CCCUK logo
 Adrian Flux
Website Control
Recent threads
New Forum Posts
» This! by chevrolet on Mon 25 Jun 18 18:37
» STOP PRESS ADDITIONAL BREAKY MEET AAC UK Summer NATS by Daytona Vette on Mon 25 Jun 18 16:54
» Sunday 1 july by roscobbc on Mon 25 Jun 18 13:29
» Trade War US Imports by roppa440 on Mon 25 Jun 18 08:59
» How Mechanically Similar Or Different Is A C4 Corvette To A European Car? by roppa440 on Mon 25 Jun 18 08:51
» Temporary targa cover by chevrolet on Sun 24 Jun 18 22:17
» Spare tyre by curious bystander on Sun 24 Jun 18 21:18
» C8 by Gort on Sun 24 Jun 18 20:05
» Electric headlight actuator conversion by MIT on Sun 24 Jun 18 12:45
» Kimbolton Country Fayre 8th July by autocolor on Sun 24 Jun 18 09:10
» The Cars the Star Show by STELTHYFLATFISH on Sat 23 Jun 18 11:52
» New owner by Tattooboy on Fri 22 Jun 18 22:22
» Corvette-Fame 13-14-15 July 2018 by Atomic Corvette 22 on Fri 22 Jun 18 19:10
» Nationals Questions by yenko 1969 on Fri 22 Jun 18 17:55
» The Classic & Sportscar Show by CDC on Thu 21 Jun 18 19:31
» Love This Sound by roscobbc on Thu 21 Jun 18 19:09
» Lights by Sid.123 on Thu 21 Jun 18 15:55
» Cigarette lighter by Sid.123 on Thu 21 Jun 18 00:00
» Dead battery, power window closing. by Grahamred70 on Wed 20 Jun 18 21:38
» Taxation by Nigelcurry on Wed 20 Jun 18 17:43
» V55/5 advise by JJVETTE on Wed 20 Jun 18 14:56
» 1978 C3 Corvette Silver Anniversary L82 Automatic by Barry scard on Wed 20 Jun 18 14:55
» c5 repairs and servicing by Bowler on Wed 20 Jun 18 08:53
» Manchester Car Show - 15/16 September 2018 by davidlarkins on Tue 19 Jun 18 21:52
» C3 1975 Small Block SIde Pipes by JJVETTE on Tue 19 Jun 18 20:45
» What did you do with your Vette today? by MIT on Tue 19 Jun 18 20:36
» Developing Starter Issue by Sid.123 on Tue 19 Jun 18 13:34
» New uk owner by Sid.123 on Tue 19 Jun 18 11:21
» Headlamp bulbs by berg944 on Tue 19 Jun 18 09:08
» clicking sound non starting.. only when jump started by L88 on Tue 19 Jun 18 08:24
Front indicator/side light mod without switchbacks
Reply to topic
Author
Message
MIT
Club Member
Tue 12 Jun 18 01:48
Hi, Iíd like to sort the front indicators/side lights, as my switchbacks are doing odd things.
Iím going to use the side wing mounted running light as a side indicator, but want to separate the current side/indicator light. But, as it currently flashes the side light, how do I overcome this? Iím happy to drill the current light assy and fit an additional orange lamp for an indicator, using the old lamp as a side light only.
Any ideas?
Cheers, Tim.
Tim.
74 coupe.
Club Member
Tue 12 Jun 18 09:35
Re: Front indicator/side light mod without switchbacks
It is not the method I used, but quite a few people have added a bulb into teh existing side/indicator lamp unit. I understand that if you drill into it and fit one of those rubber mounted bulb holders for the indicator lamp, the orange will "overpower" the white side light when it flashes, so showing a yellow flasher, but white side light. You just need to separate the wiring from the original bulb holder..
I have included the side marker lamps in the indicator circuit on ours. I was unhappy with showing an amber lamp, in case it was cinfused with an indicator and someone pulled out in front of me!
You need to remove the side marker from the original wiring loop and add a wire from the indicator circuit directly to it, so that it flashes in time (not alternately) with the front indicator. I have only fitted a pretty low powered bulb, as anything too high will speed up the flasher unit too much. By adding, I think, about a 4 or 5 watt bulb, the flasher speed has risen slightly, to within the legal tolerance (in case anyone ever measures that!)
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
MIT
Club Member
Tue 12 Jun 18 16:38
Thanks for the info, thatís exactly what I was thinking of doing. My switchback flash at different speeds, depending if side or main beam is on.
So I just separate the indicator wire, run it plus an earth to a new 5w lamp, drill the existing sidelight, then also route the indicator wire to the marker, thatís it?
Also, do you know if the front orange marker is a direct replacement for the rear red marker, so I have side rear indicators?
Cheers, tim Thumbs up
Tim.
74 coupe.
MIT
Club Member
Tue 12 Jun 18 19:45
Iíve just swopped out the front and rear markers, and they are a direct fit. Thumbs up
Tim.
74 coupe.
sublimemike
Club Member
Tue 12 Jun 18 21:48
My 70 had the orange bulb. I effectively split the the lens by removing the bulb holder, cutting and radiusing a piece of ally then siliconing it in place to allow for a bulb either side. I then wired different coloured LED bulbs each side from the existing bulb holder. I also needed to change the flasher unit for a solid state type. It works well with little bleed.
A phaff to radius the ally but the good thing is I didn't have to chop the wiring up. It would be straight forward to return this to stock if anyone wanted to.
MIT
Club Member
Wed 13 Jun 18 00:57
Was the flasher unit change due to the use of ledís?
Tim.
74 coupe.
Club Member
Wed 13 Jun 18 09:38
MIT wrote (View Post):Thanks for the info, thatís exactly what I was thinking of doing. My switchback flash at different speeds, depending if side or main beam is on.
Tim, That sounds about it! The old style flasher unit is a bi-metal unit, so affected by the drain on it. American flashers are always a little slow compared to the UK, so the addition of the 5 W bulb in the side marker speeded it up to the UK spec!
I didn't know that the front and rear side markers were the same, I know they looked it, but I've never tried to swap. (I still run the rears as red side markers) You may need to think about the replacement flasher unit mentioned if you have all those indicators.
Stephen J Irons
NCM Family Member
Apple IS Genisys!
MIT
Club Member
Wed 13 Jun 18 15:37
Hi, yes, Iíll see how they do when all wired up, and if theyíre not flashing right Iíll swop the flasher. Is there a generic one available in the U.K.?
The side makers fit on opposite sides, so front left fits rear right etc.
Thanks for the help. Thumbs up
Tim.
74 coupe.
sublimemike
Club Member
Thu 14 Jun 18 22:19
Hi MIT
Yes the flasher was changed for the led's to work . Needed a solid state. I left my rears as is US style. I had a lenient mot tester. Now I don't need an MOT. Im maybe taking a chance but its got to be a real jobs worth I think to ticket me and I didn't want to cut up my loom up.
MIT
Club Member
Fri 15 Jun 18 17:55
The no mot thing is great, loving the fact itís just the insurance to pay for to have it sitting in the garage! Still surprised thereís no need for an initial mot for imports.
Tim.
74 coupe.
Reply to topic
Permissions
