CCCUK logo
 ShipMyCar.co.uk
Website Control
Recent threads
New Forum Posts
» Resto Vette - or - Modifed Vette by Daytona Vette on Wed 26 Sep 18 13:09
» C8 is Coming by 5 USA on Wed 26 Sep 18 10:27
» '95 C4 with LT1 missfire by corvetteville on Tue 25 Sep 18 17:31
» 1989 C4 For Sale by RickyG512 on Tue 25 Sep 18 12:24
» Modified C5 for Sale by Sinatra21 on Tue 25 Sep 18 12:08
» z51 to z06 by The Dark Knight on Tue 25 Sep 18 08:14
» DeLorean DMC-12 with LS3 480 by Devil Denis on Mon 24 Sep 18 18:36
» l/h rear brake caliper wanted by damc3 on Mon 24 Sep 18 00:01
» 2008 z06 jacking pucks. by Norm on Sun 23 Sep 18 20:41
» Failed oil pump drive by roscobbc on Sun 23 Sep 18 20:21
» C3 that are in UK 1968-73 with chrome bumpers pics please! by L88 on Sat 22 Sep 18 19:11
» Amazing by MIT on Sat 22 Sep 18 11:07
» Spare wheel light by PAZ9556 on Fri 21 Sep 18 19:35
» C7 Configurator by c6pete on Thu 20 Sep 18 12:46
» C2 fibreglassing and prep. by L88 on Wed 19 Sep 18 20:50
» What did you do with your Vette today? by FelixP on Wed 19 Sep 18 13:44
» Potential new C5 owner - some basic questions by Le Vette on Tue 18 Sep 18 14:09
OBD connector ? 1 or 2
Reply to topic
Author
Message
Coltstingray
New Comer
Thu 01 Feb 18 13:02
OBD connector ? 1 or 2 Message Icon
Hi everyone Iím new on here Iím due to pick up my new baby soon a red 1989 C4 any day now canít wait. Not sure if this has been answered before I tried searching couldnít seem to find it.
I want to buy a OBD scanner and Iím having some trouble some websites on eBay or amazon say that there OBD 2 scanner works on a 1989 Vet but others say itís OBD 1 only that works, has anyone used a scanner on a C4 my year? and if so where can I get on
Thanks in Advance
Carlton
gary 53
Club Member
Thu 01 Feb 18 14:10
Re: OBD connector ? 1 or 2
it will be OBD 1
LOOKING FORWARD TO SUMMER
Coltstingray
New Comer
Thu 01 Feb 18 20:54
Thanks have you used one ? And would you be able recommend a certain one
gary 53
Club Member
Fri 02 Feb 18 09:06
You need TECH 1 OR 2
I have never used one here's a link
will tell you how to recover codes
https://corvettephotographs.com/c4vettes/ecm.htm
Coltstingray
New Comer
Sat 03 Feb 18 00:08
Thank you appreciate it
leanmeanvettemachine
Club Member
Wed 07 Feb 18 17:32
Coltstingray wrote (View Post):Hi everyone Iím new on here Iím due to pick up my new baby soon a red 1989 C4 any day now canít wait. Not sure if this has been answered before I tried searching couldnít seem to find it.
Thanks in Advance
Carlton
Hi Carlton,
Another idea if you need to know what the fault is but don't necessarily want to purchase a scan tool to find out, is to use the paper clip trick (explained here). With the ignition off, place a paper-clip between pins A & B of the 12-pin ALDL connector under the dash Image.
Turn the ignition on without starting the engine. Then get ready to count the flashes of the MIL (check-engine light). Sequences will be of the form "FLASH, FLASH pause FLASH, FLASH, FLASH". These flashes correspond to the two-digit diagnostic fault code, i.e. this example is code# 23. Troublecodes.net has a table of GM specific fault codes you can use to lookup the fault.
Once you've diagnosed the fault, turn off the ignition, and remove the paper clip. You can then clear the fault code by disconnecting the battery for more than 20 seconds.
TL;DR - The old ALDL diagnostics bus had a facility to flash the MIL (check-engine light). If you count the flashes you can diagnose the fault without a scan tool.
Hope this helps,
Alex
'12 C6 Coupe (LS3 + TR6060)
Follow my build on IG @v8tor_17
Coltstingray
New Comer
Mon 19 Feb 18 22:43
Thanks for that I have tried to find mine canít locate it is it drivers side or passenger side? Or is it connected to something I have to unplug?
Cause itís not hanging down in there
dm575
Regular
Thu 22 Feb 18 21:56
On my 91 the connector was tucked away under the dash. Remove the kick panel and take a look, it will be there somewhere Smile ( driver side to the right of the steering wheel )
1991 Black C4 Targa L98 Auto
1997 White Z28 Camaro Coupe LT1 Auto
Redlevel
Club Member
Fri 23 Feb 18 10:08
Coltstingray wrote (View Post):Thanks for that I have tried to find mine canít locate it is it drivers side or passenger side? Or is it connected to something I have to unplug?
It's above and slightly forward of your right knee on the drivers side usually covered with a black plastic cap, just under the bottom of the dash but easily accessible.
If you have SES on the screen, don't panic or try to diagnose the codes right away as they are sometimes only symptoms and not actual faults.
Drive the car a good few miles, get it hot and idling nicely, then switch off, disconnect the battery, reconnect and see if the SES comes back, if it does, do the paper clip test and read what you've got. Corvettes do not like being idle for long periods and may well throw up codes after a long lay up just to p*ss you off. If the car drives fine even with codes don't fret as most codes are easily dealt with and are no real warning of impending doom! Yes
Good luck and keep us posted..
Reply to topic
Permissions
