CCCUK logo
 Lancaster Insurance
Website Control
Recent threads
New Forum Posts
» C2 fibreglassing and stuff by L88 on Sun 16 Sep 18 16:15
» Resto Vette - or - Modifed Vette by Vetteheadtony on Thu 13 Sep 18 14:16
» Spare wheel light by fordpop52 on Mon 10 Sep 18 07:14
» My 01 c5 yellow for sale by Celcius on Sun 09 Sep 18 20:58
» For Sale 09 C6 Corvette by John Lynn on Sun 09 Sep 18 01:25
» C2 Bonnets by L88 on Sat 08 Sep 18 22:56
» BBCN Regional meet by autocolor on Sat 08 Sep 18 09:48
» Interesting Article by philv8 on Fri 07 Sep 18 23:54
» Heads/cam by Fraser on Fri 07 Sep 18 16:26
» Carburettor leaking by Genghis on Fri 07 Sep 18 14:43
» z51 to z06 by The Dark Knight on Fri 07 Sep 18 08:21
» End of an Era by Firepit on Thu 06 Sep 18 23:39
» Sharing the joy! by Invetterate on Thu 06 Sep 18 21:14
» Seatbelt refurb by curious bystander on Thu 06 Sep 18 20:32
» 1978 C3 Corvette Silver Anniversary L82 Automatic by geoff917 on Thu 06 Sep 18 20:03
» Loose handbrake lever by Jeremyflashman@gmail.com on Wed 05 Sep 18 21:23
» speed bleeders by damc3 on Wed 05 Sep 18 19:27
Water pump leak.
Go to page: 1, 2 / Next
Reply to topic
Author
Message
MIT
Club Member
Fri 08 Jun 18 20:22
Water pump leak.
Hi, first day of c3 ownership, first mechanical failure! Parked the car in the garage, and it weed on the floor, looks to be coming from the pump, possibly back plate. Iím going to remove it and have a look. Whereís best for gaskets in the U.K.?
Cheers, tim.
Tim.
74 coupe.
Mick Howes
Club Member
Fri 08 Jun 18 20:26
Re: Water pump leak.
Try Corvette kingdom, Eurovettes or Claremont Corvette. You can also use Rock Auto, I have had quite a few parts for both my C3 and C4s, things like brakem pads, seals, drive belts etc etc
just Google any of these and you'll find their websites and details
C4- ok now officially a convert!
www.mickhowes.freewebspace.com
MIT
Club Member
Fri 08 Jun 18 20:40
Cheers, I have a sheared headlight actuator pipe fitting as well, thatís been glued badly in the past so need one of those.
Tim.
74 coupe.
Sid.123
Club Member
Fri 08 Jun 18 20:51
If it was me and i had to take the water pump off.. Id be replacing it... From rock auto...
59/69 silver beige/medium brown. 1 of 1,014 in 1986. C4 glasstop
MIT
Club Member
Fri 08 Jun 18 21:02
Hi, the pumps relatively new, but itís not been used much since the engine was built, only 360 miles on it, so Iím hoping itíll just be an iffy gasket. Iíll hopefully know more once itís off.
Tim.
74 coupe.
Vetteheadtony
Club Member
Sat 09 Jun 18 07:27
As Sid says, new pump not worth messing around with!
ACDelco one at Rockauto with gasket £25+p&p
https://www.rockauto.com/en/catalog/chevrolet,1981,corvette,...
Vetteheadtony
2004 Z06 lemans edition pro charged
613 BHP
Black C6 ZR1 wheels
FECKING FAST!!!
MIT
Club Member
Sat 09 Jun 18 13:06
Well, thatís pretty conclusive, sure I shouldnít be able to see daylight through it!. Just happy it went now and not on itís first outing. New pump it is!
Tim.
74 coupe.
Vetteheadtony
Club Member
Sat 09 Jun 18 13:33
MIT wrote (View Post):Well, thatís pretty conclusive, sure I shouldnít be able to see daylight through it!. Just happy it went now and not on itís first outing. New pump it is!
Found these for you Tim,
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.eb...
Water pump from Rockauto as above.
ThoseYanks always a bit slippery when telling you about faults, still donít seem like to many issues, need any help/advise feel free to call me Tony Thumbs up
Vetteheadtony
613 BHP
Black C6 ZR1 wheels
FECKING FAST!!!
MIT
Club Member
Sat 09 Jun 18 13:39
Cheers Tony, Just removed the faulty actuator, and tested the other one, seems ok, but as Iím at it Iíll change them both. I removed the bonnet for better access. Iíll test the other bits in the system before I order anything.
Itís been quite fun sad to say. Smile
Tim.
74 coupe.
Grahamred70
Club Member
Mon 11 Jun 18 18:52
Are you using 50/50 antifreeze? had the same happen on a volvo generator after some numpty diluted ready mixed coolant, failed after only about 4 months running, cavitation in the pump with the incorrect coolant.
Graham
Graham, red 1970 convertible 350
Reply to topic
Permissions
