CCCUK logo
 Adrian Flux
Website Control
Recent threads
New Forum Posts
» Resto Vette - or - Modifed Vette by damc3 on Mon 24 Sep 18 21:47
» Ace cafe all American cruise by MIT on Mon 24 Sep 18 20:30
» DeLorean DMC-12 with LS3 480 by Devil Denis on Mon 24 Sep 18 18:36
» C8 is Coming by Redlevel on Mon 24 Sep 18 11:32
» l/h rear brake caliper wanted by damc3 on Mon 24 Sep 18 00:01
» 2008 z06 jacking pucks. by Norm on Sun 23 Sep 18 20:41
» Failed oil pump drive by roscobbc on Sun 23 Sep 18 20:21
» C3 that are in UK 1968-73 with chrome bumpers pics please! by L88 on Sat 22 Sep 18 19:11
» Amazing by MIT on Sat 22 Sep 18 11:07
» Spare wheel light by PAZ9556 on Fri 21 Sep 18 19:35
» '95 C4 with LT1 missfire by corvetteville on Fri 21 Sep 18 18:42
» 1989 C4 For Sale by RickyG512 on Fri 21 Sep 18 14:28
» C7 Configurator by c6pete on Thu 20 Sep 18 12:46
» C2 fibreglassing and prep. by L88 on Wed 19 Sep 18 20:50
» What did you do with your Vette today? by FelixP on Wed 19 Sep 18 13:44
» Potential new C5 owner - some basic questions by Le Vette on Tue 18 Sep 18 14:09
» My 01 c5 yellow for sale by Celcius on Sun 09 Sep 18 20:58
SBC engine
Go to page: Previous / 1, 2, 3
Reply to topic
Author
Message
roscobbc
Fri 29 Dec 17 13:17
Re: SBC engine
Vacuum line to distributor really needs to come from a direct source I.e inlet manifold rather than port on carb.
CCCUK Chairman
roppa440
Club Member
Fri 29 Dec 17 22:46
Re: SBC engine
You need the 23 degrees initial timing so you have to restrict the total timing so it does not go over 36 mechanical only.
Where on the carb are you connecting the vacuum advance?
If you use a port on the base of the carb that sources vacuum from below the throttle blades instead of above them that should give you manifold vacuum and that will vacuum advance the timing at idle to give you enough initial without effecting total mechanical advance.
Dellb
Club Member
Sat 30 Dec 17 10:53
Re: SBC engine
Hi All
The amount of expertise out there is quite awesome. You guys have really helped.
Back to my problem.
My current vacuum setup is
Main 12mm take off below throttle plates under secondary bowl is to the brake servo.
6mm take off half way up the primary metering block is to the distributor vac.
6mm take off under primary throttle plates was blanked, but is now connected to a PCV system that I have installed on the engine. I am keen to keep this, because not only does it keep the engine clean, but I believe it takes the pressure off the rear main bearing seal.
From the inlet manifold there is a connection that services the following.
Gearbox vacuum actuator
Headlights
heating and AC controls (currently being used for the vac gauge)
My plan is to blank the current distributor connection and tee the distributor into the gearbox vacuum actuator.
I will then set the initial to 15 degrees and see what the vacuum does to it.
For info, my engine is not a stock 350, but is a 400 SBC.
Rgds
Delb
Derek L G
roscobbc
Sat 30 Dec 17 11:30
Re: SBC engine
Dellb wrote (View Post):Hi All
Back to my problem.
Headlights
Rgds
Delb
It sounds as though you have matters in hand - your plans for the vacuum take-off are fine and will give a 'proper' vacuum signal rather than 'ported' signal from side of carb. 15% initial seems a good starting point to start with. If the distributor is stock you may want to consider replacing with a performance unit that has an adjustable advance curve and total figure - or - as an interim thing initially source a pack of different strength springs and bob weights to alter the advance 'curve' - perhaps bringing the advance-in much earlier (Moroso used to supply one of these). You'll need to be careful using an auto transmission though not to 'load' the engine and create detonation with too much advance - even more so if you are using the stock torque converter and a 'low' numerical axle ratio.
CCCUK Chairman
roppa440
Club Member
Sun 31 Dec 17 00:36
Re: SBC engine
Using vacuum advance is handy because when the engine is put under load the vacuum drops off and so it does not cause detonation. It's the same a WOT.
You really need an adjustable timing light that allows you to set the total mechanical timing to 36 degrees max all in at 3000 rpm with half that timing in at 2000 rpm.
Dellb
Club Member
Fri 12 Jan 18 21:45
Re: SBC engine
Hi All
I just thought I would take time to complete this thread. I have listened to the advice given, and it was spot on.
I purchased an advance timing light, and it is brilliant. It takes all the guesswork out of setting and measuring the timing.
I have set the carb as discussed, and the engine now idles well (it will never be smooth with this cam) is responsive with crystal clear exhaust.
Many thanks to you all for your advice.
Derek
Derek L G
roppa440
Club Member
Sat 13 Jan 18 17:37
Re: SBC engine
Well done! Clap Thumbs up
Reply to topic
Permissions
