CCCUK logo
 Ian Allan Motors
Website Control
Recent threads
New Forum Posts
» Black '68 by Ddave on Sun 22 Jul 18 22:04
» Shooting for 1000whp with my C7 @ Top Cats Racing by 5 USA on Sun 22 Jul 18 20:38
» BBCN Regional Meet by autocolor on Sun 22 Jul 18 08:50
» A rather fast C2 vette by Vetteheadtony on Sat 21 Jul 18 21:37
» Damn Yankees Summer Slam - North Weald by Vetteheadtony on Sat 21 Jul 18 21:32
» Vulcan Tour 2018 by 666Vette on Sat 21 Jul 18 18:54
» Is this 'The begining of the end' OR 'The end of the begining' ? by Daytona Vette on Sat 21 Jul 18 17:07
» Spare wheel kit 74 by MIT on Sat 21 Jul 18 13:44
» Silverstone Classic - 20/21/22 July 2018 by jukebox on Sat 21 Jul 18 12:56
» New member in Retford, Notts.......! by elv19.pn@outlook.com on Sat 21 Jul 18 09:11
» 1978 C3 Corvette Silver Anniversary L82 Automatic by geoff917 on Fri 20 Jul 18 17:08
» International Corvette & Camaro Meeting 2019 - 20th Anniversary by Alexa-Italy on Fri 20 Jul 18 16:31
» Valkenberg - A Beschi family tribute by JonnyC4 on Thu 19 Jul 18 20:48
» C5 Z06 centre caps? by yenko 1969 on Thu 19 Jul 18 11:11
» 15x8 OEM Rally wheels by Ddave on Thu 19 Jul 18 08:44
» Looking for a C6 Z06 by IbanezDan51 on Wed 18 Jul 18 23:56
» Buying a C6 Convertible.... Or more likely a Targa Top by chevrolet on Tue 17 Jul 18 22:18
» For Sale - C4 '84-'86 E (Early) Solid Roof by chevrolet on Tue 17 Jul 18 20:30
» Corvette-Fame 13-14-15 July 2018 by JonnyC4 on Tue 17 Jul 18 18:06
» Developing Starter Issue by kentvette on Mon 16 Jul 18 18:41
» What did you do with your Vette today? by roppa440 on Mon 16 Jul 18 09:39
» Garage services required for a C3 in the NW by Daytona Vette on Sun 15 Jul 18 20:06
» NEC Classic Car Show - Birmingham by 86vetteman on Sat 14 Jul 18 22:39
» C4 coupe wanted by Redridge Corvette on Sat 14 Jul 18 21:54
»  by Nosheruk on Sat 14 Jul 18 17:44
» How to post a photo in the forums by Nosheruk on Sat 14 Jul 18 17:38
» New member, new c3 on order! by Forrest Gump on Sat 14 Jul 18 12:06
» C5 seat refurbishment by roscobbc on Sat 14 Jul 18 09:29
» Classic + Vintage Vehicle Festival - Peterborough by curious bystander on Fri 13 Jul 18 17:35
» R/H door lock mech and clip by MIT on Fri 13 Jul 18 16:53
SBC engine
Go to page: Previous / 1, 2, 3 / Next
Reply to topic
Author
Message
roppa440
Club Member
Tue 05 Dec 17 14:13
Re: SBC engine
stevel98 wrote (View Post):Not good.. Sad
Hope your going to be ok and not have to swap your C5 for an SUV. Rolling Eyes
I'm just happy it's not a wooden box. Laughing
Club Member
Tue 05 Dec 17 14:24
Re: SBC engine
roppa440 wrote (View Post):stevel98 wrote (View Post):Not good.. Sad
You would not like that Dave! - Every time I have seen one of those on the road, they are never doing more than 5mph.
Barry - Daytona Vette
Redlevel
Club Member
Tue 05 Dec 17 17:07
Re: SBC engine
Sometimes at the mortuary here, its a Saab hearse that turns up to collect the deceased.
As if dying isn't bad enough! Sad
roppa440
Club Member
Wed 06 Dec 17 10:35
Re: SBC engine
stevel98 wrote (View Post):Sometimes at the mortuary here, its a Saab hearse that turns up to collect the deceased.
It's been like a mortuary on this forum lately I have noticed.
Back to the original post subject, I just want to add that the high initial advance will probably sort most of the problem by giving you enough rpm to get the throttle blades closed enough to pull the idle mixture circuit online. But sometimes with a very big can you will also need to drill a small hole in each throttle blade to get the RPM up enough. Starting at 0.5mm and going up in 0.5 steps until correct idle speed is achieved.
I have head Ross say "you have to run rich with a big cam to get it to idle". This is not actually true. It is down understanding how to best modify the distributor and carb to match the engine modifications.
Here are the readings from my 550hp 440 Chrysler when I had it. Idle mixture 14.2 rpm 880rpm, 9.1 inches of manifold vacuum.
roppa440
Club Member
Wed 06 Dec 17 10:37
Re: SBC engine
I have noticed there has been no response from the other experts on here.
roscobbc
Wed 06 Dec 17 11:05
Re: SBC engine
What I actually said was "low vacumn means stock power valves will flood engine with too rich a mixture at low rpm" i.e. HiPo cam usually means low intake vacumn. If using a carb (in this case 4160) the low vacumn will 'trick' the carb into thinking that it needs an enriched mixture and opening up the power valve (as it would under conditions of acceleration). Simply put - the OP needs to establish which power valve (valves) are installed in his carb before doing to much more.
CCCUK Chairman
roppa440
Club Member
Wed 06 Dec 17 11:30
Re: SBC engine
roscobbc wrote (View Post):What I actually said was "low vacumn means stock power valves will flood engine with too rich a mixture at low rpm" i.e. HiPo cam usually means low intake vacumn. If using a carb (in this case 4160) the low vacumn will 'trick' the carb into thinking that it needs an enriched mixture and opening up the power valve (as it would under conditions of acceleration). Simply put - the OP needs to establish which power valve (valves) are installed in his carb before doing to much more.
Gotcha. Thumbs up
roppa440
Club Member
Wed 06 Dec 17 11:44
Re: SBC engine
Just to add a couple of things for interest.
Main primary jets I adjust to around 13:1 mixture or just a touch leaner. I find this gives the best power and plug colour with modern fuel. In the old days we used to aim for 12.5:1 which seems too rich now.
If you have a Holley carb with metering plates instead of jets on the secondaries your only option used to be to drill the holes in the plates if they needed to me richer - making it a J-B Weld job if you want to go back the other way.
But Promax carbs came out with this neat metering plate that takes normal Holley jets. I used them on my 440 and they really take the guesswork (well some of it) out of secondary tuning.
roppa440
Club Member
Wed 06 Dec 17 11:48
Re: SBC engine
Also bear in mind that on an auto transmission car the mixture will be leaner and the rpm higher when idling in neutral. You need to tune the idle mixture in gear on an auto.
Dellb
Club Member
Fri 29 Dec 17 12:54
Re: SBC engine
Hi All
Many thanks for your advice, it worked. I have increased the secondaries, and decreased the primaries and she is fine, with the volume control screws now doing their job.
However another issue has raised its head that roppa440 touched on. The engine is fitted with a comp cam magnum 270. It is smoothest (vac disconnected) at an enormous amount of initial advance. 23 degrees. At this it is quite smooth and pulls 15 inches vacuum.
If I drop to the 15 degree norm, it becomes quite rough and the vacuum drops to 13 inches which is right on the limit of the 6.5 power valve. The current vacuum is taken off the carb. With the Mallory unilite distributor mechanical advance, the total advance is going to be unacceptable.
On another issue, I got a Gunson gastester as a Christmas present. My thoughts are, with a dual plane inlet manifold, how do you determine which control screw to adjust?
Any ideas?
Delb
Derek L G
Reply to topic
Permissions
