 Lancaster Insurance
» Another 'nail in the coffin' for UK based motorsport by chevrolet on Sat 18 Aug 18 22:00
» Carpets for 56 C1 by vet80y on Sat 18 Aug 18 19:22
» Heads/cam by roppa440 on Sat 18 Aug 18 16:15
» Spare wheel light by Nigelcurry on Sat 18 Aug 18 11:34
» 2003 Anniversary Red and Shale Convertible. by Number3 on Fri 17 Aug 18 19:30
» BBCN Regional meet by Nicetie on Thu 16 Aug 18 19:47
» Tyres by roscobbc on Thu 16 Aug 18 13:02
» Drag event... by roppa440 on Thu 16 Aug 18 09:20
» 1989 C4 For Sale by RobBrom on Wed 15 Aug 18 19:56
» C5 Headlamp Adjusters "Golden Rods" by roppa440 on Wed 15 Aug 18 16:31
» Shooting for 1000whp with my C7 @ Top Cats Racing by Sierra on Tue 14 Aug 18 14:19
» U-joint replacement by MIT on Mon 13 Aug 18 22:37
» C6 European Rear Light Conversion by Daytona Vette on Mon 13 Aug 18 16:42
» Full geo setup needed. by Daytona Vette on Mon 13 Aug 18 10:33
» C3 Side Exhaust Pipes by CaptainK on Mon 13 Aug 18 10:00
» Kit Kat wrappers don't make good insulation by CaptainK on Mon 13 Aug 18 09:52
» Head Unit Replacement by L88 on Sun 12 Aug 18 13:57
»  by Chris123 on Sun 12 Aug 18 12:24
» 1968 Door Handles by riddyboy on Sat 11 Aug 18 08:54
» Aircon fixed at last! by Daytona Vette on Fri 10 Aug 18 13:29
» Headlight Buckets by kentvette on Fri 10 Aug 18 09:40
» C3 Auto Box Issue Just Developed by Daytona Vette on Thu 09 Aug 18 22:52
» CCCUK West Sussex meeting tonight 9th August by Sea5 on Thu 09 Aug 18 18:27
» History of my vehicle VJD 5G by Bill Riches on Thu 09 Aug 18 16:58
» Borgeson steering box upgrade. by Skeets on Thu 09 Aug 18 13:19
» Cumbria classic (Dalemain House) car show. Sunday 19th August by 666Vette on Thu 09 Aug 18 12:26
» Concours of Elegance by curious bystander on Wed 08 Aug 18 16:47
» What did you do with your Vette today? by MIT on Wed 08 Aug 18 15:31
» South Central Regional Meeting for August by Daytona Vette on Wed 08 Aug 18 10:35
» Some Subtle Mods to my C7 Stingray by C7KEN on Tue 07 Aug 18 22:01
C3 radiator support and vacuum tank questions
Go to page: 1, 2 / Next
phorbiuz
Regular
Thu 01 Feb 18 20:45
Hello again peeps.
A couple of questions this time if you don't mind on my '78 C3.
First, I'm in the process of removing the radiator support panel and so far the only thing stopping me progressing is the bottom 2 bolts which are rusted in and completely seized in the crumbling support panel. What I did notice though is that the relatively good radiator doesn't seem to be secured at the base. My factory assembly manual in diagram 13b suggests there should be 2x lower support insulators/brackets that fit to the support panel and radiator. Can anyone show me what these would actually look like so I can look for a pair?
Second, I think I have a good lead on why my vacuum system is pretty naff as there's nothing actually attached to it.
Am I right that the valve to the far side of this tank (not pictured) is the feed in? I'm thinking these 2 should connect to the pop up lights, and therefore the best way to test is to block these 2 off and put a pressure gauge in the main feed in?
Thanks.
Dave.
Everything's easy, when you know how it's done.
Fri 02 Feb 18 15:39
Re: C3 radiator support and vacuum tank questions
Dave, The radiator just rests in the brackets at the base of the core support. There are a couple of rubber "insulators" that I think must be the same, or very similar to those at the top. The AIM has a diagram of them, which is attached. I had a quick look and maybe this is what you need, from Zip?
http://www.zip-corvette.com/76l-82-w-ac-2-5-8-radiator-mount...
The "tube" assembly at the front of the chassis doubles as the vacuum reservoir for the lights and is, I believe, what holds them or pulls them shut. So there sold be an "in" line (that is presumably "sucking") and then the two connections in your photo would, I think go to each of the actuators to pull the lamp doors down.
For some reason, it used to common years ago to see Vettes with lamp doors up, and it was always diagnosed as a leak in the system or the front tube. It's not common now, so people must understand the system better!
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
phorbiuz
Regular
Fri 02 Feb 18 21:41
Thanks for the reply Kentvette.
The issue for me is that my radiator wasn't sat in anything - it was simply resting on the rad support panel which is crumbling away and as a consequence is/was moving about. I need to figure out if I should have a bracket, an insulator, or a bracket with insulator and then buy what I need.
The radiator looks fairly clean, maybe not that old, so I suspect a recent owner did some quick jobs so the motor could be moved on.
VetteWeekend
Webmaster
Sat 03 Feb 18 00:03
This is the bottom of a '75...It has to brackets to take the rubbers that Stephen posted and there are two brackets bolted to the support and to the car. Although only one is actually on this frame as what was left of the other one was still on the car... Very Happy
Last edited by VetteWeekend on Sat 03 Feb 18 00:05; edited 1 time in total. [10 %]
CCCUK on Facebook
VetteWeekend
'75 Shark (on a shoestring) - Sold!
'58 Apache - The shop truck - Sold!
'91 ZR-1...For Fun! - The Return of Purple Haze!
'72 GMC G15 'Shorty' - Rolling Heavy.
www.kickson66.uk - For Official Gas Monkey Garage, DPG, OCC Merch & More.
phorbiuz
Regular
Sat 03 Feb 18 00:20
Thanks VetteWeekend.
It definitely doesn't have those bottom brackets for the rubbers, so I guess I need to go shopping for the brackets and the rubber insulators. Of those bottom support panel to body mounts you mention they're the 2 I'm struggling with at the moment. I'll be going back with my breaker bar next week.....
Sat 03 Feb 18 10:27
Those are a few scary photos Simon!
The difference with the '78 support appears to be that it has more metal between the rad support brackets, making the base a solid panel effectively. I noticed that bottom rad brackets are sold separately for earlier Vettes, the detail including the phrase "welds to the support". But no brackets are listed for the '78. So, I'm guessing they are integral with a new rad support, which is alas, a rather pricey item.
Stephen J Irons
NCM Family Member
Apple IS Genisys!
Sat 03 Feb 18 12:08
My Rad Support Frame has a tray at the bottom - this collects water, when I wash the car I dry the tray out with a small towel - if I was fitting again I would make sure it had drain holes.
Barry - Daytona Vette
phorbiuz
Regular
Sat 03 Feb 18 15:31
That's an interesting point peeps. The remains of the support panel coming out and the new Coffman Corvette panel to go in both have much bigger "tray" areas at the bottom than the photo's above from VetteWeekend show. It leads me to think there aren't supposed to be any lower brackets, but instead the rubber insulators sit on the shelf and in turn support the radiator. Looking again at the AIM diagram above from Kentvette (which is the same as mine) seems to suggest this.
VetteWeekend
Webmaster
Sat 03 Feb 18 17:48
kentvette wrote (View Post):Those are a few scary photos Simon!
It didn't clean up to bad, a little bit of new metal and a coat of paint it looked brand new! Very Happy Also wondered if there was a change of design on the later models and I've now only seen the AIM attachment, sorry for any confusion.. Rolling Eyes
CCCUK on Facebook
VetteWeekend
phorbiuz
Regular
Wed 07 Feb 18 20:31
A little update and a more questions, sorry peeps...
So, the original rad support panel is out and it was a ball ache. The fan shroud didn't want to play game at all but with the fan removed, air con rad removed from the support panel, and the panel itself unbolted they eventually gave way. I can confirm too that on my '78 the rubber insulators simply plug into the larger bottom shelf to support the rad.
Moving onto the lazy vacuum system, the vacuum tank tested fine, but neither headlamp actuators held vacuum well so will need repair/replacement, and all the hoses are going hard so could do also do with replacement.
Interestingly, I think some bits are missing but I have no car to compare mine too. There is no 3 port vacuum check valve following the vacuum filter, just a T-piece with one part going to the inner wing and another part going inside the cabin. Also, the headlamp relay valves just let air in/out of the bottom below the 3 hoses.
So....
Let's start with the easy one. What should be on the bottom of the relay valve. A quick read up suggests some sort of filter? Not sure where I can source these TBH.
Dave.
