL on Tue 23 Jan 18 13:00
» Was this a thing?? by Daytona Vette on Tue 23 Jan 18 10:55
» Leeds Castle Motors by the Moat Sunday 13th May 2018 by 7YEL on Mon 22 Jan 18 13:47
» BBCN Region January Meet by oldtimer on Mon 22 Jan 18 13:42
» Concours of Elegance by 7YEL on Mon 22 Jan 18 13:14
» Electric Question by Daytona Vette on Mon 22 Jan 18 13:03
» Black '68 by CaptainK on Mon 22 Jan 18 11:41
» C3 headlights . by Chuffer on Mon 22 Jan 18 10:45
» Query on C5 TPM sensor nut torque setting by roppa440 on Mon 22 Jan 18 09:51
» Who to use? by roscobbc on Sun 21 Jan 18 20:45
» BBCN Region February meet at Meguires by autocolor on Sun 21 Jan 18 09:56
» New Exhaust System by eurovettes on Sat 20 Jan 18 20:56
» 5 German Corvette on a North England trip in May by HGW on Sat 20 Jan 18 15:23
» 1976 C3 5.7L Auto For Sale by born2bmild on Sat 20 Jan 18 14:04
» About to buy a C6 by Fishy Dave on Fri 19 Jan 18 22:46
» Steering Wheel Position Sensor - Reset? by Le Vette on Fri 19 Jan 18 17:21
» Zo6 lost all power by Fraser on Fri 19 Jan 18 14:19
» iva test by hoo-raa-boy on Thu 18 Jan 18 18:19
» Classic Car + Autojumble - Hampshire by curious bystander on Thu 18 Jan 18 18:12
» Tyres for Corvette C6 Grand Sport 2011 by BlackZeD on Thu 18 Jan 18 15:36
» C5 Interior Re-Trim by Invetterate on Thu 18 Jan 18 13:32
» BBCN Region January Meet by Nicetie on Thu 18 Jan 18 13:03
» Ordering Spares From The States by FIVE RED on Wed 17 Jan 18 21:09
» [ KB ] C4 Windshield Wiper Adjustments by Ben on Wed 17 Jan 18 19:25
» Steve Cauldwell - DART Corvette by curious bystander on Wed 17 Jan 18 17:16
» C5 wipers go off the screen! by z06_tim on Wed 17 Jan 18 13:21
SBC engine
Go to page: 1, 2, 3 / Next
Reply to topic
Author
Message
Dellb
Club Member
Sat 02 Dec 17 17:39
SBC engine
Hi All
At last I got round to firing up the beast after rebuild of engine. Alas all is not well.
The engine fires up fine and oil pressure is fine, but it is very difficult to keep going, and is heaving out clouds of black smoke.
The carb is a Holley 4160, and I have overhauled it with new Holley parts etc. Float levels are fine, and I canít find anything amiss with the carb. There is no backfiring through the carb and I think the timing is ok.
Anybody out there had similar probs?
Delb
Derek L G
sssammm
Club Member
Sat 02 Dec 17 18:27
Have you got the right needles?
2013 Z06 White, 1953 Chevy 3100
stevel98
Awww... join the CCCUK!
Sat 02 Dec 17 19:10
Re: SBC engine
Black smoke usually means its very rich, either too much fuel or not enough air. If so, I wouldn't expect it to spit back as it doesn't sound like its leaning out.
Plugs ok? Correct heat range?
Dellb
Club Member
Sat 02 Dec 17 20:14
Re: SBC engine
Plugs and timing are new and fine. Air filter is off for testing. I have onerhauled the carb, and fitted new joints and needle valves etc. The carb is modified to replace the secondary metering plate with a metering block. Primary jets are 72, and secondary jets are 79. The engine is a 400 with a very serious cam. The engine ran fine when I bought the car albeit with a bent crank. There was no smoke, and the idle was lumpy due to the cam.
Derek L G
roscobbc
Sat 02 Dec 17 23:52
Re: SBC engine
What hg are power valves (4.5hg?) Big cam means low vacumn - low vacumn means stock power valves will flood engine with too rich mixture at low rpm. Use 1.5hg. (Might be other way around - it's getting late!)
CCCUK Chairman & Editor, Vette News
aaroncorvette
Club Member
Tue 05 Dec 17 07:48
Could be the choke? Manual or auto choke?
'71 vette convertible + the odd mod.
I thought we won the war?
roppa440
Club Member
Tue 05 Dec 17 09:50
Re: SBC engine
Same old story.
You need a lot of initial advance with a big cam.
Once you have that and the idle speed right you can measure the manifold vacuum and fit a power valve rated 2-inches of vacuum below that.
With the correct timing the engine will be only running on the idle mixture circuits. Currently the throttle blades will be open too far for the idle circuit to work. You are trying to idle on the main jets and probably a stock 6.5" power valve fluttering away.
To get the high initial advance (probably around 20-25 degrees) without increasing the total (mechanical only) advance (36 degrees) you either need to connect the distributor vacuum can to manifold vacuum instead of ported OR, if you don't have vacuum advance on the dizzy or enough vacuum, modify the distributor to limit the amount of mechanical advance it gives to about 10 degrees.
You will thank me for it.
stevel98
Tue 05 Dec 17 11:11
Re: SBC engine
Excellent solution as usual, Dave.. Thumbs up
We've all been waiting for this, ..what kept you? Very Happy
roppa440
Club Member
Tue 05 Dec 17 11:20
Re: SBC engine
stevel98 wrote (View Post):Excellent solution as usual, Dave.. Thumbs up
Mainly a few worrying hospital appointments. Rolling Eyes
But it looks like I am not going anywhere in a hurry.
stevel98
Tue 05 Dec 17 12:28
Re: SBC engine
Not good.. Sad
Hope your going to be ok and not have to swap your C5 for an SUV. Rolling Eyes
Reply to topic
Permissions
