CCCUK logo
 ShipMyCar.co.uk
Website Control
Recent threads
New Forum Posts
» Jacking whole car onto axle stands by stiej on Mon 21 May 18 13:51
» FOR SALE - C6 MODIFIED STANDARD EXHAUSTS louder than stock by craigyboy on Mon 21 May 18 13:23
» What did you do with your Vette today? by 1997BlackC5 on Mon 21 May 18 10:18
» C5 aircon recharge by weslp00 on Mon 21 May 18 09:35
» Loose handbrake lever by stiej on Sun 20 May 18 22:26
» dash bulbs by Vetteheadtony on Sun 20 May 18 21:02
» Oil by stevel98 on Sun 20 May 18 08:12
» Le Mans 2017 by lakechris on Sun 20 May 18 08:06
» no posts by L88 on Sat 19 May 18 12:41
» c5 outdoor cover by curious bystander on Sat 19 May 18 10:28
» Ordering Spares From The States by voguev8 on Sat 19 May 18 06:13
» RockAuto.com Discount Code for Parts & More - Expires August 15, 2018 by Sid.123 on Sat 19 May 18 02:02
» License plates dimensions by Sid.123 on Sat 19 May 18 01:26
» Under bonnet light by 5 USA on Fri 18 May 18 20:26
» Edinburgh + Lothians Car Show by curious bystander on Fri 18 May 18 18:50
» Lincolnshire Corvette Open Day by Vette T-Shirt on Thu 17 May 18 15:45
» For the C5 owner who has everything by Rich on Thu 17 May 18 13:30
» 5 German Corvette on a North England trip in May by roppa440 on Thu 17 May 18 12:31
» Trip Back In Time by kentvette on Thu 17 May 18 11:11
» Yattendon Classic Vehicle Day by Rich on Wed 16 May 18 19:04
» New East Anglian Regional Representative by Ruby 2 on Wed 16 May 18 17:56
» Festival of Wheels by Ruby 2 on Wed 16 May 18 16:07
» Tyres by stevel98 on Wed 16 May 18 09:57
» Raby castle classic car show by STELTHYFLATFISH on Wed 16 May 18 00:18
» Bella auto car show by STELTHYFLATFISH on Tue 15 May 18 23:13
» car stereo by cloudedmind on Tue 15 May 18 22:31
» BBCN Region get together at Denton car show this Sunday by autocolor on Tue 15 May 18 19:30
» Do You Have A Favorite Car Show/Cruise-In Chair? by stevel98 on Tue 15 May 18 15:10
» Borders classic and vintage car show by 666Vette on Tue 15 May 18 12:39
» new to region by Bowler on Mon 14 May 18 21:36
C3 headlights .
Go to page: 1, 2 / Next
Reply to topic
Author
Message
mickeywick
Club Member
Sat 20 Jan 18 19:46
C3 headlights .
The outer headlights on my 1977 C3 come on ok but the inner ones won't.
According to my manual, these are protected by a circuit breaker.
Is the circuit breaker in the fuse box?
Where the hell is the fuse box?
Puzzled of Horley, Surrey
Mike A
Club Member
Sat 20 Jan 18 20:04
Re: C3 headlights .
What year is your car ? Does it have floor or column mounted main beam switch ? On circa 1980 models the headlights are protected by a thermal cut out built into the multi function dash board switch which opens in an overheat situation , breaks the circuit and the head lights go out . The cut out cools, closes the circuit and the lights come on again . This controls both main beam and dipped beam lights so you will lose all four lights simultaneously . If you only have main beam not working ( the inner ones of each pair ) then it not the thermal cut out that`s the problem .
The headlights are not fused in the fuse box . The fuse box is situated well hidden under dash to left of steering column and a bitch to get at or see clearly . You need to kneel down outside car and get your head right under to see it . Dumbest place ever you ask me Banghead
Sounds more like you have an earth / connection problem . Good luck.
Life is an open road , so make the most of the journey .
Club Member
Sat 20 Jan 18 20:06
Re: C3 headlights .
Sorry ! just seen it is 1977 car , teach me to read properly !!
It should be same as my 1980 .
Club Member
Sat 20 Jan 18 20:07
Re: C3 headlights .
Presuming all C3s the same,
On low beam only one set light
On high beam both sets light
Circuit Breaker integral with the Headlight Switch
Fuse Board in the Drivers Foot well, up by the Steering Column
Best of Luck
Barry - Daytona Vette
mickeywick
Club Member
Sun 21 Jan 18 07:46
Re: C3 headlights .
Thanks chuffer and Barry.
I got under the dash by the steering column and couldn't get out again ! !
Stikll none the wiser buty will keep on trying.
atvb
Mike
Mike A
Club Member
Sun 21 Jan 18 09:19
Re: C3 headlights .
Hi Mike,
At least you now know where the fuse box is Thumbs up but how inaccessible it is Banghead
As already pointed out though , if your outer headlights work but inner don`t the problem is not circuit breaker related . I recall having one inner main beam light not working shortly after buying my car . It turned out be a dodgy connection .
Start by lifting the hood / bonnet and check inside nose of car for loose or dropped off connections at back of lights . As with all plastic cars good earthing to chassis critical so unbolt any you can find ( and reach Laughing ) clean the contact surfaces and give a squirt of WD40 before reconnecting .
Of course it just could be something simple like bulbs have blown !
mickeywick
Club Member
Sun 21 Jan 18 09:24
Re: C3 headlights .
Many thanks for that - I will continue the battle Smile
Of course it may be that the switvh is faulty - the one that sticks ouit of the left-hand sic
de of the steering column and also works the wipers and washers and indicators.
Mike
Mike A
fordpop52
Club Member
Mon 22 Jan 18 09:49
Re: C3 headlights .
When i got my 1978 C3 i had the same problem with my lights.
Someone had fitted a fuse under the dash but behing the centre console at the top i could just feel it but not see it took ages and it only had a 15amp fitted.
Arthur
Leatherhead
mickeywick
Club Member
Mon 22 Jan 18 10:13
Re: C3 headlights .
fordpop52 wrote (View Post):
Arthur
Leatherhead
Many thanks Arthur.
I've been told that both sets of headlights work through the same circuit breaker. If this is the case then my problem is not a circuit breaker but maybe a loose connection because the outer pair come on but the inner pair don't.
Rgds.
Mike
Horley
Mike A
Club Member
Mon 22 Jan 18 10:55
Re: C3 headlights .
Mike ,
You might find when you do get all four lights working simultaneously that the current draw causes the thermal cut out to keep tripping out causing lights to flash on and off .Unless a previous owner has wired relays into the circuit to prevent this . It is a C3 trait and many club members have gone that route .
I have not got round to doing this but because the rheostat built into light switch that dims instrument lights had burnt out I needed to replace that . I found that Zip Corvette list an " upgraded thermal cut out " head light switch claimed to overcome the on off flashing problem . I have just fitted one last week and initial tests seems to show it works .
Chuffer ( aka Mike too )
Reply to topic
Permissions
