 ShipMyCar.co.uk
» C5 Headlamp Adjusters "Golden Rods" by Le Vette on Wed 15 Aug 18 09:53
» Drag event... by roppa440 on Wed 15 Aug 18 08:35
» Heads/cam by Fraser on Tue 14 Aug 18 21:40
» Shooting for 1000whp with my C7 @ Top Cats Racing by Sierra on Tue 14 Aug 18 14:19
» Spare wheel light by kentvette on Tue 14 Aug 18 08:46
» 2003 Anniversary Red and Shale Convertible. by Number3 on Tue 14 Aug 18 07:11
» U-joint replacement by MIT on Mon 13 Aug 18 22:37
» C6 European Rear Light Conversion by Daytona Vette on Mon 13 Aug 18 16:42
» Full geo setup needed. by Daytona Vette on Mon 13 Aug 18 10:33
» C3 Side Exhaust Pipes by CaptainK on Mon 13 Aug 18 10:00
» Kit Kat wrappers don't make good insulation by CaptainK on Mon 13 Aug 18 09:52
» Head Unit Replacement by L88 on Sun 12 Aug 18 13:57
»  by Chris123 on Sun 12 Aug 18 12:24
» 1968 Door Handles by riddyboy on Sat 11 Aug 18 08:54
» Aircon fixed at last! by Daytona Vette on Fri 10 Aug 18 13:29
» Headlight Buckets by kentvette on Fri 10 Aug 18 09:40
» C3 Auto Box Issue Just Developed by Daytona Vette on Thu 09 Aug 18 22:52
» CCCUK West Sussex meeting tonight 9th August by Sea5 on Thu 09 Aug 18 18:27
» History of my vehicle VJD 5G by Bill Riches on Thu 09 Aug 18 16:58
» Borgeson steering box upgrade. by Skeets on Thu 09 Aug 18 13:19
» Cumbria classic (Dalemain House) car show. Sunday 19th August by 666Vette on Thu 09 Aug 18 12:26
» Concours of Elegance by curious bystander on Wed 08 Aug 18 16:47
» What did you do with your Vette today? by MIT on Wed 08 Aug 18 15:31
» South Central Regional Meeting for August by Daytona Vette on Wed 08 Aug 18 10:35
» Some Subtle Mods to my C7 Stingray by C7KEN on Tue 07 Aug 18 22:01
» Boston Bowl - American Meet and Family Day - Saturday 11th August from 11:30am by cjc on Tue 07 Aug 18 15:02
» New alloys - size advice by CaptainK on Tue 07 Aug 18 14:57
» Modified C5 for Sale by Bowler on Tue 07 Aug 18 13:57
» Local c3 garage services. by MIT on Mon 06 Aug 18 23:14
» Raby castle classic vehicle show Sunday 12th August. by STELTHYFLATFISH on Mon 06 Aug 18 15:45
Parking brake adjustment
Nigelcurry
Tue 17 Apr 18 09:44
Hi all
The parking break on my 79 coupe may need adjusting in the near future and having taken a look at the hubs,I can only see holes for star wheel adjustment on the rear rotors,does this mean the parking break is only adjustable from the rear and there is no parking break operation from front.All the hubs still have the rivets in them so I,m thinking parking break operation is kind of similar to most cortinas of the seventies etc
Thanks for any feed back guys
Nige
Redlevel
Tue 17 Apr 18 10:12
Re: Parking brake adjustment
On my '87, all you have is a hole in the front of the drum/disc so you click the star wheel around with a screwdriver til the wheel locks then back it off four clicks so it runs free then adjust the cable to take up the slack. I usually click on the lever about two clicks before I start this.
A bit of advice is to lock a length of steel bar over the lug bolts (or refit the wheel if you can be *rs*d) to turn the hub as it's important to get a full revolution when you do this 'turn test' to negate any effect of a slightly oval drum that the parking brake shoes act upon.
Apologies if the '79 is different.. Smile
Vetteheadtony
Tue 17 Apr 18 12:07
stevel98 wrote (View Post):On my '87, all you have is a hole in the front of the drum/disc so you click the star wheel around with a screwdriver til the wheel locks then back it off four clicks so it runs free then adjust the cable to take up the slack. I usually click on the lever about two clicks before I start this.
Finally Steve someone knows how to properly adjust brakes, you should get a job at my Taxi’s main agent because none of the melts that work there seem to know!! Thumbs up
Vetteheadtony
2004 Z06 lemans edition pro charged
613 BHP
Black C6 ZR1 wheels
FECKING FAST!!!
Redlevel
Tue 17 Apr 18 12:21
Cheers! Very Happy
I got right into it because there are a few C4 n/s parking brake cables around that are in fact about 25mm too long! You don't notice it because your fitting a new cable and you expect it to be correct.
Mine came from a UK supplier. After an epic task of cursing and trying adjust the brake correctly, I eventually figured the cable was too long and it was. Bought another from Rockauto and compared them and sure enough the UK one was too long which meant it wouldn't pull up when adusted.
Assuming all parts are correct, the important part is to turn the hub a few 360deg revs to ensure it turns ok when you back it off.
Nigelcurry
Tue 17 Apr 18 16:18
Thanks gents
Please forgive me for sounding stupid but judging by your info the fronts don’t enter in to the operation,(haven’t been able to access underside of car yet)
Nige
Redlevel
Tue 17 Apr 18 16:36
The e-brake system only operates on the rear wheels. The lever in the car will tug on twin cables, one to each back wheel.
If your taking a look at it, make sure the cables actually move when the lever is pulled as they can seize up. If they have seized, just buy new ones, don't waste time on the old ones trying to free them off.
Tue 17 Apr 18 19:15
Nigel
The adjustment of the C3 parking brake can be tricky to stay the least, and there is a "regime". It will help if you have the manual or the AIM, or at least a diagram of the adjuster mechanism in the rear "drum/rotor assembly".
Firstly, you'll need both rear wheels off the ground (car on jack stands) and remove them. (In an ideal world, remove the driveshaft and bake calliper, but thats's probably a step too far for now!) In the centre of the car you'll find the front cable joins the rear "cross-cable" and has a screw adjuster. Slacken this off.
Then, you'll need to turn the wheels so that you can get a screw driver into one of the larger holes and screw the adjuster in or out. (If you are very clever you'll be able to see the thread and work out which way to "click" the adjuster to get it to tighten the shoes, i.e. expand.) You want to screw it out so that you lock the wheel. Then release it about 8 - 10 "clicks" on the adjusting wheel. Do the other side the same. There then should be no sign of the brake shoes "dragging". Then, you'll need to tighten the central crew adjuster on the front cabe until it is tight enough to just move the rear cable. I do mean "only just"!
Replace the wheels and go for a test run of about 2 miles. Stop and immediately feel the rear wheel centres to see if they are hot. If so, the brakes are binding and you'll need to back off the wheel adjusters a tad. If not, great. And then, see if the parking brake actually works! Highly likely you'll be disappointed, but "Tthey are all like that, sir"!
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
roscobbc
Tue 17 Apr 18 20:12
Its not a bad (albeit a little expensive) idea to replace all parking brake components at the same time. You don't really want to be doing the job twice - not saying its a nasty job (but it can be). Auto's usually have the worst issues with parking brake as its rarely used by many drivers. The steel brake mechanism rusts and seizes. The hot tip is to replace all components with stainless steel items. It'll stop corrosion but if you maintain things properly you won't have an issue with standard parts. The fundamental design of the parking brake is its main issue. You're asking for two pairs of Honda 50 sized brake shoes to arrest the movement of a vehicle 15 times the weight of the scoot. Irrespective of whether you use standard mild steel brake shoes or stainless they are all weak, thin and will flex with aggressive operation causing the lining material to crack. If the brake hub rivets are still in place then this will be the first time for a overhaul - you don't need to replace them. Best add a new parking brake cable to the list as they stretch with use and age.......
CCCUK Chairman
Nigelcurry
Wed 18 Apr 18 08:59
All great and VERY helpful advice and info thanks very much lads
Nige
