CCCUK logo
 Adrian Flux
Website Control
Recent threads
New Forum Posts
» Carpets for 56 C1 by roscobbc on Sun 19 Aug 18 23:25
» Lights by Daytona Vette on Sun 19 Aug 18 22:15
» Another 'nail in the coffin' for UK based motorsport by chevrolet on Sat 18 Aug 18 22:00
» Heads/cam by roppa440 on Sat 18 Aug 18 16:15
» Spare wheel light by Nigelcurry on Sat 18 Aug 18 11:34
» 2003 Anniversary Red and Shale Convertible. by Number3 on Fri 17 Aug 18 19:30
» BBCN Regional meet by Nicetie on Thu 16 Aug 18 19:47
» Tyres by roscobbc on Thu 16 Aug 18 13:02
» Drag event... by roppa440 on Thu 16 Aug 18 09:20
» 1989 C4 For Sale by RobBrom on Wed 15 Aug 18 19:56
» C5 Headlamp Adjusters "Golden Rods" by roppa440 on Wed 15 Aug 18 16:31
» Shooting for 1000whp with my C7 @ Top Cats Racing by Sierra on Tue 14 Aug 18 14:19
» U-joint replacement by MIT on Mon 13 Aug 18 22:37
» C6 European Rear Light Conversion by Daytona Vette on Mon 13 Aug 18 16:42
» Full geo setup needed. by Daytona Vette on Mon 13 Aug 18 10:33
» C3 Side Exhaust Pipes by CaptainK on Mon 13 Aug 18 10:00
» Kit Kat wrappers don't make good insulation by CaptainK on Mon 13 Aug 18 09:52
» Head Unit Replacement by L88 on Sun 12 Aug 18 13:57
»  by Chris123 on Sun 12 Aug 18 12:24
» 1968 Door Handles by riddyboy on Sat 11 Aug 18 08:54
» Aircon fixed at last! by Daytona Vette on Fri 10 Aug 18 13:29
» Headlight Buckets by kentvette on Fri 10 Aug 18 09:40
» C3 Auto Box Issue Just Developed by Daytona Vette on Thu 09 Aug 18 22:52
» CCCUK West Sussex meeting tonight 9th August by Sea5 on Thu 09 Aug 18 18:27
» History of my vehicle VJD 5G by Bill Riches on Thu 09 Aug 18 16:58
» Borgeson steering box upgrade. by Skeets on Thu 09 Aug 18 13:19
» Cumbria classic (Dalemain House) car show. Sunday 19th August by 666Vette on Thu 09 Aug 18 12:26
» Concours of Elegance by curious bystander on Wed 08 Aug 18 16:47
» What did you do with your Vette today? by MIT on Wed 08 Aug 18 15:31
» South Central Regional Meeting for August by Daytona Vette on Wed 08 Aug 18 10:35
Steering Wheel Position Sensor - Reset?
Go to page: 1, 2 / Next
Reply to topic
Author
Message
Le Vette
Regional Rep
Fri 05 Jan 18 18:58
Just had steering rack removed for new harmonic balancer install. However, mechanic was unaware of need to not move the steering wheel when column disconnected from rack! So now I'm getting a message to say that the "active handling is warming up" and this won't go away, due to the swps thinking that the wheels aren't pointing forwards.
Does anyone know if it's possible to tell the swps that everything is now ok and it can forget what it knew? Maybe the message goes away after a number of successful journeys?
Can anybody throw any light on this....?
Thanks in anticipation Thumbs up [/quote]
Peter Sansbury
CCCUK International Rep
May the Force be Quite a Long Way Behind You
eurovettes
CCCUK Supporting Vendor
Fri 05 Jan 18 21:33
Re: Steering Wheel Position Sensor - Reset?
If you have access to a tech 2 then you can see the counts on the SPS, then re-align accordingly - I think it has to go to zero but cant remember
I would guess a google search may reveal some interesting videos (do use sexy words !!!)
cheers
keith
eurovettes
Fri 05 Jan 18 21:43
ooops I meant DONT use sexy words
CUSTOM EXOTICS
Addict
Sat 06 Jan 18 17:05
Please be ultra carefull here as damage can be done to the airbag ribbon connector at the steering wheel if rack has been reftted off centre take care back to mechanic and get him to refit should not need resetting if installed back correctly
nothing to prove
roppa440
Club Member
Sun 07 Jan 18 17:08
CUSTOM EXOTICS wrote (View Post):Please be ultra carefull here as damage can be done to the airbag ribbon connector at the steering wheel if rack has been reftted off centre take care back to mechanic and get him to refit should not need resetting if installed back correctly
My thoughts exactly.
Just disconnect it again and center the steering wheel.
Le Vette
Regional Rep
Thu 18 Jan 18 15:35
The problem is that the steering wheel IS centered, however when disconnected from the rack it spins freely BUT there is only one position where it is 'right'. I have borrowed a 'fancier than normal' OBD2 reader (Autel MOT Pro) and discovered that you can get a live reading of the analog voltage being monitored by the steering wheel position sensor. Apparently, 2.5v is what should be read when the steering wheel is in the 'right' position (changes by approx 1v per revolution).
Now I'm beginning to sound like an expert I'll defer from posting any more until I try and reposition the steering wheel vs the steering rack tomorrow, using the 2.5v perceived wisdom... here's hoping, fingers crossed. Scratchchin
Peter Sansbury
Rich
Club Member
Thu 18 Jan 18 17:20
Good luck, Pete.
Rich Rogers
CCCUK Lifetime Member
2017 Yellow SS Camaro
Le Vette
Regional Rep
Fri 19 Jan 18 18:21
Re: Steering Wheel Position Sensor - Reset? Message Icon
OK, so that plan didn't work. Couldn't successfully read the voltage from the SWPS using the gizmo, but of course it worked fine once I got home and tried again! Grrr.
Oh, and I also have a B0026 DTC code ("Driver Frontal Deployment Loop Open Circuit") which I'll need to understand better before I do any more... Banghead
Tomorrow is another day. Rolling Eyes
Peter Sansbury
Le Vette
Regional Rep
Wed 24 Jan 18 17:10
OK, an update:
Re-tried the OBD2 reader on the steering wheel position sensor - it turns out that the engine must actually be running to get a valid voltage reading from the SWPS. Once the engine is running you can disconnnect the steering column from the rack at the knuckle joint under the hood and turn the steering wheel until you get a reading of around 2.4 volts. Your steering wheel is then correctly centred. Thumbs up
The remaining airbag problem (B90026 DTC) is probably a result of damage inflicted on the clockspring located directly behind the steering wheel and airbag. Apparently if you turn more than three revolutions you can break this, so we have another on order.... N.B. when replacing this item there is a very similar centering process as when you disconnect the other end of the column! Basically you have to leave the steering wheel centred and make sure you put it all back in exactly the same position.
I'll update this thread again once we are in a position to say for sure what the problem with the airbags circuit is...
Peter Sansbury
CUSTOM EXOTICS
Addict
Wed 24 Jan 18 17:32
Ps I actually have a working c5 corvette clock spring here if it helps second hand if ur local to me feel free to collect
nothing to prove
Reply to topic
Permissions
