CCCUK logo
 Adrian Flux
Website Control
Recent threads
New Forum Posts
» Failed oil pump drive by Daytona Vette on Sun 23 Sep 18 10:04
» 2008 z06 jacking pucks. by Jack Oreilly on Sun 23 Sep 18 09:31
» C3 that are in UK 1968-73 with chrome bumpers pics please! by L88 on Sat 22 Sep 18 19:11
» C8 is Coming by Alan305 on Sat 22 Sep 18 14:01
» Resto Vette - or - Modifed Vette by MIT on Sat 22 Sep 18 11:18
» Amazing by MIT on Sat 22 Sep 18 11:07
» Spare wheel light by PAZ9556 on Fri 21 Sep 18 19:35
» '95 C4 with LT1 missfire by corvetteville on Fri 21 Sep 18 18:42
» 1989 C4 For Sale by RickyG512 on Fri 21 Sep 18 14:28
» C7 Configurator by c6pete on Thu 20 Sep 18 12:46
» C2 fibreglassing and prep. by L88 on Wed 19 Sep 18 20:50
» What did you do with your Vette today? by FelixP on Wed 19 Sep 18 13:44
» Potential new C5 owner - some basic questions by Le Vette on Tue 18 Sep 18 14:09
» My 01 c5 yellow for sale by Celcius on Sun 09 Sep 18 20:58
» For Sale 09 C6 Corvette by John Lynn on Sun 09 Sep 18 01:25
» C2 Bonnets by L88 on Sat 08 Sep 18 22:56
» BBCN Regional meet by autocolor on Sat 08 Sep 18 09:48
U-joint replacement
Go to page: 1, 2 / Next
Reply to topic
Author
Message
MIT
Club Member
Tue 31 Jul 18 22:36
U-joint replacement
Hi, as Im slowly going through all the drivetrain and steering on the 74 ( Borgeson steering box done, see projects ), and as Im changing the rear wheel bearings soon, Im thinking of changing the half shaft u-joints while the half shafts are dropped, and prop shaft. Apart from the potential the bend the flange when pressing the caps out, is it an easy job? Ill bolt the flanges to some steel plate I have to prevent bending them.
There so cheap seems silly not to do them. Thumbs up
Tim.
74 coupe.
Club Member
Wed 01 Aug 18 09:49
Re: U-joint replacement
Tim, I f you have a decent press, its not too tricky. As you say, hold the flanges (I have an old one I use and bolt to the good one) and take your time. We had to have a few goes at getting them set nicely, but not too tight. Don't faff about trying to do it in a vice!
Also, if get U/Js with grease nipples, make sure they are orientated correctly. I think from memory, the nipples must be facing inward (towards the shaft) at both ends if you actually want to get a grease gun on to them!
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
MIT
Club Member
Wed 01 Aug 18 10:47
Cheers, due the mileage Ill be doing, ie very little, I was going to use the lifetime sealed spicer type. I have access to a press at work if I need one.
Tim.
74 coupe.
Club Member
Fri 03 Aug 18 12:07
Tim, I dashed off a quick reply last time as we were on our way out!
But I'd add that it would be a good idea to replace the U Bolts and nuts for the inner yokes as well when you do the job. And, make sure you buy some new (preferably stainless) French Locks for the outer flange bolts. They seem a pain to bend back to undo the nuts (I get @so far@ and pop a socket over and give it a tap or two) and almost as much trouble to fold back again, but from what I read they are sooo much better than trying to use ordinary lock washers.
If you have the original metal spring you'll probably want to release that at the outer ends (there is a process for that described in the Haynes manual) but if you have a replacement "plastic" unit it is possible to remove the half shafts with the spring still attached to the trailing arms.
I do mark the shafts so that they go back on the same side, in the same orientation, but I never really know if that's necessary!
Stephen J Irons
NCM Family Member
Apple IS Genisys!
MIT
Club Member
Fri 03 Aug 18 15:32
Thanks Stephen, as Im doing it at the same time as the bearings, Ill drop the leaf spring mount bolts out, as you say itll give me better access. Ive just replaced these as well. I have considered fitting a mono spring, but getting mixed reviews so Ill leave that for now.
Ill order the new u bolts and French locks, thanks for the heads up. Thumbs up
Tim.
74 coupe.
Club Member
Fri 03 Aug 18 19:54
MIT wrote (View Post):......I have considered fitting a mono spring, but getting mixed reviews so Ill leave that for now..... :
We put our TRW unit on the old '78 19 years ago and it's one of the best things we ever did. You do need new shocks though, we went with Koni Adjustables.....
Stephen J Irons
NCM Family Member
Apple IS Genisys!
curious bystander
Fri 03 Aug 18 21:29
Stephen - you're suggesting to Tim that he use s/s French locks, but in my experience s/s is much harder to bend. Especially if you're in a tight corner
Might be wrong but ......
79 L82 Auto
Having a lot of bhp is all very well, but on these forums it's torque that counts
Club Secretary
Club Member
Sat 04 Aug 18 09:54
Bill, you're probably right! I just like to use the S/S versions as they are available and keep their condition better. Maybe that explains why I find bending them so hard these days - I'm sure the first set I used were probably the "ordinary" stuff! Very Happy
Stephen J Irons
NCM Family Member
Apple IS Genisys!
MIT
Club Member
Mon 13 Aug 18 22:37
So, turns out I have a new prop, so need to find a decent paint for it, as its just starting to get a surface rust.
I remember Tony said he uses Cromadex, just need to find a supplier.
Tim.
74 coupe.
langlj00
Club Member
Mon 20 Aug 18 13:03
If you've got a new Prop - you'll have new UJs anyway!
1974 / 350 / Auto / T-Top
Reply to topic
Permissions
