CCCUK logo
 Adrian Flux
Website Control
Recent threads
New Forum Posts
» Ace Cafe - London by Largelunchbox on Sun 25 Feb 18 21:41
» Faulty time clock by Nigelcurry on Sun 25 Feb 18 20:59
» Corvette 'Sounds' by roscobbc on Sun 25 Feb 18 18:04
» What did you do with your Vette today? by Germax on Sun 25 Feb 18 16:06
» Silverstone Classic - 20/21/22 July 2018 by curious bystander on Sun 25 Feb 18 15:55
» looking for a c5 by JJVETTE on Sun 25 Feb 18 14:42
» Clutch options '95 LT1 by Dan. on Sun 25 Feb 18 14:12
» Radio Wanted by kentvette on Sun 25 Feb 18 09:41
» C7 remote start by Rich on Sat 24 Feb 18 15:12
» Rear spring by Dellb on Fri 23 Feb 18 21:16
» Headlamps by kentvette on Fri 23 Feb 18 17:05
» Earls Barton Classic Vehicle show by Nicetie on Fri 23 Feb 18 13:34
» Earls Barton Classic Vehicle show by Nicetie on Fri 23 Feb 18 13:33
» Earls Barton Classic Vehicle show by Nicetie on Fri 23 Feb 18 13:32
» Earls Barton Classic Vehicle show by Nicetie on Fri 23 Feb 18 13:31
» Earls Barton Classic Vehicle show by Nicetie on Fri 23 Feb 18 13:30
» BBCN Region February meet at Meguires by Nicetie on Fri 23 Feb 18 13:14
» Steering Wheel Position Sensor - Reset? by Rich on Fri 23 Feb 18 13:00
» C5 thrown a 'serpentine' belt by Le Vette on Fri 23 Feb 18 12:50
» Numbers matching by paj66 on Fri 23 Feb 18 11:39
» How it's made - Corvette Stingray by FIVE RED on Fri 23 Feb 18 11:29
» Does anyone recognise this Vert by MIKERED on Fri 23 Feb 18 10:09
» The Scottish Car Show 15th July 2018 by roppa440 on Fri 23 Feb 18 09:55
» Engine bay by Nigelcurry on Fri 23 Feb 18 09:16
» OBD connector ? 1 or 2 by stevel98 on Fri 23 Feb 18 09:08
» 1960 C1 steering box by paj66 on Thu 22 Feb 18 17:50
» London 'T' charge by roscobbc on Thu 22 Feb 18 17:35
» Tewkesbury Classic Vehicle Festival by curious bystander on Thu 22 Feb 18 17:30
» RockAuto.com Discount Code for Parts & More - Expires April 4, 2018 by Rich on Thu 22 Feb 18 16:00
Wheel Alignment
Go to page: Previous / 1, 2, 3
Reply to topic
Author
Message
stevel98
Awww... join the CCCUK!
Wed 14 Feb 18 15:25
Re: Wheel Alignment
roppa440 wrote (View Post):Daytona Vette wrote (View Post):I only asked the question because I remember many posts ago when you mentioned that you could not get the power down as much as you wanted due to insufficient traction, because if your man has a corner weighting facility he could give you more traction at the rear.
Different game that. To get weight over the rear tyres the centre of gravity of the car needs to shift rearwards at launch on a drag car. To do that you need stiff suspension at the rear and very soft suspension at the front.
Can you still get 90/10 shocks then? Scratchchin
https://www.youtube.com/watch?v=TF9IJljDMfk
stevel98
Wed 14 Feb 18 15:32
Re: Wheel Alignment
roppa440 wrote (View Post):Oh and I have no traction issues since I bought a pair of sticky Mickey Thompsons to use at the track. Thumbs up
MT's... Yes
I'd love to have a set of these on the back.. Probably lethal in our climate, but what the hell, they look great. And they do them in my size!
https://firstchoicewheelsandtires.com/product/tire/166
roppa440
Club Member
Wed 14 Feb 18 15:34
Re: Wheel Alignment
stevel98 wrote (View Post):roppa440 wrote (View Post):Daytona Vette wrote (View Post):I only asked the question because I remember many posts ago when you mentioned that you could not get the power down as much as you wanted due to insufficient traction, because if your man has a corner weighting facility he could give you more traction at the rear.
Yes. And sometimes the guys remove the front anti roll bar and fit springs from a lighter engined car.
Normally weight at the wheels is used when adjusting suspension rates at each corner. Adjustable coil overs, spring/traction bar preload and shocks etc. I can't see how adjusting caster, camber, and toe could be effected by wheel weight. I must not know as much about it as I thought? Confused
roppa440
Club Member
Wed 14 Feb 18 15:38
Re: Wheel Alignment
stevel98 wrote (View Post):roppa440 wrote (View Post):Oh and I have no traction issues since I bought a pair of sticky Mickey Thompsons to use at the track. Thumbs up
MT's... Yes
Apparently these newer Mk2 versions of the tyre are "better" in the wet than the completely lethal previous version. Laughing
roppa440
Club Member
Wed 14 Feb 18 15:46
Re: Wheel Alignment
Would these bolt on your car at the track Steve? You could borrow them off me at the Mopar Nats. Very Happy
stevel98
Wed 14 Feb 18 16:43
Re: Wheel Alignment
I wish..
The 84-89 C4 has a unique wheel with a 34-38mm backspace depending on the width (8.5 or 9.5 depending upon what Bubba and Dan had available on the line) so later C4's and C5's won't fit as I think they have a 56mm backspace. The only later GM wheel that will fit an early C4 oddly enough is a ZR1 wheel (11x17) as it has the same 38mm backspace. I could fit C5 wheels, but I'd need spacers and that would push the wheel out of the wheelarch.
My BBS's are in fact off a BMW and 10x16 and 295/50R16 is a perfect size for me.
The biggest issues seem to occur with the '84-'87 models. According to Mike Sweeney of Corvette Wheel Specialist, these wheels were special, with a 36-38mm offset, different from the more common 56mm offset found on '88 through '96 Corvette wheels. "Offset" is the distance between the front of the wheel and where the wheel mounts to the disc-brake rotor; backspacing is measured from this point to the back of the wheel.
To be honest, I doubt if traction would be an issue with my car as Santa Pod's surface, and the traction compound they spray on it seems to bog down a lot of the lesser powered cars especially if they are burning out too. I would guess that my best shot would be to not burn out and let the tyres spin a tad to keep it all going..
roscobbc
Wed 14 Feb 18 18:39
Re: Wheel Alignment
That may change with the new 'concrete' surface being laid for the 2018 season
CCCUK Chairman & Editor, Vette News
Richard J
Club Member
Fri 16 Feb 18 08:01
Had it's MOT yesterday passed with no Advisories...
I asked them to check, for anything worn, wobbly or look out for dodgy shocks etc. he said didn't find anything and all was well. He drives a Skyline and said he's does it as well, any car with this sort of set up and fat tyres is always going to follow ruts in the road, so maybe it's just me...
Also has new tyers all round now, so I'll see how that goes
Reply to topic
Permissions
