CCCUK logo
 ShipMyCar.co.uk
Website Control
Recent threads
New Forum Posts
» BBCN Region CHRISTMAS Dinner by Nicetie on Wed 21 Nov 18 12:39
» Northeast regional, Breakfast Meeting Sun 9th December by Wacjac on Mon 19 Nov 18 22:00
» Replacement head unit for US spec C6 by c6pete on Mon 19 Nov 18 18:05
» NEC Classic Car Show - Birmingham by Chuffer on Mon 19 Nov 18 14:28
» Best Advertising Place?? by roscobbc on Mon 19 Nov 18 12:01
» 1982 Collectors Edition by kentvette on Mon 19 Nov 18 11:00
» C3 wanted by Jimbo64 on Mon 19 Nov 18 07:01
» C6 LED halos by Fraser on Sun 18 Nov 18 16:34
» 2007 Indianapolis 500 Pace car For Sale by Atomic Corvette 22 on Sun 18 Nov 18 12:44
» Heads/cam by Fraser on Sun 18 Nov 18 11:42
» 1978 C3 Corvette Silver Anniversary L82 Automatic by J Broom on Sun 18 Nov 18 10:01
» rear dampers by Norm on Sat 17 Nov 18 22:35
» My Ideal Vette by Redlevel on Sat 17 Nov 18 22:17
» 2007 C6 ZO6, Manual. by jackconcord on Fri 16 Nov 18 15:44
» 1986 c4 coupe silver/brown for sale by chevrolet on Fri 16 Nov 18 12:48
» C3 roof panel by curious bystander on Thu 15 Nov 18 15:56
» 2017 Tapas and Rioja Tour by kentvette on Tue 13 Nov 18 11:13
» C5 Z06 for sale (2002) by roscobbc on Tue 13 Nov 18 00:50
» Anyone know anything about this C5??? by roppa440 on Mon 12 Nov 18 11:38
» 94 In A 45 by kentvette on Sun 11 Nov 18 18:32
» Wanted.. Convertible C6 by Monty`s vette on Sat 10 Nov 18 16:10
» C6 Grand Sport Convertible by Monty`s vette on Sat 10 Nov 18 16:00
» My new C3 pace car by Nosheruk on Sat 10 Nov 18 12:04
» C3 jack, brace, spare tub bolts by MIT on Fri 09 Nov 18 21:03
» WTB: C6 Auto Coupe For Sale? by Atomic UK on Fri 09 Nov 18 02:27
» Spring Compressor by L88 on Thu 08 Nov 18 22:01
» Refurbishing wheels, factory finish by RumblinRon on Thu 08 Nov 18 13:45
» Visual differences US and Export models? by BlackZeD on Thu 08 Nov 18 13:28
» Help with newly acquired 72 350 Auto by Jimbo64 on Wed 07 Nov 18 16:52
» Coilovers by Daytona Vette on Wed 07 Nov 18 11:10
Oil Testing Service?
Reply to topic
Author
Message
leanmeanvettemachine
Club Member
Mon 02 Apr 18 20:13
Oil Testing Service? Message Icon
Hi all, this is my first proper post on the forum so be nice Smile
Yesterday when dipping my oil, I noticed some very faint white traces on the dip stick.
I immediately jacked up the car and drained some oil from the sump, half expecting to find a torrent of yoghurt. Much to my relief, the oil looks normal. However, when you let the oil streak down the sides of a container you can just make out some faint white streaks.
Obviously seeing white anything in my oil immediately makes me think blown head gasket, but the car is only a 2012 model with 24k miles, so it seems pretty unlikely to me that the head gasket could have failed so soon..
I was thinking it might be worth having an oil analysis done to determine if this is just some condensation from the cold winter weve had, or if this is more serious (i.e. glycol in the oil). Do any CCCUK members have experience with an oil testing service in the UK?
Thanks,
Alex
'12 C6 Coupe (LS3 + TR6060)
Follow my build on IG @v8tor_17
roscobbc
Mon 02 Apr 18 20:23
Re: Oil Testing Service?
Have you actually observed loss of coolant?
How long since the engine was run?. Did the engine and all liquids get the chance to heat through thoroughly on the last run? Have you done an oil change since you've had the car?
CCCUK Chairman
Vetteheadtony
Club Member
Mon 02 Apr 18 22:54
All important points Ross has made, probably thinking the same as me, just some condensation from short run periods over the winter.
Vetteheadtony
2004 Z06 lemans edition pro charged
613 BHP
Black C6 ZR1 wheels
FECKING FAST!!!
roscobbc
Tue 03 Apr 18 00:23
Tony being a cabbie will remember (before the days of electric fans operated by a vehicle ecu) seeing many black cabs in winter with a piece of alloy or plywood blocking half the radiator grille - same with trucks. This would made sure the engine would be running at a higher temperature to avoid oil contamination (and made the inadequate heaters work better) - a hot running (but not overheating) engine is always more efficient in all respects. And never run without a thermostat.
CCCUK Chairman
Redlevel
Club Member
Tue 03 Apr 18 11:03
2012 and 24k miles... That's the problem right there. Yes
Why not just use the car and get it hot to burn off all the moisture out of the oil, brake fluid, trans fluid and the electrical connections etc.. It'll do it the world of good.
These cars are not meant to be pampered, they are seriously robust performance cars that like to be used, so why not just enjoy it instead of keeping it nice for the next owner. So what if it gets dirty and salty, that's why God gave us the jetwash!
Club Member
Tue 03 Apr 18 11:34
Thanks guys.
First of all to answer roscobbc questions - I last flushed out the coolant about 5 months back and haven't touched it since. Looking now, I'd say the level in the expansion tank has dropped about 7mm from the max cold mark. I honestly can't say over how long it has taken to drop, as I've only glanced at the tank to check there was fluid in there, not checked in detail until now.
The last run I made was the previous week. Drove about 100 miles, where the oil temp definitely had the chance to get up ~230F.
Last oil change was ~1,200 miles ago in December. However, I did put in some Royal Purple HPS, which is technically not a GM spec. compliant oil. I'm wondering if, because this is a 'racing' oriented oil, that it could be more prone to moisture absorption than conventional 5w-30..? Scratchchin
As Vetteheadtony says, this could just be some winter humidity...
Either way, do you reckon I should get the oil tested for glycol before firing her up again?
Cheers,
Alex
Last edited by leanmeanvettemachine on Tue 03 Apr 18 11:34; edited 1 time in total. [1 %]
Redlevel
Club Member
Tue 03 Apr 18 12:27
Royal Purple is just a full synth with a molecular additive like Actv8 or ZX1. Good stuff and as its a full synthetic, it doesn't need changing for a long time. I use Mobil 1 with Activ8 and change it every two years or 20k miles.
Find RP comparison in here.. http://www.animegame.com/cars/Oil%20Tests.pdf
If it were mine, I'd be getting in some serious miles on it and at a fair lick too and just keep an eye on the gauges. If there's a problem, you'll know it soon enough..
666Vette
Thu 05 Apr 18 20:38
Hi Alex,
contact Stuart Harbottle at www.advancedlubricant.solutions
info @ advancedlubricant.solutions
0191 267 3718
I have already primed him.
They are the UK agents for Royal Purple and have a great interest in Corvettes amongst other racing vehicles.
Hope this helps.
Cheers
Allen
________________________
50th Anniversary Convertible
NCM # 500458
CCCUK Membership Secretary
Club Member
Fri 06 Apr 18 10:40
666Vette wrote (View Post):Hi Alex,
0191 267 3718
Hope this helps.
Thanks very much Allen, Ill be sure to take note of their details.
So after a couple days of letting her sit and doing a few odd jobs, I decided to take her out for a drive. Pulling over and checking the oil every few minutes, I'm somewhat embarrassed, but relieved to say that all appears well and there are no longer any traces of white in the oil.
As you guys speculated, the white streaks must have been a result of condensation from the cold weather weve been having. Having never used Royal Purple before (especially with it being a deep purple hue) it must be characteristic of the oil to show up any minute traces of water that are present, which would probably go unnoticed in a brown/golden coloured oil. Doh
Anyway, thanks a lot for all of your feedback. Apologies for the run-around!
Reply to topic
Permissions
