CCCUK logo
 Lancaster Insurance
Website Control
Recent threads
New Forum Posts
» Heads/cam by Redlevel on Sat 17 Nov 18 09:50
» rear dampers by johng on Sat 17 Nov 18 08:26
» Replacement head unit for US spec C6 by Slick on Sat 17 Nov 18 08:20
» 2007 C6 ZO6, Manual. by jackconcord on Fri 16 Nov 18 15:44
» NEC Classic Car Show - Birmingham by curious bystander on Fri 16 Nov 18 15:11
» Northeast regional, Breakfast Meeting Sun 9th December by STELTHYFLATFISH on Fri 16 Nov 18 13:20
» 1986 c4 coupe silver/brown for sale by chevrolet on Fri 16 Nov 18 12:48
» C3 roof panel by curious bystander on Thu 15 Nov 18 15:56
» 2017 Tapas and Rioja Tour by kentvette on Tue 13 Nov 18 11:13
» C5 Z06 for sale (2002) by roscobbc on Tue 13 Nov 18 00:50
» Anyone know anything about this C5??? by roppa440 on Mon 12 Nov 18 11:38
» 94 In A 45 by kentvette on Sun 11 Nov 18 18:32
» Wanted.. Convertible C6 by Monty`s vette on Sat 10 Nov 18 16:10
» C6 Grand Sport Convertible by Monty`s vette on Sat 10 Nov 18 16:00
» My new C3 pace car by Nosheruk on Sat 10 Nov 18 12:04
» C3 jack, brace, spare tub bolts by MIT on Fri 09 Nov 18 21:03
» WTB: C6 Auto Coupe For Sale? by Atomic UK on Fri 09 Nov 18 02:27
» Spring Compressor by L88 on Thu 08 Nov 18 22:01
» My Ideal Vette by Jack75 on Thu 08 Nov 18 16:59
» Refurbishing wheels, factory finish by RumblinRon on Thu 08 Nov 18 13:45
» Visual differences US and Export models? by BlackZeD on Thu 08 Nov 18 13:28
» Help with newly acquired 72 350 Auto by Jimbo64 on Wed 07 Nov 18 16:52
» Coilovers by Daytona Vette on Wed 07 Nov 18 11:10
» CCCUK West Sussex meeting in November by robbiew on Wed 07 Nov 18 10:48
» South Central Regional Supper Club Meet by Daytona Vette on Tue 06 Nov 18 17:35
» Car Control by philv8 on Tue 06 Nov 18 14:51
» BBCN Region CHRISTMAS Dinner by Nicetie on Tue 06 Nov 18 12:54
» New Exhaust Controller for non-TPP C6 going cheap by 86vetteman on Tue 06 Nov 18 11:52
» Corvette required by roscobbc on Mon 05 Nov 18 22:19
» Original 2009 C6 tyres by BlackZeD on Mon 05 Nov 18 18:04
Modified C5 for Sale
Go to page: 1, 2 / Next
Reply to topic
Author
Message
Sinatra21
Club Member
Wed 30 May 18 18:45
Corvette C5 Torch Red 2000
LS1 5.7 V8 360 BHP
107k
Auto
MOT till August can get full 12 months
£15 000
Bodywork & Exterior
The paintwork is very good, not just for a car of its age itís in genuine nice condition. It still polishes and shines great and hasnít gone pink like so many older red cars. It does however have a couple of small imperfections as it is 18 years old.
The car is originally a Euro Spec car but underwent some modifications by the previous owner. These were carried out by a garage called custom exotics (take a look at their website, they deal with a lot of American cars). On the outside these modifications included converting the rear bumper to US spec (this gets rid of the nasty reflectors in the bumper), fitting a reversing camera to the rear number plate surround, F1 style fog light fitted between the exhaust, painted number plate surround and black lettering of the corvette logo. The rear lights have been tinted black along with the side repeaters and the wing mirrors have also been painted. The side and rear windows have been professionally tinted
The car has also been fitted with sill protectors that run the length of the car and castor wheels at the front that allow the car to be pushed up over higher speed bumps rather than catching on the front bumper (which is quite long on these cars)
Wheels are Forgester and where imported from the states. They are 19Ē rear and 18Ē front and are staggered. They are shod in Goodyear Eagle tyres all with plenty of tread (approx. 5mm). Small details like the centre caps and even the tyre valves have the corvette racing logo on them. The car has also kept the tyre pressure monitoring system (TMPS) which works as it should.
The car is lowered on standard shocks so retains its ride comfort whilst looking low. The rear has had a lowering block fitted so the car sits straight.
Engine & Performance
The car has the standard LS1 5.7 V8 engine, that runs through a 4 speed Auto gearbox. It has the sport 3.15 Rear diff fitted (a rare factory option). The engine starts and runs fine with plenty of power and torque as you would expect from a car of this nature. The engine has had a custom remap from the states using a Diablo I2 intune device. This allows certain parameters to be changed from a small hand held device such as timing and fuelling as well as torque management settings. The standard map for the car can be but back on within about 30 seconds if required. The remap usually nets around 15-20 bhp but most importantly it changes the shift points and shift times of the auto box giving a better response.
The auto box itself was rebuilt last year after a failed O ring allowed fluid to leak out. I had the box re built using Raybestos clutch packs and also had a large aftermarket transmission cooler fitted as the standard trans cooler is built into the radiator and is quite small (Receipts for work available).
After market exhaust was made by Profusion, it is an over axle system and has had the tips painted black to keep with the theme of the car. It gives a great noise at higher rpm but is not intrusive in the car and is very civilised at motorway cruising speeds.
The car has a large amount of service history and has been regularly serviced. It has been in the Corvette owners club for many years and has been well looked after. In my ownership as well have having the gearbox rebuilt I have fixed a couple of small niggles like the outside temp sensor, replaced a front wheel bearing (this was a Timkin part ordered from the states) and last month the oil was changed (5-30w Mobil one).
ABS and Traction control are fitted as standard.
All 4 brakes have been replaced with upgraded drilled rotors with Hawk pads fitted to the front. The callipers have been painted red with black corvette lettering.
Interior
Standard electric windows, climate control, electric mirrors all work as they should. The car has been given a refresh inside by Custom Exotics to give it a more modern look. This included a full strip down of the interior and fitting of heavy duty sound deadening and new carpets. The centre counsel has had the old tap/cd player removed and replaced with a pumpkin android tablet. This is a DVD/CD player as well as radio. You can tether your phone to it and use it as an android tablet. Access the internet and use google maps for navigation. The reverse parking camera is also displayed here when the car is put into reverse. A new surround was made to look like stock and fit around the headunit. There is also a hands free kit fitted with microphone above the rear view mirror, once your phone is blue toothed to the head unit you can make and receive calls.
The seats are Corbeau, again imported from the states and are designed for the C5. They give much better support than standard seats and are comfy even on longer journeys. To match the seats the armrest and gear gaiter have been wrapped in carbon effect trim. The gear stick has a corvette racing logo etched into it.
There is a momo steering wheel with quick release hub, the airbag light has been correctly mapped out so there are no warning lights. I have the original wheel to go with the car.
The headsup display (HUD) works and been a euro car can flick between MPH and KM.
Two sets of floor mats come with the car a standard black set and a show set embroidered with the corvette logo. There is a rear cover over the boot with the corvette logo and I have an indoor car cover to fit the car too.
If youíve read all of that and have any more questions please drop me an message. The car has been cherished and it shows. I dare say this is one of the cleanest C5ís for sale.
I also have all the service manuals.
I have loads of pictures that i'll upload shortly as my photobucket account doesn't host anymore.
The car is located in Birmingham.
Sinatra21
Club Member
Wed 04 Jul 18 14:40
Re: Modified C5 for Sale
Price drop to 15 500, will have a fresh MOT as of next week.
Shifty
Awww... join the CCCUK!
Wed 04 Jul 18 21:21
Very pretty! Good luck with the sale.
2004 Corvette C5 Coupe
2003 Suzuki GSX-R1000
roppa440
Club Member
Fri 06 Jul 18 09:52
That is a STEAL at just £15,500.
C5 Corvettes are actually starting to edge up in value these days. So its a great time to buy one. Yes
dex99
Club Member
Fri 06 Jul 18 16:11
This is Colin's old car, cracking car
Sinatra21
Club Member
Thu 12 Jul 18 10:49
Now with 12 Months MOT, (no advisors)
Sinatra21
Club Member
Mon 06 Aug 18 14:57
Price drop to £15,000
Firepit
Club Member
Mon 06 Aug 18 21:30
OMG that's a ridiculously low price. What's the matter with the C5 market these days?
Banghead
C5 in custom made Firepit Orange color with Billy Boat Bullet exhaust, MGW short shift, Wilwood Superlite front brakes, Venair Orange Silicon hoses and Evans waterless coolant. Custom mural under hood with wheels and other accessories in Thunder Grey. Illuminated Sills and Firepit Orange interior.
roppa440
Club Member
Tue 07 Aug 18 08:50
I had the same bother when I tried to sell my C5 a few years ago.
You just get time wasters who want thousands of high resolution images of every inch of the car because they can't be arsed to come and look at it themselves and then ask if it has ever been driven in the rain because they don't want one that has. Banghead
Bowler
Club Member
Tue 07 Aug 18 12:57
Firepit wrote (View Post):OMG that's a ridiculously low price. What's the matter with the C5 market these days?
Banghead
My guess is that most of them in the UK aren't for sale and those that do come onto the market are from owners that may want to move on to the next project. I'm not saying that the sellers are desperate, but we all know that we also need to find the right buyer, so patience is the key.
Obviously if there is any urgency, then normally the quickest way to get things moving is the price. However in the case of a Corvette, I don't actually think that price is the major factor...
2003 Euro Spec Coupe.
1966 Convertible
I suffer from an addiction called CH≥ No≤ - a disease with no known cure....
Reply to topic
Permissions
You can download files in this forum
