CCCUK logo
 Adrian Flux
Website Control
Recent threads
New Forum Posts
» l/h rear brake caliper wanted by damc3 on Mon 24 Sep 18 00:01
» DeLorean DMC-12 with LS3 480 by Chris_Von_Bron on Sun 23 Sep 18 20:53
» 2008 z06 jacking pucks. by Norm on Sun 23 Sep 18 20:41
» Failed oil pump drive by roscobbc on Sun 23 Sep 18 20:21
» C3 that are in UK 1968-73 with chrome bumpers pics please! by L88 on Sat 22 Sep 18 19:11
» C8 is Coming by Alan305 on Sat 22 Sep 18 14:01
» Resto Vette - or - Modifed Vette by MIT on Sat 22 Sep 18 11:18
» Amazing by MIT on Sat 22 Sep 18 11:07
» Spare wheel light by PAZ9556 on Fri 21 Sep 18 19:35
» '95 C4 with LT1 missfire by corvetteville on Fri 21 Sep 18 18:42
» 1989 C4 For Sale by RickyG512 on Fri 21 Sep 18 14:28
» C7 Configurator by c6pete on Thu 20 Sep 18 12:46
» C2 fibreglassing and prep. by L88 on Wed 19 Sep 18 20:50
» What did you do with your Vette today? by FelixP on Wed 19 Sep 18 13:44
» Potential new C5 owner - some basic questions by Le Vette on Tue 18 Sep 18 14:09
» My 01 c5 yellow for sale by Celcius on Sun 09 Sep 18 20:58
» For Sale 09 C6 Corvette by John Lynn on Sun 09 Sep 18 01:25
Exhaust too loud.
Reply to topic
Author
Message
MIT
Club Member
Wed 11 Jul 18 00:41
Exhaust too loud.
Hi, didnít ever think Iíd say this, but after driving the 74 a few times now, itís just too loud! It really resonates at 13-1800rpm, and not a lot better around that. Now, Iíd rather not fork out for a new system, and wondered if anyone has added custom centre silencers? Itíll also be kinder to the neighbors.
I have ceramic stainless headers, then straight through to a Flowmaster back box on each side, not very big ones at that!
I might go down the soundproofing under the carpet as well later.
Cheers.
Tim.
74 coupe.
roscobbc
Wed 11 Jul 18 01:05
Re: Exhaust too loud.
Your problem may well be the Flowmaster muffler itself. If its one of the 'delta flow' types I think you'll find that it uses a series of deflector plates in the muffler casing to supposedly 'silence' the exhaust with minimal HP losses. There are a number of different versions of these - my experience of them is that they are quite noisy at idle speeds and lower rpm - giving that muscle car sound - when at higher rpm and at load they quieten down a fair bit - but they resonate badly inside the car, especially if A. you have a cam installed and B. and auto transmission with a stock stall speed converter and low numerical axle ratio.
An absobrsion tube muffler (Magnaflow, Jetex, etc) should resonate much less and will be quieter when soft pedalling the gas - and making the right noises when nailing the 'loud' pedal.
CCCUK Chairman
MIT
Club Member
Wed 11 Jul 18 03:35
Thatís pretty much exactly it. Low cruising loads itís noisy, and I do have a fancy cam. So maybe a case of new silencers then. Itís a welded system, from the header collector back, so might have to pop into one of these custom exhaust shops. More money!
Cheers Tony. Thumbs up
Tim.
74 coupe.
Reply to topic
Permissions
