CCCUK logo
 Adrian Flux
Website Control
Recent threads
New Forum Posts
» What did you do with your Vette today? by Vetteheadtony on Tue 22 Jan 19 11:39
» New Unexpected Owner of this C3!! by L88 on Tue 22 Jan 19 10:59
» Power Windows by roscobbc on Mon 21 Jan 19 20:50
» CCCUK Website and Forum by roscobbc on Mon 21 Jan 19 20:47
» C6 Z06 Flat battery by Tattooboy on Mon 21 Jan 19 20:03
» This seems very cheap for a C7 by roscobbc on Mon 21 Jan 19 17:28
Corvette C6 oil filter and correct Oil / Owners manual
Go to page: 1, 2, 3 / Next
Reply to topic
Author
Message
Davee
New Comer
Fri 30 Mar 18 15:59
Hi Guys just returned to Corvette ownership since owning a C5 some years ago !! can anyone recommend an oil filter and oil for a 2005, C6, LS2 engine seen loads on the internet but thought I would ask the forum on there advice on oil filters and oil makes and viscosity etc . Think it supposed to have Mobil 1, 5w 30w or is that for the USA ? I also need a C6 corvette owners hand book if anyone knows where I can get one ?
as mine was stolen in transit !! your help is much appreciated thanks Davee
Rich
Club Member
Fri 30 Mar 18 19:20
Re: Corvette C6 oil filter and correct Oil / Owners manual
The GM recommended items are:
AC Delco Oil Filter PF46
Dexos 2 oil. 5w 30. Available from Vauxhall dealers.
Mobil 1 was recommended but that changed to Dexos 2.
I have a pdf of a 2008 Owners Manual which I can email to you, no problem, but you may be able to find one online for your year.
Rich Rogers
CCCUK Lifetime Member
2017 Yellow SS Camaro
CHUCK
Club Member
Fri 30 Mar 18 19:36
You Might find the PF46 is better for 2005/2006 C6. Thumbs up
C6 Lg headers,borla stinger,ported,fast 92 intake ,ported throttle body , vararam ram air
and mgw short throw shifter.
Rich
Club Member
Fri 30 Mar 18 20:23
CHUCK wrote (View Post):You Might find the PF46 is better for 2005/2006 C6. Thumbs up
You are quite right - it is a PF46 for a 2005.
I had PF48 in my mind as my C6s had LS3 engines and PF48 is the filter for the LS3 engine. I've amended my original post to avoid any confusion.
Rich Rogers
Davee
New Comer
Sat 31 Mar 18 08:38
Thanks for that info Rich and Chuck very helpful, and thanks for the offer of the pdf manual Rich !! is there any particular place to get fram filters from or just off e bay etc ? can anyone also tell me the oil capacity on the 2005, LS2 engine inc filter ? Thanks again lads happy Easter, and hopefully some decent weather comes soon !! Davee
Rich
Club Member
Sat 31 Mar 18 09:31
Eurovettes on here can supply the AC Delco filter and also the US spec Mobil 1 (if that is your preference) in the correct amount for you. The spec of the UK Mobil 1 is marginally different to the US spec.
Rich Rogers
C6NL
Club Member
Sat 31 Mar 18 11:05
Rockauto AC-Delco PF46E, just bought 4 for $3 a piece, and that was without the 10% forum discount code
Callaway Honker
Ported throttle body
Ported intake
Crane Cams 1.8 ratio rockers
Kooks Jet Hot coated headers
Pfadt Johnny O'Connel shocks
Hotchkis sway bars
Diablosport Trinity with custom tune
Brian Tooley Racing valve spring kit
When launching and stopping this beast, passengers may experience temporary black-out due to "G" forces
caused by acceleration and deceleration speeds faster than what they are normally accustomed to.
Dieter Orton
Club Member
Sat 31 Mar 18 13:23
Help wanted:I have a C6 four speed auto now with 80k miles from new.Unfortunately the car has started to judder and jolt when moving off in first gear and then from first to second,this resulted in the engine block light coming on.Initially, this fault code was shown to be a problem with the torque converter and a small amount of fluid,less than 100ml,appeared to solve the problem.Sadly the fault returned and I took the car to an auto specialist and sods law after half-hour test drive nothing untoward happened,but he did suggest that there was a slight misfire.I have had a complete major service done which included new plugs,leads, coils for each plug and all filters replaced.Took the car for a drive and it ran sweetly until I had some traffic and the jolting into gear returned and the fault light came on,any ideas would be most welcome.Regards Dieter
C6NL
Club Member
Sat 31 Mar 18 13:29
Dieter Orton wrote (View Post):Help wanted:I have a C6 four speed auto now with 80k miles from new.Unfortunately the car has started to judder and jolt when moving off in first gear and then from first to second,this resulted in the engine block light coming on.Initially, this fault code was shown to be a problem with the torque converter and a small amount of fluid,less than 100ml,appeared to solve the problem.Sadly the fault returned and I took the car to an auto specialist and sods law after half-hour test drive nothing untoward happened,but he did suggest that there was a slight misfire.I have had a complete major service done which included new plugs,leads, coils for each plug and all filters replaced.Took the car for a drive and it ran sweetly until I had some traffic and the jolting into gear returned and the fault light came on,any ideas would be most welcome.Regards Dieter
Perhaps a better plan would be to start your own topic, your question has nothing to do with the OP question
Callaway Honker
Ported intake
Hotchkis sway bars
Davee
New Comer
Sat 31 Mar 18 15:05
Hi guys, can anyone confirm how much oil is needed for a 2005, C6 , auto, inc filter change please , thanks again Guys
Reply to topic
Permissions
