CCCUK logo
 Adrian Flux
Website Control
Recent threads
New Forum Posts
» This! by chevrolet on Mon 25 Jun 18 18:37
» STOP PRESS ADDITIONAL BREAKY MEET AAC UK Summer NATS by Daytona Vette on Mon 25 Jun 18 16:54
» Sunday 1 july by roscobbc on Mon 25 Jun 18 13:29
» Trade War US Imports by roppa440 on Mon 25 Jun 18 08:59
» How Mechanically Similar Or Different Is A C4 Corvette To A European Car? by roppa440 on Mon 25 Jun 18 08:51
» Temporary targa cover by chevrolet on Sun 24 Jun 18 22:17
» Spare tyre by curious bystander on Sun 24 Jun 18 21:18
» C8 by Gort on Sun 24 Jun 18 20:05
» Electric headlight actuator conversion by MIT on Sun 24 Jun 18 12:45
» Kimbolton Country Fayre 8th July by autocolor on Sun 24 Jun 18 09:10
» The Cars the Star Show by STELTHYFLATFISH on Sat 23 Jun 18 11:52
» New owner by Tattooboy on Fri 22 Jun 18 22:22
» Corvette-Fame 13-14-15 July 2018 by Atomic Corvette 22 on Fri 22 Jun 18 19:10
» Nationals Questions by yenko 1969 on Fri 22 Jun 18 17:55
» The Classic & Sportscar Show by CDC on Thu 21 Jun 18 19:31
» Love This Sound by roscobbc on Thu 21 Jun 18 19:09
» Lights by Sid.123 on Thu 21 Jun 18 15:55
» Cigarette lighter by Sid.123 on Thu 21 Jun 18 00:00
» Dead battery, power window closing. by Grahamred70 on Wed 20 Jun 18 21:38
» Taxation by Nigelcurry on Wed 20 Jun 18 17:43
» V55/5 advise by JJVETTE on Wed 20 Jun 18 14:56
» 1978 C3 Corvette Silver Anniversary L82 Automatic by Barry scard on Wed 20 Jun 18 14:55
» c5 repairs and servicing by Bowler on Wed 20 Jun 18 08:53
» Manchester Car Show - 15/16 September 2018 by davidlarkins on Tue 19 Jun 18 21:52
» C3 1975 Small Block SIde Pipes by JJVETTE on Tue 19 Jun 18 20:45
» What did you do with your Vette today? by MIT on Tue 19 Jun 18 20:36
» Developing Starter Issue by Sid.123 on Tue 19 Jun 18 13:34
» New uk owner by Sid.123 on Tue 19 Jun 18 11:21
» Headlamp bulbs by berg944 on Tue 19 Jun 18 09:08
» clicking sound non starting.. only when jump started by L88 on Tue 19 Jun 18 08:24
C2 - Headlamp Not rotating
Reply to topic
Author
Message
Bowler
Tue 17 Apr 18 09:09
A query for the C2 gurus amongst us.... Confused
After standing all winter, I've discovered that the LH (near side) Headlamp unit on my 66 Convertible, will not now rotate.
When activating the (rotation) switch, I can hear the motor click, the lamp unit moves slightly, but after that it's dead
It's possible to manually rotate the headlamp (with the knob) but electrically it's doing nothing,. However the RH unit has no issues and all 4 headlights illuminate
Upon investigation, I've discovered that the torque reaction bracket, that is mounted between the motor body and the steel cross member (that is bonded into the GRP nose cone), is loose. This is because the bolt has sheared, leaving the thread embedded in the cross member
My gut feel is that the torque bracket is also an electrical connection, so that as soon as the motor moves, it twists the torque bracket away from the body and breaks the circuit, so the motor stops...
Questions
--> Has anyone heard of this before?
--> Will addressing the torque bracket fix the problem, or is it likely to be something else?
--> How can I get the broken fixing out out of the steel cross member?
--> If trying to address the broken fixing is a major issue due to access, is tack-welding it an option?
Thanks in advance for any help
Guy Waltham
2003 Euro Spec Coupe.
1966 Convertible
I suffer from an addiction called CH³ No² - a disease with no known cure....
JJVETTE
Club Member
Tue 17 Apr 18 11:18
Re: C2 - Headlamp Not rotating
Hi Guy ,
I have asked a C2 Guru for info ...
as soon as I get an answer I will post it here .
Jeff
L88
Club Member
Tue 17 Apr 18 15:29
The bracket is where the motor gets its neg from. Loose bracket =poor earth. Fatter self tapper or try with a lead from earth to motor housing.
Unlikely but it could be the limiter switch for that motor or of course it's died.
Something like this:
https://youtu.be/W08d4hpsDgI
Bowler
Wed 18 Apr 18 07:01
@ Jeff: Thanks for the offer of help
@ L88: Thanks Frank. As you can probably tell I suspected that it was a failed electrical connection with the bracket. My only real issue is now is how to try and drill the cross member in such an awkward position
Thanks again both. It is very much appreciated
Guy Waltham
1966 Convertible
Reply to topic
Permissions
