CCCUK logo
 ShipMyCar.co.uk
Website Control
Recent threads
New Forum Posts
» looking for a c5 by Invetterate on Sun 25 Feb 18 11:43
» Radio Wanted by kentvette on Sun 25 Feb 18 09:41
» What did you do with your Vette today? by geoff917 on Sat 24 Feb 18 19:32
» C7 remote start by Rich on Sat 24 Feb 18 15:12
» Rear spring by Dellb on Fri 23 Feb 18 21:16
» Faulty time clock by Dellb on Fri 23 Feb 18 21:13
» Headlamps by kentvette on Fri 23 Feb 18 17:05
» Earls Barton Classic Vehicle show by Nicetie on Fri 23 Feb 18 13:34
» Earls Barton Classic Vehicle show by Nicetie on Fri 23 Feb 18 13:33
» Earls Barton Classic Vehicle show by Nicetie on Fri 23 Feb 18 13:32
» Earls Barton Classic Vehicle show by Nicetie on Fri 23 Feb 18 13:31
» Earls Barton Classic Vehicle show by Nicetie on Fri 23 Feb 18 13:30
» BBCN Region February meet at Meguires by Nicetie on Fri 23 Feb 18 13:14
» Steering Wheel Position Sensor - Reset? by Rich on Fri 23 Feb 18 13:00
» C5 thrown a 'serpentine' belt by Le Vette on Fri 23 Feb 18 12:50
» Numbers matching by paj66 on Fri 23 Feb 18 11:39
» How it's made - Corvette Stingray by FIVE RED on Fri 23 Feb 18 11:29
» Does anyone recognise this Vert by MIKERED on Fri 23 Feb 18 10:09
» The Scottish Car Show 15th July 2018 by roppa440 on Fri 23 Feb 18 09:55
» Engine bay by Nigelcurry on Fri 23 Feb 18 09:16
» OBD connector ? 1 or 2 by stevel98 on Fri 23 Feb 18 09:08
» 1960 C1 steering box by paj66 on Thu 22 Feb 18 17:50
» London 'T' charge by roscobbc on Thu 22 Feb 18 17:35
» Tewkesbury Classic Vehicle Festival by curious bystander on Thu 22 Feb 18 17:30
» RockAuto.com Discount Code for Parts & More - Expires April 4, 2018 by Rich on Thu 22 Feb 18 16:00
» "Breakfast Club" Meeting - March by Bowler on Thu 22 Feb 18 14:18
» London Classic Car Show - 15th-18th February 2018 by Fishy Dave on Wed 21 Feb 18 15:00
» Letter of conformity by Barrelmaker on Tue 20 Feb 18 21:04
» The Mods continue on my C7 by C7KEN on Tue 20 Feb 18 18:42
C3 headlights .
Go to page: Previous / 1, 2
Reply to topic
Author
Message
mickeywick
Club Member
Mon 22 Jan 18 10:10
Re: C3 headlights .
Thanks Mike.
I have already been down the relay fitting route and they werte working ok.
Now just the outside ones come on and I can't get the inner ones to light up.
Possibly a loose connection? or maybe that little stick on the left of the steering column that does the washers, wipers and indicators etc.
Mike A
Club Member
Mon 22 Jan 18 10:45
Re: C3 headlights .
Hope it turns out be something simple Doh
\When my one main didn`t work I could tap the lens with my knuckle and it would work then go off again . Took the light units out of the pop up mounts , couldn`t find anything obvious so took off all connections , cleaned terminals and earth points and hey presto ! It worked Clap
Life is an open road , so make the most of the journey .
mickeywick
Club Member
Tue 30 Jan 18 17:30
Re: C3 headlights .
Thanks so much - you were dead right - all working OK now - just got to align them all - ha ha !!
Mike A
Mike A
Club Member
Wed 31 Jan 18 11:00
Re: C3 headlights .
Excellent news , glad it was an easy fix . Thumbs up
mickeywick
Club Member
Wed 31 Jan 18 18:09
Re: C3 headlights .
Yes - many thanks.
Plucking up courage to adjust the beams assuming I can get the car on level ground Smile
Why on earth is the fuse box so inaccessible ?
Look at Surrey Oaks, Newdigate for monthly classic car breakfast.
atvb
Mike
Mike A
Club Member
Thu 01 Feb 18 10:12
Re: C3 headlights .
mickeywick wrote (View Post):
Yes - many thanks.
Mike
I adjusted the beams on our '78 in the garage, using the closed door as the "wall". Actually quite straightforward assuming you can get the car about 8ft from the "wall" and "square". Two adjuster screws per lamp unit. For the full beam, when all four lamps are lit, I covered the main/dip unit that I had previously adjusted, so that I could see the pattern of the main bean easier.
Seemed to be OK as it passed the test here and, with the new halogen dip beam, its a joy at night now!
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
mickeywick
Club Member
Fri 02 Feb 18 07:50
Re: C3 headlights .
Many thanks for that.
Do you happen to know how far down, and to the side, the dipped beams should be assuming you're 8 ft. from the wall/door?
atb
Mike
Mike A
Club Member
Fri 02 Feb 18 09:36
Re: C3 headlights .
Hi
To be honest, no Rolling Eyes Smile I did mine a while ago and I seem to think that I'd got an idea of where the Vette lights should be, based on our "metal car", parked in the same place!
I used masking tape to put lines on the door to show height and angle and also where the dip went to.
Then, swapped the cars. I recall that measured the height of the actual lights on the car from the ground, and the width, so I had an idea if the lights were pointing ahead (!) Then just got all of them lined up to that, getting all four main beams in line.
I have to say I was surprised by how close I got it, as they were great to drive with almost straight away. (The new lamp units had been pointing at the ground when they first went in!) Not sure how stringent the test is here for "Collection cars", but it passed.
Hope that's a bit helpful!
Stephen J Irons
NCM Family Member
Apple IS Genisys!
mickeywick
Club Member
Fri 09 Feb 18 10:04
Re: C3 headlights .
I know virtually nothing about headlighs or how they work - a complete mystery !
Would my C3 have sealed beam lights and would I simply be able to change the bulb if one stops working?
How can I tell whether they are sealed beam or not?
atb
Mike
Mike A
Club Member
Fri 09 Feb 18 10:36
Re: C3 headlights .
Yes, the stock fitting on a C3 would be Sealed Beams. I think you'll find that the units will actually be marked "Sealed Beam" on the glass, but that may just have been on a couple of my replacement items? I don't think it's possible to see the back of the unit if it's still in the car though, to tell if it is a sealed unit or a separate bulb. If one fails you'll need to change the whole unit. The 5.75 sealed beam units are not too hard to come by, but many on here have swapped to lamp units with bulbs, allowing the use of halogen bulbs, which are brighter.
I went to Classic Car Accessories
( http://www.classic-car-accessories.co.uk/acatalog/HEADLIGHTS... ) who were excellent to deal with, had great delivery times and were cheaper than the other "players".
There's lots of discussion about the use of relays. I haven't got them, but I probably should have, if only to protect the switch!
Stephen J Irons
NCM Family Member
Apple IS Genisys!
Reply to topic
Permissions
